Author Topic: reactor on QUIT.  (Read 7807 times)
Andrea
reactor on QUIT.
« on: October 16, 2006, 10:17:06 AM »
Good morning All.. 8-)
I'm playing with reactor..
and trying do to something like this..
(vlr-command-reactor nil '((:vlr-commandEnded . endQCommand)))
(defun endQCommand (calling-reactor endquitInfo / EQP)
  (setq EQP (nth 0 endquitdInfo))
  (if (= EQP "QUIT") (alert "QUIT ended"))
But AutoCAD QUIT before showing the alert box...
same thing with commandCancelled and failed.
What i'm trying to do is to put some cad user information on a network drive before leaving AutoCAD.
Any help will be appreciated.
thanks. :-)
« Last Edit: October 16, 2006, 10:19:15 AM by Andrea »
Keep smile...
Patrick_35
Re: reactor on QUIT.
« Reply #1 on: October 16, 2006, 10:39:37 AM »
Hi
(vlr-command-reactor nil (list (cons :vlr-CommandWillStart (function endQCommand))))
(defun endQCommand (calling-reactor endquitInfo)
  (if (= (car endquitInfo) "QUIT") (alert "QUIT ended"))
« Last Edit: October 16, 2006, 10:41:26 AM by Patrick_35 »
« Reply #2 on: October 16, 2006, 10:47:05 AM »
        (:vlr-commandWillStart . _CommandWillStart)
(defun _CommandWillStart ( reactor args  )
    (if (member (car args) '("QUIT" "END"))
        (alert "I'm about to die!")
Andrea
« Reply #3 on: October 16, 2006, 01:22:31 PM »
woo !  :roll:
thanks guys...but not working !  :-)
I think that's using vlr-commandWillStart is not the solution...
because autocad do not detect if user press Cancel in the dialog box when drawing wasn't save
by the way...MP....Nice avatar !  :wink:
« Last Edit: October 16, 2006, 01:30:24 PM by Andrea »
Keep smile...
« Reply #4 on: October 16, 2006, 01:42:15 PM »
My guess is you're not talking about the AutoCAD application being killed, you're talking about a document being closed. Perhaps --
(vlr-docmanager-reactor nil
        (:vlr-documentToBeDestroyed . _DocumentToBeDestroyed)
(defun _DocumentToBeDestroyed ( reactor args  )
    (alert "Document about to die!")
Andrea
« Reply #5 on: October 16, 2006, 02:37:53 PM »
vlr-documentToBeDestroyed !!
thats the way !
thanks MP.
Keep smile...
Andrea
« Reply #6 on: October 16, 2006, 03:16:51 PM »
oops...!!
was enjoying to earlier..
The routine work well only if we close a drawing....
but not when closing AutoCAD without any drawing...
so that create another question..
Is it possible to run any lisp without any drawing open ?
The program i'm trying to create is to send a message only when AutoCAD is closing.
is this possible in lisp ?
« Last Edit: October 16, 2006, 03:18:15 PM by Andrea »
Keep smile...
« Reply #7 on: October 16, 2006, 03:24:11 PM »
Not that I know of.  You may have to look at another language.
Andrea
« Reply #8 on: October 16, 2006, 04:13:19 PM »
ok ...thank you. :kewl:
Keep smile...
