Author Topic: List of numbers to compacted string?  (Read 12829 times)
Re: List of numbers to compacted string?
« Reply #15 on: October 13, 2006, 04:10:07 PM »
I like the recursive approach, but it looks like it has problems....
(1 3 5 6 8 53 54 55 56 57 58 59 60 61 62 63 64 66 67 68)
_$ (test testlist)
"1,5-6,53-64,67-68"
« Reply #16 on: October 13, 2006, 05:25:42 PM »
Okay, here is my new entry.  I think it will work better.  Inspiration from Michael's.  :-)
(defun NumList->String (NumList AddFactor / StrList Str)
(foreach Num NumList
  ((not StrList)
   (setq StrList (list (list Num)))
  ((equal (caar StrList) (- Num AddFactor) (* AddFactor 0.25))
   (setq StrList (subst (cons Num (car StrList)) (car StrList) StrList))
  (T
   (setq StrList (cons (list Num) StrList))
(setq Str "")
(foreach Lst (reverse StrList)
  ((equal (length Lst) 1)
   (setq Str (strcat Str (vl-princ-to-string (car Lst)) ","))
  ((equal (length Lst) 2)
   (setq Str (strcat Str (vl-princ-to-string (cadr Lst)) "," (vl-princ-to-string (car Lst)) ","))
  (T
   (setq Str (strcat Str (vl-princ-to-string (last Lst)) "-" (vl-princ-to-string (car Lst)) ","))
(substr Str 1 (1- (strlen Str)))
Return
Command: (NumList->String '(1 2 4 5 6  8 10 11 12) 1)
"1,2,4-6,8,10-12"
Command: (NumList->String '(1.0 2 4 5 6  8 10 11 12) 0.1)
"1.0,2,4,5,6,8,10,11,12"
Command: (NumList->String '(1.0 1.1 1.2 2 2.1 2.2 2.5) 0.1)
"1.0-1.2,2-2.2,2.5"
Command: (NumList->String '(1 3 5 6 8 53 54 55 56 57 58 59 60 61 62 63 64 66 67 68) 1)
"1,3,5,6,8,53-64,66-68"
« Reply #17 on: October 13, 2006, 09:16:44 PM »
OK late to the party again.
Took my wife out to dinner, first time in 8 weeks. Big points.  :-)
This code will handle reals but not like Tim's, no AddFactor
(defun intstorangedstring (ints / sorted result x y )
  (setq sorted (vl-sort ints '>)
        x      (car sorted)
        sorted (cdr sorted)
        result (list (vl-princ-to-string x))
  (while (setq y (car sorted))
    (setq sorted (cdr sorted))
      ((and (= (1+ y) x) (= (1- y) (car sorted)))
       (if (/= (car result) "-") (setq result (cons "-" result)))
      ((= (car result) "-")
       (setq result (cons (vl-princ-to-string y) result))
      ((setq result (cons (vl-princ-to-string y) (cons "," result))))
    (setq x y)
 (apply 'strcat result)
(defun c:test ()
  (print (intstorangedstring '(1 3 4 5 8 10 11 14 15 16)))
  ;; "1,3-5,8,10,11,14-16"
  (print (intstorangedstring '(1 2 4 5 6  8 10 11 12)))
  ;;  "1,2,4-6,8,10-12"
  (print (intstorangedstring '(1.0 2 4 5 6  8 10 11 12)))
  ;; "1.0,2,4,5,6,8,10,11,12"
  (print (intstorangedstring '(1 3 5 6 8 53 54 55 56 57 58 59 60 61 62 63 64 66 67 68)))
  ;;  "1,3,5,6,8,53-64,66-68"
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #18 on: October 14, 2006, 01:13:33 AM »
_$ (test testlist)
"1,5-6,53-64,67-68"
Excuse, I have hastened and have badly checked up... :oops:
(defun test (lst)
  (if (and lst (listp (car lst)))
      ((not (cadr lst))
       (strcat (itoa (caar lst)) "-" (itoa (cadar lst)))
      ((equal (1+ (cadar lst)) (cadr lst) 1e-8)
       (test (cons (list (caar lst) (cadr lst)) (cddr lst)))
      (t (strcat (itoa (caar lst)) "-" (itoa (cadar lst)) "," (test (cdr lst))))
    ) ;_  cond
      ((null lst) "")
      ((not (cadr lst)) (itoa (car lst)))
      ((equal (1+ (car lst)) (cadr lst) 1e-8)
       (test (cons (list (car lst) (cadr lst)) (cddr lst)))
      (t (strcat (itoa (car lst)) "," (test (cdr lst))))
    ) ;_  cond
  ) ;_  if
(test  '(1 3 5 6 8 53 54 55 56 57 58 59 60 61 62 63 64 66 67 68))
"1,3,5-6,8,53-64,66-68"
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: October 14, 2006, 01:35:26 AM »
Has deleted superfluous checks...
(defun test (lst)
  (if lst
    (if (listp (car lst))
      (if (cadr lst)
        (if (equal (1+ (cadar lst)) (cadr lst) 1e-8)
        ) ;_  if
      ) ;_  if
      (if (cadr lst)
        (if (equal (1+ (car lst)) (cadr lst) 1e-8)
        ) ;_  if
        (itoa (car lst))
      ) ;_  if
    ) ;_  if
  ) ;_  if
« Reply #20 on: October 14, 2006, 01:41:31 AM »
Evgeniy,
very nice ..
Could you show how you would expand the list ?
ie
(setq x "1,3,5-6,8,53-64,66-68" )
(test_expand x) ;; ->>
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: October 14, 2006, 04:34:29 AM »
Evgeniy,
very nice ..
ie
(defun test1 (s)
  (if s
    (if (listp s)
      (if (and (cadar s)(< (caar s) (cadar s)))
          (cons (caar s) (test1 (cons (list (1+ (caar s)) (cadar s)) (cdr s))))
          (cons (caar s)(test1 (cdr s)))
      (test1
        (read
          (strcat
            (apply
              (function strcat)
              (mapcar
                (function
                  (lambda (x)
                      ((< 47 x 58) (chr x))
                      ((= 44 x) ")(")
                      ((= 45 x) " ")
                    ) ;_  cond
                  ) ;_  lambda
                ) ;_  function
                (vl-string->list s)
              ) ;_  mapcar
            ) ;_  apply
          ) ;_  strcat
        ) ;_  read
      ) ;_  test
    ) ;_  if
  ) ;_  if
« Reply #22 on: October 14, 2006, 04:59:34 AM »
Evgeniy,
(test1 "1,3,5-6,8,53-64,66-68")
; error: too many arguments
edit : piccy
« Last Edit: October 14, 2006, 05:08:56 AM by Kerry Brown »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #23 on: October 14, 2006, 05:06:47 AM »
Whence it (T)??
« Reply #24 on: October 14, 2006, 05:11:15 AM »
 ahhhhh ,  My bad ..   :oops:
Thanks !
« Reply #25 on: October 14, 2006, 06:28:27 PM »
I think I must have left the t when I removed the closing_comments ..
          ) ;_  strcat
clumsy !
Andrea
« Reply #26 on: October 14, 2006, 07:25:13 PM »
and mine...
[code(setq mainlist (vl-sort '(1 3 4 5 8 10 11 14 15 16) '<) Flist "")
(foreach n mainlist
  (setq i1 (car mainlist) i2 (cadr mainlist))
  (if i2
      (if (eq (+ i1 1) i2)
(setq Flist (strcat Flist (rtos i1 2 0) ","))
(setq Flist (strcat Flist (rtos i1 2 0) "-")))
      (setq mainlist (cdr mainlist))
    )(setq Flist (strcat Flist (rtos i1 2 0)))
))(alert (strcat "Ther it is: " Flist))
« Last Edit: October 14, 2006, 07:30:45 PM by Andrea »
Keep smile...
« Reply #27 on: October 14, 2006, 07:30:04 PM »
Andrea, you may need to test that.
Andrea
« Reply #28 on: October 14, 2006, 07:33:06 PM »
test result....
Keep smile...
« Reply #29 on: October 14, 2006, 07:36:58 PM »
test result.... "1-3,4,5-8-10,11-14,15,16"
I believe it should return "1,3-5,8,10-11,14-16"  or "1,3-5,8,10,11,14-16" depending on how you read the specifications.
