Author Topic: List of numbers to compacted string?  (Read 12832 times)
« on: October 13, 2006, 02:31:13 PM »
OK, so it's Friday, it's been a long week, and I just can't seem to get into coding this seemingly simple function. Anyone care to help out?
Given: List of numbers, sorted lowest->highest, not necessarily sequential.
Needed: String of said numbers, compacting the sequential ones.
Example:
This list: '(1 3 4 5 8 10 11 14 15 16)
would return this string: "1,3-5,8,10,11,14-16"
Re: List of numbers to compacted string?
« Reply #1 on: October 13, 2006, 03:03:49 PM »
Be gentle, very quick, very dirty --
(defun IntsToRangedString ( ints / sorted result group )
    ;;  first sort em, losing any duplicates
    (setq
        sorted (vl-sort ints '<)
        result (list (list (last sorted)))
    ;;  now roll 'em ...
    (foreach x (cdr (reverse sorted))
        (setq result
            (if (eq (1+ x) (car (setq group (car result))))
                (cons
                    (cons x (list (last group)))
                    (cdr result)
                (cons
                    (list x)
                    result
    (setq result
        (mapcar
           '(lambda ( lst / a b )
                    (   (eq 1 (length lst))
                        (itoa (car lst))
                    (   (eq (1+ (setq a (car lst))) (setq b (cadr lst)))
                        (strcat (itoa a) "," (itoa b))
                    (   (strcat (itoa a) "-" (itoa b))  )
            result
    (apply 'strcat
        (append
            (list (car result))
            (mapcar
               '(lambda (x) (strcat "," x))
                (cdr result)
(IntsToRangedString '(1 3 4 5 8 10 11 14 15 16))
« Reply #2 on: October 13, 2006, 03:12:26 PM »
Here is mine.
(defun ForJeff (NumList / Str PrevNum Hyphen)
(foreach Num NumList
 (if (not Str)
  (setq Str (itoa Num))
  (if (equal (1- Num) PrevNum)
   (setq Hyphen T)
   (setq Str
    (strcat
     Str
     (if Hyphen
       (setq Hyphen nil)
       (strcat "-" (itoa PrevNum) "," (itoa Num))
      (strcat "," (itoa Num))
  (and
   (equal Num (last NumList))
  (setq Str
   (strcat
    Str
    (if Hyphen
      (setq Hyphen nil)
      (strcat "-" (itoa Num))
 (setq PrevNum Num)
; (prompt (strcat "\n Testing: " Str))
Str
Return
Command: (forjeff '(1 3 4 5 8 10 11 14 15 16))
"1,3-5,8,10-11,14-16"
Command: (forjeff '(1 3 4 5 8 10 11 14 15 16 20))
"1,3-5,8,10-11,14-16,20"
« Reply #3 on: October 13, 2006, 03:14:18 PM »
« Reply #4 on: October 13, 2006, 03:18:51 PM »
Thanks, Michael! Looks almost like what I was imagining but couldn't quite code.
Works great, too! :-)
Thanks to Tim, too! Only minor deficiency I see is "10-11" should be "10,11" but looks great, too.
Now I can get back to some real work.
« Reply #5 on: October 13, 2006, 03:21:29 PM »
Here is mine ...
Cool.
Same could/is said about yours.  Going the list route.  Took me a little while to see the whole flow.  I like the example.  :-)
Guess I could look at that, but since Michael's works.......
Have fun today.   :-D
« Reply #6 on: October 13, 2006, 03:27:47 PM »
You're very welcome Jeff. I'm surprised I can code anything today -- have a cold / splitting headache -- but I am in the comfort of my own home* -- maybe that's what enabled a solution to percolate up.
* Officially unemployed (of my own volition) as of yesterday but starting with a new client on the 30th, so all is cool.
« Reply #7 on: October 13, 2006, 03:34:40 PM »
Sorry to hear this.  Get better soon.
Happy to hear this.  Hope the new client will stimulate you mind, and keep things fresh and fun.  Good luck there Michael.
« Reply #8 on: October 13, 2006, 03:42:32 PM »
Thanks Tim!
Thanks x 2! The new job has abundant promise: A spectrum of automation challenges, no development software handcuffs + good peeps, folks I've worked with before and have lots of respect for (that bring buckets of expertise and experience to the table). Bidirectional mentoring = true. What's not to like?
« Reply #9 on: October 13, 2006, 03:44:49 PM »
Dittos on the get well soon, MP. While it'll be good to be off the next few weeks to recharge your system, it would be far better if you felt good during that period.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #10 on: October 13, 2006, 03:45:53 PM »
(defun test (lst)
  (if (and lst (listp (car lst)))
      ((not (cadr lst))
       (strcat (itoa (caar lst)) "-" (itoa (cadar lst)))
      ((= (1+ (cadar lst)) (cadr lst))
       (test (cons (list (caar lst) (cadr lst)) (cddr lst)))
      (t (strcat (itoa (caar lst)) "-" (itoa (cadar lst)) "," (test (cddr lst))))
    ) ;_  cond
      ((null lst) "")
      ((not (cadr lst)) (itoa (car lst)))
      ((= (1+ (car lst)) (cadr lst))
       (test (cons (list (car lst) (cadr lst)) (cddr lst)))
      (t (strcat (itoa (car lst)) "," (test (cddr lst))))
    ) ;_  cond
  ) ;_  if
« Reply #11 on: October 13, 2006, 03:47:28 PM »
Thanks and true Jeff. I'm exploiting the time off / bed rest by doing as much geek reading as my eyes will permit.
« Last Edit: October 13, 2006, 03:50:00 PM by MP »
« Reply #12 on: October 13, 2006, 03:49:19 PM »
« Reply #13 on: October 13, 2006, 03:55:52 PM »
Great thread guys !
gile
  • Marseille, France
« Reply #14 on: October 13, 2006, 03:58:02 PM »
Another way :
(defun intlst2str (lst / str)
  (setq lst (vl-sort lst '<)
str ""
  (while lst
    (setq str (strcat str (itoa (car lst))))
    (if (= (+ 2 (car lst)) (caddr lst))
(setq str (strcat str "-"))
(while (= (1+ (car lst)) (cadr lst))
  (setq lst (cdr lst))
    (if lst
      (setq str (strcat str ","))
    str
