Author Topic: VBA Plotting  (Read 4016 times)
deegeecees
VBA Plotting
« on: October 12, 2006, 05:31:11 PM »
Working on yet another QuickPlot program here. I've had no problems with a "SendCommand" scenario, basically command lining through all the prompts via "vbCr". Works great. But NOW they (the users) want to be able to plot a windowed portion of the modelspace layout. So, here's what I've got:
Old method:
Sub plt_18x24()
Call AcadApplication.RunMacro("Q:\Std\ACAD\Support\Lisp\drafting_db.dvb!plot_counter")
ThisDrawing.SendCommand "-plot" & vbCr & "y" & vbCr & "Model" & vbCr & "Oce TDS600 3.x.pc3" & vbCr & "ARCH expand C (24.00 x 18.00 Inches)" & vbCr & "inches" & vbCr & "Landscape" & vbCr & "no" & vbCr & "extents" & vbCr & "fit" & vbCr & "Center" & vbCr & "yes" & vbCr & "comed36x24.ctb" & vbCr & "yes" & vbCr & "n" & vbCr & vbCr & vbCr & vbCr
End Sub
Here's what I'm trying to develop:
Sub qplot_d_color()
    Dim point1 As Variant, point2 As Variant
    point1 = ThisDrawing.Utility.GetPoint(, "Click the lower-left of the window to plot.")
    ReDim Preserve point1(0 To 1)
    point2 = ThisDrawing.Utility.GetPoint(, "Click the upper-right of the window to plot.")
    ReDim Preserve point2(0 To 1)
    ThisDrawing.ActiveLayout.SetWindowToPlot point1, point2
    ThisDrawing.ActiveLayout.GetWindowToPlot point1, point2
ThisDrawing.SendCommand "-plot" & vbCr & "y" & vbCr & "Model" & vbCr & "DesignJet 500.pc3" & vbCr & "ARCH D (36.00 x 24.00 Inches)" & vbCr & "inches" & vbCr & "Landscape" & vbCr & "no" & vbCr & "window" & vbCr & vbCr & vbCr & "fit" & vbCr & "Center" & vbCr & "yes" & vbCr & "C-D-E_Color.ctb" & vbCr & "yes" & vbCr & "n" & vbCr & vbCr & vbCr & vbCr
End Sub
Works OK, except for being a bit buggy when there is no "rectangle" to choose LL & UR corners. Aside from that it's also a bit cheesy.
Any improvements are extremely welcomed.
David Hall
  • Automatic Duh Generator
Re: VBA Plotting
« Reply #1 on: October 12, 2006, 06:18:57 PM »
i have a quick plot routine for VBA, but not using  a window.  Let me see what I can add
mohnston
  • CAD Programmer
Re: VBA Plotting
« Reply #2 on: October 12, 2006, 06:29:25 PM »
You could try dropping the SendCommand which will almost always give you problems. Plotting in VB/VBA is not simple but it isn't impossible either.
This might get you started. Keep in mind I haven't tested this.
Public Sub foo()
    Dim config As AcadPlotConfiguration
    Set config = ThisDrawing.PlotConfigurations(ThisDrawing.ActiveLayout.ConfigName)
    config.ConfigName = "Oce TDS600 3.x.pc3"
    config.CanonicalMediaName = "ARCH expand C (24.00 x 18.00 Inches)"
    config.PlotType = acExtents
    config.CenterPlot = True
    config.StandardScale = acScaleToFit
    config.RefreshPlotDeviceInfo
    ThisDrawing.Plot.PlotToDevice config.ConfigName
End Sub
CAD Programming Solutions
deegeecees
Re: VBA Plotting
« Reply #3 on: October 12, 2006, 06:57:48 PM »
Thanks Cmdr, it's been a while since I've been able to work on anything VBA related. Been working my butt off on design issues, hence my call to arms. I appreciate it.
deegeecees
Re: VBA Plotting
« Reply #4 on: October 12, 2006, 06:58:44 PM »
Thanks Mohnston, I'll post results tomorrow.
David Hall
Re: VBA Plotting
« Reply #5 on: October 13, 2006, 09:52:04 AM »
This is my setup routine
Option Explicit
Public Sub SetupAndPlot(ByRef Plotter As String, CTB As String, SIZE As String, PSCALE As String, ROT As String)
    Dim Layout As AcadLayout
    On Error GoTo Err_Control
    Set Layout = ThisDrawing.ActiveLayout
    Layout.RefreshPlotDeviceInfo
    Layout.ConfigName = Plotter    ' CALL PLOTTER
    Layout.PlotType = acExtents
    Layout.PlotRotation = ROT    ' CALL ROTATION
    Layout.StyleSheet = CTB    ' CALL CTB FILE
    Layout.PlotWithPlotStyles = True
    Layout.PlotViewportBorders = False
    Layout.PlotViewportsFirst = True
    Layout.CanonicalMediaName = SIZE    ' CALL SIZE
    Layout.PaperUnits = acInches
    Layout.StandardScale = PSCALE    'CALL PSCALE
    Layout.ShowPlotStyles = False
    ThisDrawing.Plot.NumberOfCopies = 1
    Layout.CenterPlot = True
    Layout.ScaleLineweights = False
    ThisDrawing.Regen acAllViewports
    ZoomExtents
    Set Layout = Nothing
    ThisDrawing.Save
Exit_Here:
    Exit Sub
Err_Control:
    Select Case Err.Number
    Case "-2145320861"
        MsgBox "Unable to Save Drawing- " & Err.Description
    Case "-2145386493"
        MsgBox "Drawing is setup for Named Plot Styles." & (Chr(13)) & (Chr(13)) & "Run CONVERTPSTYLES command", vbCritical, "Change Plot Style"
    Case Else
        MsgBox "Unknown Error " & Err.Number
    End Select
End Sub
and this is how I call it and pass in size, rotation, ctb etc as arguments
' a few examples
Public Sub Vendor1117()
    Call SetupAndPlot("11x17Draft.pc3", "11X17-CHECKSET.ctb", "ANSI_B_(11.00_x_17.00_Inches)", acScaleToFit, ac90degrees)
    ThisDrawing.Close (True)
End Sub
Public Sub VendorQuickPlotC()
    Call SetupAndPlot("OCE DesignJet 750C.pc3", "VENDOR MEDIUM.ctb", "ARCH_expand_C_(24.00_x_18.00_Inches)", acScaleToFit, ac0degrees)
End Sub
Public Sub VendorQuickPlotD()
    Call SetupAndPlot("OCE DesignJet 750C.pc3", "VENDOR MEDIUM.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
End Sub
Now all we need to do is generate a window and feed that in.
David Hall
Re: VBA Plotting
« Reply #6 on: October 13, 2006, 09:56:03 AM »
I found this
layout.GetWindowToPlot LL,UR so all you need to do is define LL and UR as doubles
with
dim LL(0 to 2) as double
dim UR(0 to 2) as double
'pseudo code getpoint LL and UR
deegeecees
Re: VBA Plotting
« Reply #7 on: October 13, 2006, 11:16:31 AM »
Thanks Cmdr, got a deadline to meet today. Between you and Mohnston, I think there's enough info to help me figure it out.
Rush, rush rush!
Zooom....
David Hall
Re: VBA Plotting
« Reply #8 on: October 13, 2006, 03:27:48 PM »
I got this to work
Dim LL As Variant, UR As Variant
    LL = ThisDrawing.Utility.GetPoint
    UR = ThisDrawing.Utility.GetPoint
    ThisDrawing.ModelSpace.AddLine LL, UR
so i was able to draw a line, so you should be able to use the Layout.GetWindowToPlot LL,UR
