Author Topic: arx vectors help  (Read 2919 times)
ckulhanek
arx vectors help
« on: October 12, 2006, 12:10:09 PM »
can someone give me a brief rundown on AcGeVector2d and 3d. I don't get it. When I create one, i'm passing in...  what?  Points? And how does the function create a vector from this? I don't understand. Thanks for help.
-ck
Swift
Re: arx vectors help
« Reply #1 on: October 12, 2006, 01:12:07 PM »
a vector is the difference between two points, or how do i get from pt a to pt b.
 think of it as an autocad command
line
10,10,10
@5,5,5 // vector
the resulting point is 15,15,15
The AcGeCeVector2d and 3d are both based from the origin
« Last Edit: October 12, 2006, 01:15:55 PM by Swift »
ckulhanek
« Reply #2 on: October 12, 2006, 02:06:00 PM »
so, it's the sum of the points, actually, is the new point location, from the origin. And the vector, is distance, from 0,0,0.  Interresting.
line
10,10,10
@5,5,5 // vector
Swift
« Reply #3 on: October 12, 2006, 05:14:21 PM »
MickD has an article on vectors around here, perhaps you need to give that a read
MickD
  • (x-in)->[process]->(y-out)
« Reply #4 on: October 12, 2006, 05:48:03 PM »
Welcome aboard ckulhanek!
have a look here -> http://www.theswamp.org/index.php?page=16 for a brief article on vectors, there's another one around there too.
Lao Tzu: “To attain knowledge, add things
every day; to obtain wisdom, remove things every day.”
