Author Topic: Challenge: Get all system variables with values  (Read 23640 times)
« on: October 11, 2006, 04:03:21 PM »
I don't know how one would accomplish this, and thought it might be fun.  I will look into this a little more when I get back from lunch.
Guest
Re: Challenge: Get all system variables with values
« Reply #1 on: October 11, 2006, 04:15:41 PM »
You mean besides....??
Command: setvar
Enter variable name or [?]: ?
Enter variable(s) to list <*>:
Then copy/paste.
« Reply #2 on: October 11, 2006, 04:19:05 PM »
(c:sysvdlg)
Guest
« Reply #3 on: October 11, 2006, 04:22:40 PM »
Now what about the SETENV variables??  How does one obtain a list of those?!?  And are they the same for the various verticals??
« Reply #4 on: October 11, 2006, 04:49:09 PM »
(c:sysvdlg)
Pretty good, but it doesn't have them all.  There is no 'qaflags'.  I'm looking for them ALL.  :-)
Edit:
Good question.  I would like to know this answer also.
The detective work continues.
« Last Edit: October 11, 2006, 04:50:34 PM by T.Willey »
« Reply #5 on: October 11, 2006, 04:52:19 PM »
Edit the sysvdlg.dat file?
uncoolperson
« Reply #6 on: October 11, 2006, 04:59:20 PM »
BRUTE FORCE
where list is ("AAA" "AAB" "AAC" etc...)
foreach item in list
if (getvar item) returns something
it's a var
if (getenv item) returns something
it's a var
if not
then it aint
« Reply #7 on: October 11, 2006, 05:02:35 PM »
How about if you don't know what you are missing?  It doesn't look like it's in the 'atoms-family' which I must admit, I'm not sure about 'atom's to begin with.  I will continue to look around.
Thanks for pointing those out.  I did't even know about them.
« Reply #8 on: October 11, 2006, 05:03:39 PM »
BRUTE FORCE
it's a var
it's a var
if not
then it aint
Trying not to go that route.  Who knows how long that process would take?  How many letters would you make the sting limits be?
« Reply #9 on: October 11, 2006, 05:11:47 PM »
Good question and I don't know. I'm guessing it's internal (in the AutoCAD executable, though that is pure speculation).
You're right about the atoms-family, it doesn't host the system variables. On that topic, you may find the tool in this thread interesting / useful / not.
No problem My pleasureTim.
Edit: My wife says "No problem" all the time because everyone at her work says that and I can't stand it. Can't believe I just posted same. Carry on.
« Last Edit: October 11, 2006, 05:15:02 PM by MP »
« Reply #10 on: October 11, 2006, 05:23:46 PM »
Very cool routine!  I'm not all up on atoms, so it may be over my head right now, but I can see some good things with it.
I know what you mean.  I've been trying to kick the habbit of saying it also.  When people say 'thank you' and I respond with 'no problem' instead of 'you're welcome' or something, I'm just like 'why did I say that'  :-D oh well.  I will learn soon enough.
Thanks again Michael.
« Reply #11 on: October 11, 2006, 05:42:04 PM »
My bright idea :-o?
You could set up a lisp with this:
;;  Check all words "aaaa" through "zzzzzzzzzzzzzzz"
(defun c:getvars ()
  (setq seed "aaaa")
  (while (< (strlen seed) 15)
    (if (setq var (getvar seed))
      (setq vlist (cons seed vlist))
    ;; Here you will need to increment the string
    ;; Going through all carbonations, then add a character.
    ;;  too tired to do it though, it's beer 30
  ) ; while
  vlist
LE
« Reply #12 on: October 11, 2006, 05:42:44 PM »
I am doing some laundry work right now (so no time to play)....   :-P - I think that the master of master John Uhden did something like this.... it may still be available on his web site...
« Reply #13 on: October 11, 2006, 05:52:30 PM »
Alan,
 I have code I might be able to use to do it this way, I was just hoping that it was stored somewhere in the system, and could be retrived easly.  Doesn't look like it.
Luis,
  I didn't see anything on his side cadlantic.com.
LE
« Reply #14 on: October 11, 2006, 06:12:11 PM »
Can't find the code... but found a partial output from something he wrote (I remember seeing the code - man the age  :oops:)
http://discussion.autodesk.com/thread.jspa?messageID=2129722
