Author Topic: Code request  (Read 6549 times)
Matersammichman
Code request
« on: October 10, 2006, 11:46:24 AM »
I'm looking for code that I can use to list all of the Images contained in a dwg file. Suggestions?
Maverick®
Re: Code request
« Reply #1 on: October 10, 2006, 11:55:45 AM »
Suggestion #1   :wink:  :-)
What is a good way to get started on writing code to list images in a dwg.?
Re: Code request
« Reply #2 on: October 10, 2006, 12:03:49 PM »
Look for the 'ACAD_IMAGE_DICT' (dictionary) in the drawing, and then step through it for all the images.
Fatty
Re: Code request
« Reply #3 on: October 11, 2006, 04:19:12 AM »
Is there what you looking for?
Option Explicit
Sub GetImages()
Dim objDict As AcadDictionary
Set objDict = ThisDrawing.Dictionaries("ACAD_IMAGE_DICT")
If objDict.Count < 0 Then
MsgBox "No images definitions in this database."
Else
MsgBox "There are " & objDict.Count & "images definitions"
Dim oSset As AcadSelectionSet
Dim ftype(0) As Integer
Dim fdata(0) As Variant
Dim dxfcode As Variant
Dim dxfdata As Variant
ftype(0) = 0: fdata(0) = "IMAGE"
dxfcode = ftype
dxfdata = fdata
For Each oSset In ThisDrawing.SelectionSets
If oSset.Name = "$IMAGESET$" Then
Exit For
End If
Next oSset
If oSset Is Nothing Then
Set oSset = ThisDrawing.SelectionSets.Add("$IMAGESET$")
Else
oSset.Clear
End If
oSset.Select acSelectionSetAll, , , dxfcode, dxfdata
If oSset.Count > 0 Then
Dim oEntity As AcadEntity
Dim objImage As AcadRasterImage
Dim tmpArr(1) As Variant
Dim imageColl As New Collection
For Each oEntity In oSset
Set objImage = oEntity
tmpArr(0) = objImage.Name
Debug.Print tmpArr(0)
tmpArr(1) = objImage.ImageFile
Debug.Print tmpArr(1)
imageColl.Add tmpArr
Erase tmpArr
Next
Else
MsgBox "No images inserted."
End If
End If
oSset.Delete
Set oSset = Nothing
End Sub
Fatty
~'J'~
Matersammichman
Re: Code request
« Reply #4 on: October 11, 2006, 08:40:59 AM »
Thanks for the coding help.
I tried your code and it choked on:
Why is it doing this?
Bryco
Re: Code request
« Reply #5 on: October 11, 2006, 10:15:50 AM »
 Try something like below, a dictionary is a bit funky as it can also be an xrecord so typeof is a good way to get it straight
 Dim oDics As AcadDictionaries
    Dim oDic As AcadDictionary
    Dim oD
    Set oDics = ThisDrawing.Dictionaries
    For Each oD In oDics
        If TypeOf oD Is AcadDictionary Then
            If oD.Name = "ACAD_IMAGE_DICT" Then
                Set oDic = oD
Matersammichman
Re: Code request
« Reply #6 on: October 11, 2006, 10:43:14 AM »
Thanks for all the input, but I've decided to just use a Diesel expression in Fields. It's much simpler.
Fatty
Re: Code request
« Reply #7 on: October 11, 2006, 12:55:25 PM »
    Dim oD
                Set oDic = oD
Hi, Bryco
Nice one, as always
You beat me, thanks :)
Fatty
~'J'~
Re: Code request
« Reply #8 on: October 11, 2006, 01:08:45 PM »
The problem may be that the dictionary isn't in the drawing, so images are in the drawing.  I know this is a problem in lisp, I don't know/use VBA that is why I didn't post any code, just an idea.  In lisp you would catch the error to see if it is there.
Bryco
Re: Code request
« Reply #9 on: October 11, 2006, 11:16:26 PM »
I use it in a purge sub that lists all the unloaded images with the choice to delete them. I find it very handy and the vba does it fine.
Matersammichman
Re: Code request
« Reply #10 on: October 18, 2006, 07:26:41 AM »
Bryco,
Could I obtain a copy of that LISP routine...pleeeeze?
David Hall
  • Automatic Duh Generator
Re: Code request
« Reply #11 on: October 18, 2006, 09:19:00 AM »
I think Bryco's solution is VBA not lisp
Matersammichman
Re: Code request
« Reply #12 on: October 18, 2006, 09:21:12 AM »
VBA would work even better!
Bryco
Re: Code request
« Reply #13 on: October 18, 2006, 04:55:55 PM »
Matersammichman, I think this covers it.
Private Sub DeleteUnloadedImages()
    On Error GoTo Err_Control
    Dim oD, Imagedef
    Dim i As Integer, sImageName As String
    Dim oImage As AcadRasterImage
    Dim SS As AcadSelectionSet
    Dim Answer As Integer, strPrompt As String
    Dim isThere As Boolean
    Dim obj(0) As AcadEntity
                Set oDic = oD
                Set SS = sset(0, "Image")
                For Each Imagedef In oDic
                    sImageName = oDic.GetName(Imagedef)
                     Debug.Print sImageName, vbAssoc(Imagedef, 280)
                    If vbAssoc(Imagedef, 280) = 0 Then
                        strPrompt = "The image: """ & sImageName & """ is unloaded" & vbCrLf & "Choose Yes to delete"
                        Answer = MsgBox(strPrompt, vbYesNo, "Unloaded Image Files")
                        If Answer = vbYes Then
                            Imagedef.Delete
                        End If
                    Else
                        isThere = False
                        If SS.count > 0 Then
                            For Each oImage In SS
                                  If oImage.Name = sImageName Then
                                      isThere = True
                                      Exit For
                                  End If
Nextimage:
                            Next oImage
                            If Not isThere Then
                            Dim bl As Boolean
                            bl = IsNestedImage(sImageName)
                             Debug.Print sImageName, bl
                                If Not IsNestedImage(sImageName) Then
                                    strPrompt = "The image: """ & sImageName _
                                            & """ is unreferenced" & vbCrLf & "Choose Yes to delete"
                                    Answer = MsgBox(strPrompt, vbYesNo, "Unreferenced Image Files")
                                        Imagedef.Delete
                                    End If
                                End If
                            End If
                        End If
                        'SS.Delete
                    End If
                Next Imagedef
                SS.Delete
                Exit For
            End If
        End If
    Next oD
Exit_Here:
    Exit Sub
Err_Control:
    Select Case Err.Number
        Case -2145386476  'Key not found
            Set obj(0) = oImage
            SS.RemoveItems obj
            oImage.Delete
            Err.Clear
            GoTo Nextimage
    'Add your Case selections here
        Case Else
        'MsgBox Err.Description
        Debug.Print Err.Number, Err.Description
        Err.Clear
        Resume Exit_Here
    End Select
End Sub
and a function
Public Function sset(FilterType, FilterData As Variant, Optional ssName As String = "SS") As AcadSelectionSet
    Dim oSSets As AcadSelectionSets
    Set oSSets = ThisDrawing.SelectionSets
    For Each sset In oSSets
        If sset.Name = ssName Then
            sset.Delete
            Exit For
        End If
    Next
    Dim FType() As Integer
    Dim FData() As Variant
    Dim i As Integer
    If IsArray(FilterType) = False Then
        If IsArray(FilterData) = False Then
            ReDim FType(0)
            ReDim FData(0)
            FType(0) = FilterType
            FData(0) = FilterData
        Else
            Exit Function
        End If
    Else
        If UBound(FilterType) <> UBound(FilterData) Then
            Exit Function 'They must be pairs
        End If
        ReDim FType(UBound(FilterType))
        ReDim FData(UBound(FilterType))
        For i = 0 To UBound(FilterType)
            FType(i) = FilterType(i)
            FData(i) = FilterData(i)
        Next
    End If
    Set sset = ThisDrawing.SelectionSets.Add(ssName)
    sset.Select 5, FilterType:=FType, FilterData:=FData
    'To use this function for single filter
    'Set SS = SSet(0, "insert")
    'For multiple filter
    'Set SS = SSet(array(0,2),array("insert",oBlock.name)) 'must be pairs
End Function
Matersammichman
Re: Code request
« Reply #14 on: October 18, 2006, 05:18:09 PM »
??? It choked on vbAssoc. :lol:
