Author Topic: Teaching Tracey - Creating layers  (Read 28827 times)
jonesy
  • SuperMod
« on: October 10, 2006, 05:11:39 AM »
The colours, layers and linetypes dictated by our clients are currently set up in template files that we use to start new drawings.  Some of our users purge their drawings before they are complete, therefore losing all of the unused layer, colour and linetype settings.
I would like to write a lisp routine to set all of this up and reload the layers that have been purged.
Is there anyone out there who would be willing to help me with this project, by guiding me?
I have very little knowledge in lisp, but am more than willing to learn.
Thanks in advance
Tracey
Re: Teaching Tracey - Creating layers
« Reply #1 on: October 10, 2006, 05:43:48 AM »
Tracey, Have you tried inserting your template drawing (exploded) into the target drawing ??
// kwb
kdub in one timeline.
--> Donate to theSwamp<-
jonesy
  • SuperMod
« Reply #2 on: October 10, 2006, 06:10:30 AM »
Thanks for your reply Kerry
We have used this method for the past year, sometimes successfully, othertimes not.
Sometimes other users then forget to take the tick out of the "explode" box and many more blocks get inserted already exploded. Sometimes I dont catch these until I audit the drawings.
I was hoping to find an alternative.
« Reply #3 on: October 10, 2006, 06:15:28 AM »
OK, Try this ..
you'll just need to modify the Layer definitions ..
;; // TRACEY_Layers.lsp
;; // last edit kwb : 20061010
;; (c:Tracey_LAYERS)
(DEFUN c:tracey_layers (/            lintypefile  layerdata
                        onewlayer    ltname
                        *error*      _assertitem
  (DEFUN *error* (msg /)
    ;;----- Cancel any Active Commands -----------------------------
    (WHILE (< 0 (GETVAR "cmdactive")) (COMMAND))
    (VLA-SETVARIABLE kg:iacaddocument "menuecho" 1)
    (VLA-ENDUNDOMARK kg:iacaddocument)
    ;;----- Display error message if applicable _-------------------
    (COND
      ((NOT msg))                                                ; no error, do nothing
      ((VL-POSITION
         (STRCASE msg T)                                         ; cancel
         '("console break" "function cancelled" "quit / exit abort")
      ((PRINC (STRCAT "\nApplication Error: "
                      (ITOA (GETVAR "errno"))   ;; <-- edited kwb
                      msg
       (VL-BT)
    (PRINC)
  (DEFUN _assertitem (collection item / returnvalue)
    (IF (NOT (VL-CATCH-ALL-ERROR-P
               (SETQ
                 returnvalue (VL-CATCH-ALL-APPLY 'VLA-ITEM
                                                 (LIST collection item)
      returnvalue
  (SETQ kg:iacadapplication (VLAX-GET-ACAD-OBJECT)
        kg:iacaddocument    (VLA-GET-ACTIVEDOCUMENT kg:iacadapplication)
        kg:iacadlayers      (VLA-GET-LAYERS kg:iacaddocument)
        kg:iacadlinetypes   (VLA-GET-LINETYPES kg:iacaddocument)
  (VLA-ENDUNDOMARK kg:iacaddocument)                             ; end any open undo group
  (VLA-STARTUNDOMARK kg:iacaddocument)                           ; start new group
  (SETQ g:layerslist
         (LIST
           (LIST "ST90"                                          ;LayerName
                 "CONTINUOUS"                                    ;LineType
                 "Outlines 0.90mm"                               ;Description
                 ACBLUE                                          ;Color
           (LIST "ST70"
                 "CONTINUOUS"
                 "Outlines 0.70mm"
                 ACGREEN
           (LIST "ST50"
                 "CONTINUOUS"
                 "Outlines 0.50mm"
                 ACMAGENTA
           (LIST "ST35"
                 "CONTINUOUS"
                 "Outlines 0.35mm"
                 ACYELLOW
           (LIST "ST25" "CONTINUOUS" "Outlines 0.25mm" ACRED)
           (LIST "ST18" "CONTINUOUS" "Outlines 0.18mm" ACCYAN)
           (LIST "ST00" "CONTINUOUS" "Outlines Mixed" 8)
           (LIST "STC18"
                 "CENTER2"
                 "Center Lines Short 0.18mm"
                 ACCYAN
           (LIST "STC20"
                 "CENTER"
                 "Center Lines Medium 0.25mm"
                 ACRED
           (LIST "STC25"
                 "CENTERX2"
                 "Center Lines Long 0.25mm"
                 ACRED
           (LIST "STH18"
                 "HIDDEN2"
                 "Hidden Lines Short 0.18mm"
                 ACCYAN
           (LIST "STH20"
                 "HIDDEN"
                 "Hidden Lines Medium 0.25mm"
                 ACRED
           (LIST "STH25"
                 "HIDDENX2"
                 "Hidden Lines Long 0.25mm"
                 ACRED
           (LIST "STH30"
                 "DASHEDX2"
                 "Dashed Lines Long 0.25mm"
                 ACRED
           ;; text layers
           (LIST "STT90" "CONTINUOUS" "Text 0.90mm" ACBLUE)
           (LIST "STT70" "CONTINUOUS" "Text 0.70mm" ACGREEN)
           (LIST "STT50" "CONTINUOUS" "Text 0.50mm" ACMAGENTA)
           (LIST "STT35" "CONTINUOUS" "Text 0.35mm" ACYELLOW)
           (LIST "STT25" "CONTINUOUS" "Text 0.25mm" ACRED)
           (LIST "STT18" "CONTINUOUS" "Text 0.18mm" ACCYAN)
  (SETQ lintypefile (IF (= 1 (GETVAR "Measurement"))
                      (FINDFILE "acadiso.lin")
                      (FINDFILE "acad.lin")
  ;; (setq layerdata (car g:layerslist))
  (FOREACH layerdata g:layerslist
    (SETQ onewlayer (VLA-ADD kg:iacadlayers (CAR layerdata))
          ltname    (CADR layerdata)
    (IF (NOT (_assertitem kg:iacadlinetypes ltname))
      (VLA-LOAD kg:iacadlinetypes ltname lintypefile)
    (VLA-PUT-LINETYPE onewlayer ltname)
    (VLA-PUT-DESCRIPTION onewlayer (CADDR layerdata))
    (VLA-PUT-COLOR onewlayer (LAST layerdata))
  (PRINC)
  (PRINC)
edit : *error* routine modified <
« Last Edit: October 10, 2006, 06:24:59 AM by Kerry Brown »
« Reply #4 on: October 10, 2006, 06:16:51 AM »
 ... each of these defines a layer ..
                 ACBLUE                                          ;Color
jonesy
  • SuperMod
« Reply #5 on: October 10, 2006, 07:18:12 AM »
Thanks Kerry...
I'll look at that this afternoon
LE
« Reply #6 on: October 10, 2006, 09:36:24 AM »
Hola Tracey;
This is what I use, super basic:
(acad-push-dbmod)
;; basic layers
(setvar "cmdecho" 0)
(setq layer (getvar "clayer"))
(if (not (tblsearch "layer" "1"))
  (command "_.layer" "_m" "1" "_c" "1" "" ""))
(if (not (tblsearch "layer" "2"))
  (command "_.layer" "_m" "2" "_c" "2" "" ""))
(if (not (tblsearch "layer" "3"))
  (command "_.layer" "_m" "3" "_c" "3" "" ""))
(if (not (tblsearch "layer" "4"))
  (command "_.layer" "_m" "4" "_c" "4" "" ""))
(if (not (tblsearch "layer" "5"))
  (command "_.layer" "_m" "5" "_c" "5" "" ""))
(if (not (tblsearch "layer" "6"))
  (command "_.layer" "_m" "6" "_c" "6" "" ""))
(if (not (tblsearch "layer" "7"))
  (command "_.layer" "_m" "7" "_c" "7" "" ""))
(if (not (tblsearch "layer" "11"))
  (command "_.layer" "_m" "11" "_c" "11" "" ""))
(if (not (tblsearch "layer" "A-DIM"))
  (command "_.layer" "_m" "A-DIM" "_c" "4" "" ""))
(if (not (tblsearch "layer" "A-TEXT"))
  (command "_.layer" "_m" "A-TEXT" "_c" "4" "" ""))
(if (not (tblsearch "layer" "CENTER"))
  (command "_.layer" "_m" "CENTER" "_c" "5" "" "_l" "CENTER" "" ""))
(if (not (tblsearch "layer" "HIDDEN"))
  (command "_.layer" "_m" "HIDDEN" "_c" "5" "" "_l" "HIDDEN" "" ""))
(if (not (tblsearch "layer" "XR_BASE"))
  (command "_.layer" "_m" "XR_BASE" "_c" "7" "" ""))
(if (not (tblsearch "layer" "XR_TITLEBLOCK"))
  (command "_.layer" "_m" "XR_TITLEBLOCK" "_c" "7" "" ""))
(if (not (tblsearch "layer" "VIEWPORT"))
  (command "_.layer" "_m" "VIEWPORT" "_c" "1" "" "_p" "_n" "" ""))
(if layer
  (setvar "clayer" layer))
(setq layer nil)
(setvar "cmdecho" 1)
(acad-pop-dbmod)
jonesy
  • SuperMod
« Reply #7 on: October 10, 2006, 09:50:40 AM »
Thanks LE.
I'll look at that one too.
Can I ask a quick question?
What is (acad-push-dbmod) and (acad-pop-dbmod)
Tracey
« Reply #8 on: October 10, 2006, 10:01:35 AM »
Since the standard has already been defined in a template drawing why not use object dbx to read said drawing's layer structure then (intelligently) recreate it n the current document?
LE
« Reply #9 on: October 10, 2006, 10:02:31 AM »
Those two functions can be use to make a modifications to a drawing and then restored to the original status.
Go to the autocad help and type DBMOD system variable - or type the function's name on the search tab.
For example, I load the lisp code into a new drawing (started from scratch or any other existing one), the lisp does some modifications... but then I make a decision to simple close the drawing.... Those previous modifications will be ignored and it won't show the dialog message of asking to saved changes....
HTH.
jbuzbee
« Reply #10 on: October 10, 2006, 10:02:50 AM »
Another approach:
Create a block that has line segments, circles, or other simple object for each (and on that) layer.  Insert it into the drawing and use the following to make the block reference invisible:
(defun c:jbPutInvisible  (/ ent)
  (setq ent (entsel))
  (if ent
    (vla-put-Visible (vlax-ename->vla-object (car ent)) :vlax-false)))
(defun c:jbPutAllVisible  (/)
  (vlax-for b (vla-get-blocks(vla-get-ActiveDocument(vlax-get-acad-object)))
    (vlax-for x b
    (if (vlax-property-available-p x 'visible T)
    (vla-put-Visible x :vlax-true)))))
Now the block reference can't be erased so the block,  and included layers, can't be purged.  Include any other object table data in the same way: other blocks, textstyles, dimstyles, etc.
Just a thought,
jb
James Buzbee
Windows 8
jonesy
  • SuperMod
« Reply #11 on: October 10, 2006, 10:05:13 AM »
Would that be very difficult (for a newbie like me to be able to follow and learn from)
LE
« Reply #12 on: October 10, 2006, 10:11:00 AM »
That's why I am posting something that uses the command approach, so you can start by implementing something simple... Then in the future, you can do complex coding if necessary.
(if (not (tblsearch "layer" "1")) ;; see if the layer name exist.
  (command "_.layer" "_m" "1" "_c" "1" "" "")) ;; is not there - make it.
(command "_.layer" "_m" "1" "_c" "1" "" "") ;; even you can use just this.
Again, became comfortable with the lisp coding... and add new code lines... as you need them...
<edit> fixed code tags  Mav
« Last Edit: October 10, 2006, 10:14:53 AM by Maverick® »
« Reply #13 on: October 10, 2006, 10:29:00 AM »
While I totally think you could handle it (assuming the info were presented logically, methodically etc.) maybe smaller more bite sized pieces would be better right now; sorry.
« Reply #14 on: October 10, 2006, 11:21:09 AM »
When ready I have one I can post.  Not very pretty, but I can clean it up pretty quickly, I think.  I would start with the other ways mentioned here.
Another way that hasn't been mentioned, is to use 'entmake' to make the layers.  I have never done this, but I know others have, and could show a better example.  Just giving more options.  :-D
