Author Topic: Examples of usage GRREAD - let's share  (Read 201023 times)
alanjt
  • Standby for witty remark...
Re: Examples of usage GRREAD - let's share
« Reply #120 on: March 14, 2011, 08:52:18 AM »
Excellent , Alan ! :-)
You have used the better method grdraw to show middle routine . I can learn a lot from your code
Enjoy. I had a bit of fun writing it.
Dropbox
GDF
« Reply #121 on: March 14, 2011, 03:16:32 PM »
Nice routine.
To activate the PW command grread function, I have to hit the space bar after selecting the polyline.
alanjt
« Reply #122 on: March 14, 2011, 03:19:46 PM »
Nice routine.
Thanks.
Yes, it allows for multiple LWPolyline selection, so you have to right-click/enter/spacebar after selecting all desired LWPolylines.
Dropbox
Pad
« Reply #123 on: March 15, 2011, 04:54:59 AM »
Thanks for the two leader arrow routines Alan.  Very useful.
alanjt
« Reply #124 on: March 15, 2011, 08:45:58 AM »
Enjoy.  :-)
Dropbox
alanjt
« Reply #125 on: March 30, 2011, 10:51:50 AM »
Similar to the new option to 2011 or being able to TAB through a list of ENames like one can TAB through different usable OSnaps in an area.
(defun AT:CycleThroughENames (lst / l n i g e)
  ;; Cycle through a list of ENames to choose one
  ;; lst - list of ENames
  ;; Alan J. Thompson, 03.29.11
  (if (>= (setq l (length lst)) 2)
      (princ "\n<Tab> to cycle through entities: ")
      (redraw (setq i (nth (setq n 0) lst)) 3)
      (while (progn (setq g (grread nil 10))
                    (cond ((equal g '(2 9))
                           (redraw i 4)
                           (redraw (setq i (nth (setq n (rem (1+ n) l)) lst)) 3)
                           T
                          ((or (member g '((2 32) (2 13))) (eq (car g) 25)) (redraw (setq e i) 4))
                          (T (redraw i 4))
      e
    (car lst)
EDIT: Minor change to follow a suggestion by Lee.
Test subroutines (and a quick sub to convert the selection set to a list):
(defun ss->lst (ss / i l)
  (if (eq (type ss) 'PICKSET)
    (repeat (setq i (sslength ss)) (setq l (cons (ssname ss (setq i (1- i))) l)))
(defun c:Test (/ ent)
  (if (setq ent (AT:CycleThroughENames (ss->lst (ssget))))
    (sssetfirst nil (ssadd ent))
(defun c:Test2 (/ pt ent)
  (if (and (setq pt (getpoint "\nSpecify point: "))
           (setq ent (AT:CycleThroughENames (ss->lst (ssget "_C" pt pt))))
« Last Edit: March 30, 2011, 12:07:52 PM by alanjt »
Dropbox
« Reply #126 on: March 30, 2011, 11:18:57 AM »
Nice one Alan :-) It reminds me of a snippet I posted here  :-)
Looking back at it, it could probably be shortened to just:
(defun c:msel ( / ss i l )
    (setq ss (ssget))
    (setq i -1 l (sslength ss))
    (princ "\nPress Tab to Cycle Through Selection <Exit>: ")
    (while (= 9 (cadr (grread nil 10))) (sssetfirst nil (ssadd (ssname ss (setq i (rem (1+ i) l))))))
« Last Edit: March 30, 2011, 11:27:26 AM by Lee Mac »
alanjt
« Reply #127 on: March 30, 2011, 11:58:00 AM »
(rem (1+ i) l)
Clever. :kewl: You've proved me useless.
Dropbox
« Reply #128 on: March 30, 2011, 12:19:50 PM »
(rem (1+ i) l)
Thanks Alan  8-)
alanjt
« Reply #129 on: March 30, 2011, 02:11:21 PM »
These would probably make more sense. I was getting caught up in worrying with it only returning an EName if the user right-clicked, hit enter or the spacebar, but that's kind of silly. If they selected the objects, they're bound to want to, regardless...
(defun AT:CycleThroughENames (lst / l i n)
    (progn (princ "\n<Tab> to cycle through entities: ")
           (while (eq (cadr (grread nil 10)) 9)
             (mapcar 'redraw (list i (setq i (nth (setq n (rem (1+ n) l)) lst))) '(4 3))
           (redraw i 4)
           i
    (car lst)
(defun AT:CycleThroughSS (ss / l i e)
    (if (eq (setq l (sslength ss)) 1)
      (ssname ss 0)
             (redraw (setq e (ssname ss (setq i 0))) 3)
               (mapcar 'redraw (list e (setq e (ssname ss (setq i (rem (1+ i) l))))) '(4 3))
             (redraw e 4)
             e
Thanks for the example to put my head on a little straighter, Lee.
Dropbox
« Reply #130 on: March 31, 2011, 07:33:44 AM »
Nice one Alan, you're welcome :-)
pBe
« Reply #131 on: March 31, 2011, 08:13:22 AM »
Question:
Can grread retrieve infos from a "gripped" object?
« Reply #132 on: March 31, 2011, 08:28:21 AM »
What 'infos' would you be looking to retrieve?
grread is simply a function to monitor user input.
alanjt
« Reply #133 on: March 31, 2011, 08:33:23 AM »
Question:
You can select the 'gripped' object with (ssget "_I") and extract info from there.
Dropbox
pBe
« Reply #134 on: March 31, 2011, 08:40:44 AM »
I understand, just wondering that's all  :-)
Thank you gentlemen
