Author Topic: Examples of usage GRREAD - let's share  (Read 200979 times)
Re: Examples of usage GRREAD - let's share
« Reply #30 on: December 18, 2009, 08:24:55 PM »
a description of what it's 'sposed to do would be handy.
... and that first prompt confuses me "\nPick Center of First Radius: "
Regards
Apologies Kerry, post updated.  :oops:
« Reply #31 on: December 18, 2009, 08:27:22 PM »
Regards
No apologies needed :)
... just thinking of those following who may not be able to grasp intent from the code.
xianaihua
« Reply #32 on: December 18, 2009, 08:56:17 PM »
Hi Lee Mac
nice work! :-D
I have a suggestion: You can enter a numeric value of the radius increased!
« Reply #33 on: December 18, 2009, 09:28:48 PM »
Hi Lee Mac
nice work! :-D
Thanks Xianaihua :-)
Yes, that seems to be the next logical improvement  8-)
« Reply #34 on: December 19, 2009, 01:17:38 PM »
Code updated to accept keyboard input.  :wink:
« Reply #35 on: December 19, 2009, 07:08:17 PM »
Regards
ahh yes ! a picture is worth a thousand words. !
xianaihua
« Reply #36 on: December 22, 2009, 05:49:35 AM »
;;;by:lihuili 2009-12-20
;;;Dynamic drawing a line to another line perpendicular bisector
(defun Perp_bisector_line (/   ent en      pt     enname
   p1   p2 ang ptemp1 p0     pt1
   sp   source ptemp ptemp1 ptemp2 ptemp3
   pt1   pt2 pt3 loop
  (setvar "cmdecho" 0)
  (if (and (setq ent (car (entsel "\n select a line.")))
   (= (cdr (assoc 0 (setq en (entget ent)))) "LINE")
      (redraw ent 3)
      (setq p1 (trans (cdr (assoc 10 en)) 0 1)
    p2 (trans (cdr (assoc 11 en)) 0 1)
    ang (angle p1 p2)
      (setq p0     (polar p1 ang (* 0.5 (distance p1 p2)))
    lineobj (vla-addLine
      (vla-get-ModelSpace
      (vlax-3d-point p0)
      (vlax-3d-point p0)
      (setq ptemp1 (polar p0 (+ ang (* 0.5 pi)) 10))
      (prompt "\n to:")
      (setq loop t
    ptemp p0
    pt1 p0
      (while loop
(setq sp (grread t))
(setq source (car sp)
      sp     (cadr sp)
(cond ((= source 5)
       (setq ptemp sp)
       (setq ptemp2 (polar sp 0 10)
     ptemp3 (polar sp (* 0.5 pi) 10)
       (setq pt2 (inters p0 ptemp1 sp ptemp2 nil))
       (setq pt3 (inters p0 ptemp1 sp ptemp3 nil))
       (cond ((null pt2) (setq pt1 pt3))
     ((null pt3) (setq pt1 pt2))
     (t
      (if (< (distance sp pt2) (distance sp pt3))
(setq pt1 pt2)
(setq pt1 pt3)
       (vla-put-EndPoint lineobj (vlax-3d-point pt1))
      (t (setq loop nil))
      (redraw ent 4)
    (prompt "\n No select a line!")
(defun c:test ()
  (Perp_bisector_line)
Fred Tomke
  • [ Mr. Bad Guy ]
« Reply #37 on: December 22, 2009, 06:18:49 AM »
Hi, I neither want to disturb nor to annoy but I'd prefer to rotate the crosshair while dragging perpendicular (see attached gif).
Fred
Fred Tomke
Dipl.-Ing. (FH) Landespflege
[ landscaper - landscape developer - digital landscape and urban design]
alanjt
  • Standby for witty remark...
« Reply #38 on: December 22, 2009, 10:05:57 AM »
Hey xianaihua, I did something similar to that...
;;; Draw perpendicular line
;;; Alan J. Thompson, 10.15.09
(defun c:LPer (/ #Ent #Read)
    (setq #Ent (car (entsel "\nSelect curve: ")))
    (vl-position (cdr (assoc 0 (entget #Ent))) '("LWPOLYLINE" "ARC" "LINE" "CIRCLE" "ELLIPSE"))
    (while (not (eq 25 (car (setq #Read (grread T 15 0)))))
      (princ "\rSpecify point for line: ")
      (redraw)
      (if (vl-consp (cadr #Read))
        (grdraw (vlax-curve-getclosestpointto #Ent (trans (cadr #Read) 1 0) T)
                1
        ) ;_ grdraw
      ) ;_ if
      (if (eq 3 (car #Read))
        (entmake (list '(0 . "LINE")
                       (cons 10 (vlax-curve-getclosestpointto #Ent (trans (cadr #Read) 1 0) T))
                       (cons 11 (trans (cadr #Read) 1 0))
                 ) ;_ list
        ) ;_ entmake
      ) ;_ if
    ) ;_ while
  ) ;_ and
  (redraw)
) ;_ defun
« Last Edit: December 22, 2009, 10:09:54 AM by alanjt »
Dropbox
xianaihua
« Reply #39 on: December 22, 2009, 11:14:48 AM »
Hi,alanjt
nice work!
Your program can add to the block processing,In other words, be able to select block.
alanjt
« Reply #40 on: December 22, 2009, 12:30:45 PM »
Hi,alanjt
nice work!
:) Thanks
No, the vlax-curve... functions don't work on blocks.
Dropbox
rkmcswain
« Reply #41 on: December 22, 2009, 01:24:23 PM »
Don't flame me too bad... I know, no code, but here is a animation of what it does....
dgorsman
« Reply #42 on: December 22, 2009, 01:33:08 PM »
Ooooh....   :kewl:
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
alanjt
« Reply #43 on: December 22, 2009, 01:42:58 PM »
I posted this one in another thread....
http://www.theswamp.org/index.php?topic=30660.0
Dropbox
alanjt
« Reply #44 on: December 22, 2009, 01:43:59 PM »
Very cool!
Dropbox
