Author Topic: Examples of usage GRREAD - let's share  (Read 201199 times)
Re: Examples of usage GRREAD - let's share
« Reply #60 on: December 24, 2009, 10:32:20 AM »
alanjt
  • Standby for witty remark...
« Reply #61 on: December 24, 2009, 11:31:54 AM »
Here's a real simple one I did, modeled after a thread here. It's nice because it allows me to have the last typed in input available for the next time I create a text object. It's real simple.
;;; Quick Text
;;; Required Subroutines: AT:Mtext AT:Getstring
;;; Alan J. Thompson, 09.23.09
(defun c:QT (/ #Point1 #Point2 #String #Text #Final)
  (or QT:Default (setq QT:Default ""))
  (and (setq #String (AT:Getstring "Specify text string: " QT:Default))
       (not (eq #String ""))
       (setq QT:Default (strcase #String))
       (setq #Point1 (getpoint "\nSpecify placement point: "))
       (or (setq
             #Point2 (getpoint #Point1 "\nSpecify next point for angle <Zero>: ")
           ) ;_ setq
           (setq #Point2 #Point1)
       ) ;_ or
       (setq #Text (AT:Mtext #Point1 QT:Default 0 nil 5))
       (not (vla-put-rotation #Text (angle #Point1 #Point2)))
       (while (eq 5 (car (setq #Final (grread T 4 4))))
         (vla-put-insertionpoint #Text (vlax-3d-point (trans (cadr #Final) 1 0)))
       ) ;_ while
  ) ;_ and
) ;_ defun
You would need these two subroutines:
;;; Add MText to drawing
;;; #InsertionPoint - MText insertion point
;;; #String - String to place in created MText object
;;; #Width - Width of MText object (if nil, will be 0 width)
;;; #Layer - Layer to place Mtext object on (nil for current)
;;; #Justification - Justification # for Mtext object
;;;      1 or nil= TopLeft
;;;      2= TopCenter
;;;      3= TopRight
;;;      4= MiddleLeft
;;;      5= MiddleCenter
;;;      6= MiddleRight
;;;      7= BottomLeft
;;;      8= BottomCenter
;;;      9= BottomRight
;;; Alan J. Thompson, 05.23.09
(defun AT:MText (#InsertionPoint #String #Width #Layer #Justification / #Width
                 #Space #Insertion #Object
  (or #Width (setq #Width 0))
  (or *AcadDoc*
      (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))
  ) ;_ or
  (setq #Space     (if (or (eq acmodelspace
                               (vla-get-activespace *AcadDoc*)
                           ) ;_ eq
                           (eq :vlax-true (vla-get-mspace *AcadDoc*))
                       ) ;_ or
                     (vla-get-modelspace *AcadDoc*)
                     (vla-get-paperspace *AcadDoc*)
                   ) ;_ if
        #Insertion (cond
                     ((vl-consp #InsertionPoint) (vlax-3d-point #InsertionPoint))
                     ((eq (type #InsertionPoint) 'variant) #InsertionPoint)
                     (T nil)
                   ) ;_ cond
  ) ;_ setq
  ;; create MText object
  (setq #Object (vla-addmtext #Space #Insertion #Width #String))
  ;; change layer, if applicable
  (and #Layer
       (tblsearch "layer" #Layer)
       (vla-put-layer #Object #Layer)
  ) ;_ and
  ;; change justification & match insertion point with new justification
  (cond ((member #Justification (list 1 2 3 4 5 6 7 8 9))
         (vla-put-attachmentpoint #Object #Justification)
         (vla-move #Object
                   (vla-get-InsertionPoint #Object)
                   #Insertion
         ) ;_ vla-move
  ) ;_ cond
  #Object
) ;_ defun
;;; Getstring Dialog Box
;;; #Title - Title of dialog box
;;; #Default - Default string within edit box
;;; Alan J. Thompson, 08.25.09
(defun AT:GetString
       (#Title #Default / #FileName #FileOpen #DclID #NewString)
  (setq #FileName (vl-filename-mktemp "" "" ".dcl")
        #FileOpen (open #FileName "W")
  ) ;_ setq
  (foreach x '("TempEditBox : dialog {" "key = \"Title\";"
               "label = \"\";" "initial_focus = \"Edit\";" "spacer;"
               ": row {" ": column {" "alignment = centered;"
               "fixed_width = true;" ": text {" "label = \"\";" "}" "}"
               ": edit_box {" "key = \"Edit\";" "allow_accept = true;"
               "edit_width = 40;" "fixed_width = true;" "}" "}"
               "spacer;" ": row {" "fixed_width = true;"
               "alignment = centered;" ": ok_button {" "width = 11;" "}"
               ": cancel_button {" "width = 11;" "}" "}" "}//"
    (write-line x #FileOpen)
  ) ;_ foreach
  (close #FileOpen)
  (setq #DclID (load_dialog #FileName))
  (new_dialog "TempEditBox" #DclID)
  (set_tile "Title" #Title)
  (set_tile "Edit" #Default)
  (action_tile
    "accept"
    "(setq #NewString (get_tile \"Edit\"))(done_dialog)"
  ) ;_ action_tile
  (action_tile "cancel" "(done_dialog)")
  (start_dialog)
  (unload_dialog #DclID)
  (vl-file-delete #FileName)
  #NewString
) ;_ defun
« Last Edit: December 24, 2009, 12:25:02 PM by alanjt »
Dropbox
xianaihua
« Reply #62 on: December 24, 2009, 11:39:06 AM »
hi!alanjt
nice work!
Learn from you!
alanjt
« Reply #63 on: December 24, 2009, 11:56:53 AM »
hi!alanjt
nice work!
Learn from you!
Thanks :) but there are much much more qualified people here than me.
Dropbox
GDF
« Reply #64 on: December 24, 2009, 12:20:42 PM »
hi!alanjt
nice work!
Learn from you!
Very nice routine. I added this gem to my library. Thanks for sharing it.
alanjt
« Reply #65 on: December 24, 2009, 12:23:15 PM »
Thanks and you're welcome. :)
hi!alanjt
nice work!
Learn from you!
Dropbox
alanjt
« Reply #66 on: December 24, 2009, 12:26:57 PM »
Copy the main routine again. I updated how the text is moved around with grread per something Lee had pointed out a while back (wrote it before that).
hi!alanjt
nice work!
Learn from you!
Dropbox
alanjt
« Reply #67 on: December 24, 2009, 12:30:58 PM »
Just playing around, learning how to use grread.
;;; Magic Eraser (erase anything cursor crosses)
;;; Alan J. Thompson, 10.15.09
(defun c:EE (/ #Read #Ent)
  (while (eq 5 (car (setq #Read (grread t 15 2))))
    (princ "\rMove cursor over object to erase: ")
    (if (setq #Ent (ssget (cadr #Read)))
      (vl-catch-all-apply 'entdel (list (ssname #Ent 0)))
    ) ;_ if
  ) ;_ while
) ;_ defun
Dropbox
alanjt
« Reply #68 on: December 24, 2009, 12:32:18 PM »
This has NO practical application, it was just more of my playing around with grread (learning).
;;; Dynamic Distance (distance displayed from picked base point)
;;; Alan J. Thompson, 11.09.09
(defun c:DyD (/ *error* #Pnt #Obj #Read #Dist)
  (setq *error* (lambda (x)
                  (and #Obj (vl-catch-all-apply 'vla-delete (list #Obj)))
                  (grtext)
                  (redraw)
                ) ;_ lambda
  ) ;_ setq
  (and (setq #Pnt (getpoint "\nSpecify base point: "))
       (setq #Obj (vlax-ename->vla-object
                    (entmakex (list '(0 . "CIRCLE")
                                    '(100 . "AcDbEntity")
                                    '(100 . "AcDbCircle")
                                    '(62 . 1)
                                    '(6 . "Continuous")
                                    '(40 . 1.0)
                                    (cons 10 (trans #Pnt 1 0))
                              ) ;_ list
                    ) ;_ entmakex
                  ) ;_ vlax-ename->vla-object
       ) ;_ setq
       (while (eq 5 (car (setq #Read (grread T 15 0))))
         (redraw)
         (grdraw #Pnt (cadr #Read) 1 1)
         (vl-catch-all-apply 'vla-put-radius (list #Obj (distance #Pnt (cadr #Read))))
         (setq #Dist (strcat "Distance: " (rtos (distance #Pnt (cadr #Read)))))
         (princ (strcat "\r" #Dist "          "))
         (grtext -1 #Dist)
       ) ;_ while
  ) ;_ and
  (*error* nil)
) ;_ defun
Dropbox
alanjt
« Reply #69 on: December 24, 2009, 12:34:43 PM »
Last one.
I did this one as a request (ended up not being what they wanted) and just got a little carried away.
;;; Place current drawing's directory contents (matching *.dwg) in MText
;;; Required Subroutines: AT:MText
;;; Alan J. Thompson, 10.28.09
(defun c:Dir2Text (/ AT:NumFix #Pnt1 #List #Pos #String #Text #Read)
  (defun AT:NumFix (#Num #Length / #Str)
    (setq #Str (vl-princ-to-string #Num))
    (while (and (<= (1+ (strlen #Str)) #Length) (< (strlen #Str) 16))
      (setq #Str (strcat "0" #Str))
    ) ;_ while
    #Str
  ) ;_ defun
    ((setq #Pnt1 (getpoint "\nSpecify first corner: "))
     (setq #List   (vl-sort (vl-remove-if-not
                              '(lambda (x) (wcmatch x "*.dwg"))
                              (vl-directory-files (getvar 'dwgprefix))
                            ) ;_ vl-remove-if-not
                   ) ;_ vl-sort
           #String ""
     ) ;_ setq
     (foreach x #List
       (setq #Pos (AT:NumFix (1+ (vl-position x #List)) (length #List)))
       (setq #String (strcat #String #Pos " - " (vl-filename-base x) "\\P"))
     ) ;_ foreach
     (setq #Text (AT:MText #Pnt1 #String 0 nil 1))
     (while (eq 5 (car (setq #Read (grread T 15 2))))
       (redraw)
       (grvecs (list 7
                     #Pnt1
                     (list (car (cadr #Read)) (cadr #Pnt1))
                     (cadr #Read)
                     (cadr #Read)
                     (list (car #Pnt1) (cadr (cadr #Read)))
                     #Pnt1
               ) ;_ list
       ) ;_ grvecs
       (vla-put-width #Text (abs (- (car #Pnt1) (car (cadr #Read)))))
     ) ;_ while
  ) ;_ cond
  (redraw)
) ;_ defun
You'll need the AT:MText subroutine (posted above).
http://www.theswamp.org/index.php?topic=12813.msg369811#msg369811
Dropbox
xianaihua
« Reply #70 on: December 25, 2009, 12:02:03 AM »
Dear friends of the good works one after another eye-opener
« Reply #71 on: December 26, 2009, 07:45:55 AM »
Alan, you could always cheat with your GetString  :evil:
(defun LM:GetString (#Default / dcTag result)
  (cond (  (<= (setq dcTag (load_dialog "ACAD")) 0))
        (  (not (new_dialog "acad_txtedit" dcTag)))
        (t
           (set_tile "text_edit" #Default)
           (action_tile "accept" "(setq result (get_tile \"text_edit\")) (done_dialog)")
           (start_dialog)
           (unload_dialog dcTag)))
  result)
VovKa
  • Ukraine
« Reply #72 on: December 26, 2009, 09:37:16 AM »
Lee, i'm a cheater too :)
(lisped "edit me")
alanjt
« Reply #73 on: December 26, 2009, 11:54:31 AM »
True, maybe one of these days I'll actually learn DCL properly.
        (t
           (start_dialog)
  result)
Dropbox
« Reply #74 on: December 26, 2009, 12:34:14 PM »
Nah, its just using whats already there  :evil:
