Author Topic: Determining Even or Odd  (Read 7557 times)
Hangman
« on: October 06, 2006, 09:15:53 PM »
Hey guys, I'm in a bit of a pickle.  I'm about to get swamped (no pun intended   :?  ) with a "need it yesterday" type of project.  This thing will be an ongoing project for the next 6 months.  It's a nightmare, long story.  So I'm trying to put together a couple routines that will help me for the onslaught come Monday morning.
Is there a way to determine a real number be either Even or Odd without having to type in every single number from 1 to 50 ??
  (setq pt-dist_12 (distance pt1 pt2))
  (setq plate-ctr (/ pt-dist_12 3))
  (setq plate-ctr (fix plate-ctr))
    (cond  ( (  ... ;;If plate-ctr is Odd then do something ...
              ( (  ... ;;If plate-ctr is Even then do something else ...
Is there a possibility of that or do I need to do something like this ...
    (cond  ( (or (= plate-ctr 1) (= plate-ctr 3) (= plate-ctr 5) (= plate-ctr 7) (= plate-ctr 9)) ;; all the way to 49
                ( ...  do something here ... ))
              ( (or (= plate-ctr 2) (= plate-ctr 4) (= plate-ctr 6) (= plate-ctr 8)  (= plate-ctr 10)) ;; all the way to 50
Thank you for your thoughts & help.
Hangman  8)
Drafting Board, Mechanical Arm, KOH-I-NOOR 0.7mm
MickD
Re: Determining Even or Odd
« Reply #1 on: October 06, 2006, 09:22:59 PM »
is there a modulo operator in lisp??
if num%2 > 0 answer is odd. (where '%' = modulo operator)
- John Carmack
- J.R.R. Tolkien
MickD
« Reply #2 on: October 06, 2006, 09:33:24 PM »
lisp arithmetic function 'rem' looks like it should do the trick ;)
« Last Edit: October 06, 2006, 09:34:29 PM by MickD »
- John Carmack
- J.R.R. Tolkien
« Reply #3 on: October 06, 2006, 09:59:37 PM »
Another spin on the topic:
If the last number is a one, its odd. If its not, then its even.
1: 00000001
2: 00000010
3: 00000011
4: 00000100
« Reply #4 on: October 06, 2006, 10:05:55 PM »
(defun odd? (i)
  ;; odd?
  ;; Returns 0 if even and 1 if odd
   (logand i 1))
« Reply #5 on: October 06, 2006, 10:19:43 PM »
(defun IsEven ( x )
    (zerop (rem x 2))
(setq
    plate-ctr  (fix (/ pt-dist_12 3))
(if (IsEven plate-ctr)
    (DoStuffForEvenCondition)
    (DoStuffForOddCondition)
MickD
« Reply #6 on: October 06, 2006, 10:42:13 PM »
logand would be by far the quickest given the fact you don't need the remainder and division is a slow(er) operation for a cpu, another practical use for 0's and 1's :)
- John Carmack
- J.R.R. Tolkien
Hangman
« Reply #7 on: October 06, 2006, 11:15:42 PM »
Hey guys, thanks for the quick responses.  Looking over these, I'm think'n MickD is correct, I'd prefer to use the logand function.  I like the post Se7en posted,
(defun odd? (i)
  ;; odd?
   (logand i 1))
But I'm not understanding exactly how it's to work.  I've tried it with several different numbers, but it keeps coming back as Odd.  I don't think I'm working it properly and the examples in the help files don't give me much.  Could you guys post a couple examples for me. ??
Nice post MP, I like the way you did that.  Thanks for the input & help.
Hangman  8)
« Reply #8 on: October 06, 2006, 11:16:05 PM »
... but no practical speed difference is realized in lisp --
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (zerop (rem 1 2)) ............... 1438 / 1.01 <fastest>
    (zerop (logand 1 1)) ............ 1453 / 1.00 <slowest>
    (zerop (rem 255 2)) ............. 1437 / 1.01 <fastest>
    (zerop (logand 255 1)) .......... 1453 / 1.00 <slowest>
    (zerop (rem 65535 2)) ........... 1469 / 1.01 <fastest>
    (zerop (logand 65535 1)) ........ 1485 / 1.00 <slowest>
    (zerop (rem 1073741824 2)) ...... 1468 / 1.02 <fastest>
    (zerop (logand 1073741824 1)) ... 1500 / 1.00 <slowest>
MickD
« Reply #9 on: October 06, 2006, 11:33:14 PM »
layer upon layer upon layer.....
oh well, it was food for thought though. :)
in technical terms, rem/modulo returns the remainder from a division eg 12/10 = 2 and 12/2 = 0.
- John Carmack
- J.R.R. Tolkien
Hangman
« Reply #10 on: October 06, 2006, 11:45:06 PM »
Yeah, well, my head feels like it's going to burst into flames.
K, so, 'rem' might be faster.  I don't think a couple milliseconds is going to make too much of a difference here.  But I'm learn'n someth'n new.
I just found the Logand info  (couldn't find it online, had to revert to an old book written for release 12).
So, the code Se7en posted:
(defun odd? (i)
  ;; odd?
   (logand i 1))
The 'i', to my understanding, is the integer to be tested ?.
So, one would setq i to an integer, and the 'logand' would test i for an odd bitcode ?.
So I could set my code something like:
(setq
(setq Odd-Even (logand plate-ctr 1))
(if (= Odd-Even 0)
Hey look, it worked !!!  Too cool.  Thanks guys.
Hangman  8)
« Reply #11 on: October 06, 2006, 11:53:19 PM »
;; returns t of num is odd
(defun odd? (num)
   (= (logand num 1) 1)
(print (odd? 1))
(print (odd? 2))
(print (odd? 3))
(print (odd? 4))
;; returns t of num is even
(defun even? (num)
   (zerop (logand num 1))
(print (even? 1))
(print (even? 2))
(print (even? 3))
(print (even? 4))
« Reply #12 on: October 07, 2006, 02:07:01 AM »
<snip>
</snip>
Hey, wait a min. Well that scenario has got to be slower. Your pinning one boolean test up against two (Native mathematics is the fastest hands down so that can be negated from the test.).
If we pin my one Boole up against your math&Boole i bet i could do better then that.
« Reply #13 on: October 07, 2006, 02:09:02 AM »
<snip>
(defun even? (num)
</snip>
One question: Why have a test for both odd and even? ``If its not one...''
« Reply #14 on: October 07, 2006, 02:13:26 AM »
<snip>
</snip>
And returns true if and oly if both tests are true. In the case of `logand ... 1' we are testing to see if the first bit is a one in an int.  (Does that make sence?)
1 = 00000001
2 = 00000010
So
(logand 2 1) returns what?
