;; Grread+osnap+GRVECS
;; Rewritten by Fools @ TheSwamp.org
;; Use (grread) to get original point
;; Use (osnap) to calculate accurate point
;; Use (GRVECS) to show AutoSnapMarker
;; No return , just show the method
(DEFUN c:tmp (/ AUTOSNAPMARKERCOLOR AUTOSNAPMARKERSIZE
DRAG GHOSTPT LST_OSMODE STR_OSMODE TIME
DistPerPixel Bold Draftobj get_osmode STD-STRTOK
YPY_GetGrvecs YPY_DrawVecs
;; CAB 10/5/2006
;; Fools change a little about "," (3/3/2007)
;; Function to return the current osmode setting in the form of a string
;; If (getvar "osmode") = 175
;; (get_osmode) returns "_end,_mid,_cen,_nod,_int,_per"
(DEFUN get_osmode (/ cur_mode mode$)
(SETQ mode$ "")
(IF (< 0 (SETQ cur_mode (GETVAR "osmode")) 16383)
(MAPCAR (FUNCTION (LAMBDA (x)
(IF (NOT (ZEROP (LOGAND cur_mode (CAR x))))
(IF (ZEROP (STRLEN mode$))
(SETQ mode$ (CADR x))
(SETQ mode$ (STRCAT mode$ "," (CADR x)))
'((1 "_end")
(2 "_mid")
(4 "_cen")
(8 "_nod")
(16 "_qua")
(32 "_int")
(64 "_ins")
(128 "_per")
(256 "_tan")
(512 "_nea")
(1024 "_qui")
(2048 "_app")
(4096 "_ext")
(8192 "_par")
mode$
;; -------------------------------------------------------------------73
;; Tokenizers
;; These might be renamed to the long versions:
;; std-string-tokenize, std-string-split and std-string-join
;; Converts string with delimiters into string list
;; Ignore repeated delims such as white space.
;; The order of chars in delim is not important.
;; Might be renamed to std-string-tokenize
;; Also named lex-string in some Common Lisps.
;; (std-strtok " 2 3 " " ") => ("2" "3")
;; (std-strtok "f 1,3" ", ") => ("f" "1" "3")
;; Same as std-string->strlist
(DEFUN STD-STRTOK (s delims / len s1 i c lst)
(SETQ delims (VL-STRING->LIST delims)
len (STRLEN s)
s1 ""
i (1+ len)
(WHILE (> (SETQ i (1- i)) 0)
(SETQ c (SUBSTR s i 1))
(IF (MEMBER (ASCII c) delims)
(IF (/= s1 "") ; no null tokens
(SETQ lst (CONS s1 lst)
s1 ""
(SETQ s1 (STRCAT c s1))
(IF (/= s1 "")
(CONS s1 lst) ; no ("" "1" "2")!
lst
;;My functions
(DEFUN YPY_GetGrvecs (pt dragpt lst / KEY)
(SETQ key T)
(WHILE (AND key lst)
(IF (EQUAL (OSNAP dragpt (CAR lst)) pt 1E-6)
(SETQ key nil)
(SETQ lst (CDR lst))
(CDR (ASSOC (CAR lst)
'(("_end"
((-1 1) (-1 -1))
((-1 -1) (1 -1))
((1 -1) (1 1))
((1 1) (-1 1))
) ;square
("_mid"
((0 1.414) (-1.225 -0.707))
((-1.225 -0.707) (1.225 -0.707))
((1.225 -0.707) (0 1.414))
) ;triangle
("_cen"
((0 1) (-0.707 0.707))
((-0.707 0.707) (-1 0))
((-1 0) (-0.707 -0.707))
((-0.707 -0.707) (0 -1))
((0 -1) (0.707 -0.707))
((0.707 -0.707) (1 0))
((1 0) (0.707 0.707))
((0.707 0.707) (0 1))
) ;circle
("_nod"
((-1 1) (1 -1))
((-1 -1) (1 1))
) ;circle+cross
("_qua"
((0 1.414) (-1.414 0))
((-1.414 0) (0 -1.414))
((0 -1.414) (1.414 0))
((1.414 0) (0 1.414))
) ;square rotate 45
("_int"
((-1 1) (1 -1))
((-1 -1) (1 1))
((1 0.859) (-0.859 -1))
((-1 0.859) (0.859 -1))
((0.859 1) (-1 -0.859))
((-0.859 1) (1 -0.859))
) ;cross
("_ins"
((-1 1) (-1 -0.1))
((-1 -0.1) (0 -0.1))
((0 -0.1) (0 -1.0))
((0 -1.0) (1 -1))
((1 -1) (1 0.1))
((1 0.1) (0 0.1))
((0 0.1) (0 1.0))
((0 1.0) (-1 1))
) ;two squares
("_per"
((-1 1) (-1 -1))
((-1 -1) (1 -1))
((0 -1) (0 0))
((0 0) (-1 0))
) ;half square
("_tan"
((1 1) (-1 1))
) ;circle+line
("_nea"
((-1 1) (1 -1))
((1 -1) (-1 -1))
((-1 -1) (1 1))
((1 1) (-1 1))
) ;two triangle
("_qui") ; ???
("_app"
((-1 1) (-1 -1))
((-1 -1) (1 -1))
((1 -1) (1 1))
((1 1) (-1 1))
((-1 1) (1 -1))
((-1 -1) (1 1))
) ;square+cross
("_ext"
((0.1 0) (0.13 0))
((0.2 0) (0.23 0))
((0.3 0) (0.33 0))
) ;three points
("_par" ((0 1) (-1 -1)) ((1 1) (0 -1))) ;two lines
;;Use GRVECS
(DEFUN YPY_DrawVecs (Pt Vecs Size Color / lst matrix)
;;no Z axis
(SETQ matrix (LIST (LIST Size 0.0 0.0 (CAR pt))
(LIST 0.0 Size 0.0 (CADR pt))
(LIST 0.0 0.0 1.0 0.0)
(LIST 0.0 0.0 0.0 1.0)
(SETQ lst (MAPCAR 'CONS
(MAPCAR (FUNCTION (LAMBDA (x) Color)) Vecs)
Vecs
(GRVECS (APPLY 'APPEND lst) matrix)
;; Main Routine starts here
(VL-LOAD-COM)
(SETQ time T)
(SETQ str_osmode (get_osmode))
(SETQ lst_osmode (STD-STRTOK str_osmode ","))
(SETQ Draftobj (VLA-GET-DRAFTING
(VLA-GET-PREFERENCES (VLAX-GET-ACAD-OBJECT))
(SETQ AutoSnapMarkerSize (VLA-GET-AUTOSNAPMARKERSIZE Draftobj))
(SETQ AutoSnapMarkerColor (VLA-GET-AUTOSNAPMARKERCOLOR Draftobj))
(WHILE time
(GRREAD (SETQ drag (GRREAD T 15 1)))
(COND ((= (CAR drag) 5)
(REDRAW)
(SETQ drag (CADR drag))
(IF (NULL (SETQ ghostpt (OSNAP drag str_osmode)))
(SETQ ghostpt drag)
;;Beacuse of mouse middle button scroll , calculate "DistPerPixel" every time
(PROGN (SETQ DistPerPixel (/ (GETVAR "VIEWSIZE") (CADR (GETVAR "SCREENSIZE"))))
;;Bold
(SETQ Bold (MAPCAR '*
(LIST DistPerPixel DistPerPixel DistPerPixel)
(LIST (+ AutoSnapMarkerSize 0.5)
AutoSnapMarkerSize
(- AutoSnapMarkerSize 0.5)
(FOREACH item Bold
(YPY_DrawVecs
ghostpt
(YPY_GetGrvecs ghostpt drag lst_osmode)
item
AutoSnapMarkerColor
((= (CAR drag) 3)
(IF (NULL (SETQ ghostpt (OSNAP (CADR drag) (get_osmode))))
(SETQ ghostpt (CADR drag))
(REDRAW)
(SETQ time nil)
(PRINC) ;can return ghostpt if want
