Author Topic: Batch Plot PDF  (Read 8959 times)
GDF
Batch Plot PDF
« on: October 05, 2006, 10:24:07 AM »
Need help...
I can batch plot to lazer jet printer and to plotter, but I am having trouble with PDF's. I am using a modified version of
Tim Willey, Allen Butler and KPBLC BatchPlot routine. Thanks guys this routine works greayt!
I want the answer "yes" and not have the dialog box to create the PDF file that pops up (see image).
Next, it would be neat to have each PDF file close automatically upon creation.
Gary
« Last Edit: October 05, 2006, 10:26:13 AM by Gary Fowler »
Re: Batch Plot PDF
« Reply #1 on: October 05, 2006, 10:45:46 AM »
I thought that was a switch in the PDF software, not ACAD.
Re: Batch Plot PDF
« Reply #2 on: October 05, 2006, 11:39:22 AM »
Second.  I don't know which one it is, but I remember reading it.  Could have been on the Adesk Ng site though.
GDF
Re: Batch Plot PDF
« Reply #3 on: October 05, 2006, 11:45:27 AM »
Thanks Alan and Tim.
I will lurk around and see if anyone has a possible solution.
Gary
Re: Batch Plot PDF
« Reply #4 on: October 05, 2006, 01:14:41 PM »
http://tinyurl.com/p6nub
Although I use PDF995.
GDF
Re: Batch Plot PDF
« Reply #5 on: October 05, 2006, 03:10:05 PM »
Alan
Thanks. We have Adobe 6, do I need version 7 to see the "Adobe PDF output folder"?
http://72.14.209.104/search?q=cache:xcnCghn9tkMJ:forums.cadalyst.com/showthread.php%3Ft%3D4095+pdf+%22batch+plot%22&hl=en&gl=us&ct=clnk&cd=11
Create a new Adobe PDF for Batch Plotting PC3.
1. Create a new Adobe PDF for Batch Plotting PC3.
2. Type plot.
3. Select the new PC3.
4. Click on the Properties box to the right.
5. When the driver Dialog pops up Click on the Device and Document settings tab.
6. Half way down click on "Custom Properties."
7. Near the botton Click on the "Custom Properties" box that will appear.
8. A new dialog box titled "Adobe PDF Document Properties" will pop up.
9. Click on the "adobe PDF Settings" Tab.
10 You should see for setting with pulldowns to the right. Click on the third one down "Adobe PDF output Folder"
11. Select "My Documents\*.pdf"
Gary
GDF
Re: Batch Plot PDF
« Reply #6 on: October 05, 2006, 03:27:39 PM »
Alan
Thank you. It is working now. It no longer prompts for the file name dialog box., and the adobe file closes after
creating the pdf files.
One more question, how do I select the folder for placing the pdf files?
It is currentle saving them to c:\documents and settings\cad_5\my documents
Thank you. Thank you.
Gary
GDF
Re: Batch Plot PDF
« Reply #7 on: October 05, 2006, 04:36:32 PM »
Need help...
Gary
Is there a setting for using the current drawing file prefix for use in the plot file location?
Set the path based upon (getvar "dwgprefix")
Gary
Jeff_M
  • C3D user & customizer
Re: Batch Plot PDF
« Reply #8 on: October 05, 2006, 05:00:41 PM »
This works in 2007, I don't know if this was availble in 2006....
(setq prefs (vla-get-preferences *acad))
(setq pprefs (vla-get-output prefs))
(vla-put-DefaultPlotToFilePath pprefs (getvar "dwgprefix"))
Re: Batch Plot PDF
« Reply #9 on: October 05, 2006, 05:09:03 PM »
Looks like it's available in 2005.
GDF
Re: Batch Plot PDF
« Reply #10 on: October 05, 2006, 05:15:11 PM »
Need help...
Gary
Thanks Jeff
Command: (setq prefs (vla-get-preferences *acad))
; error: bad argument type: VLA-OBJECT nil
What am I doing wrong?
Gary
Jeff_M
Re: Batch Plot PDF
« Reply #11 on: October 05, 2006, 05:21:26 PM »
You must set *acad to the acadobject....sorry.
(setq *acad (vlax-get-acad-object))
GDF
Re: Batch Plot PDF
« Reply #12 on: October 05, 2006, 05:31:42 PM »
Need help...
Gary
Jeff
Thanks again. I get nil when using this:
(vla-put-DefaultPlotToFilePath (vla-get-output (vla-get-preferences (vlax-get-acad-object))) (getvar "dwgprefix"))
Gary
Re: Batch Plot PDF
« Reply #13 on: October 05, 2006, 05:45:06 PM »
After you run:
  (vla-get-output
  (getvar 'dwgprefix)
Inspect in the vlide editor:
  (vla-get-output
or run:
(vla-get-DefaultPlotToFilePath
  (vla-get-output
« Last Edit: October 05, 2006, 05:46:14 PM by ronjonp »
Andrea
Re: Batch Plot PDF
« Reply #14 on: October 05, 2006, 05:55:12 PM »
just curious....
Why don't simply use PUBLISH ?
Keep smile...
