Author Topic: read file values like ini  (Read 2275 times)
Humbertogo
« on: October 02, 2006, 06:09:33 AM »
can some one tell me how to read the values of this kind of file
i need to read the File [FName] value
File:
Version [Real]= 15.0 d E
[cfg]= d E
ScanMode [Short]= 1 d E
[Dir]= d E
[Test_Library]= d E
  Name [String]="Test Library" d E
  File [FName]="C:\test\lib.glf" d E
Re: read file values like ini
« Reply #1 on: October 02, 2006, 09:28:49 AM »
You could roll your own or use the WinAPI. Here's some info on the latter --
See MSDN entry, scroll down the bottom of this page, you should see --
For those headed towards .NET >> this << may be an interesting read.
Humbertogo
« Reply #2 on: October 02, 2006, 09:54:08 AM »
ready try but
is coming entry (is not a key)
