Author Topic: Stumped!! Need assistance with X-Data  (Read 3007 times)
V-Man
« on: September 29, 2006, 10:50:18 AM »
I need some assistance with this example. (see attached CAD drawing).
In this drawing there is one (1) closed LWPolyline with some form of XDATA attached to it. I am unable to read or extract the XDATA.
Can any of you guys take a crack at this and see if you can read and/or extract the XDATA?
Many thanks,
Autocad 2002
« Last Edit: September 29, 2006, 12:10:23 PM by CAB »
Re: Stumped!! Need assistance
« Reply #1 on: September 29, 2006, 11:08:55 AM »
Try this.
(defun MyGetXData (Obj DataName / CodeType DataType)
; Retrive XData for an object
(vla-GetXData
 Obj
 (if DataName
  DataName
 'CodeType
 'DataType
(if (and CodeType DataType)
 (mapcar
  '(lambda (a b)
   (cons a (variant-value b))
  (safearray-value CodeType)
  (safearray-value DataType)
Called like
(mygetxdata (vlax-ename->vla-object (car (entsel))) nil)Returned
Select object: ((1001 . "IRD") (1002 . "{") (1000 . "WISDM-_-ade") (1070 . 515)
(1071 . 1) (1004 . #<safearray...>) (1004 . #<safearray...>) (1002 . "}"))
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: September 29, 2006, 11:16:40 AM »
ENTITIES
  0
POLYLINE
  5
91
  8
ROOM-LWPOLYLINE
 66
     1
 10
0.0
 20
0.0
 30
0.0
 70
     1
1001
IRD
1002
1000
WISDM-_-ade
1070
   515
1071
        1
1004
01003000300030003000300000004F00500045004E0020004F004600460049004300450000004E006500770030003100000054004500530054003000300031000000300031000000540054004F0000003000310000004F004600460000003400350030002000530071002E002000460074002E000000310030003700340032
1004
003200380039003300360000000000
1002
  0
VERTEX
  5
AD
  8
ROOM-LWPOLYLINE
 10
311.54098400732602
 20
8.792169053929598
 30
0.0
  0
VERTEX
  5
AE
  8
ROOM-LWPOLYLINE
 10
311.54098400732602
 20
224.7921690539296
 30
0.0
  0
VERTEX
  5
AF
  8
ROOM-LWPOLYLINE
 10
11.540984007326029
 20
224.7921690539296
 30
0.0
  0
VERTEX
  5
B0
  8
ROOM-LWPOLYLINE
 10
11.540984007326029
 20
8.792169053929598
 30
0.0
  0
SEQEND
  5
B1
  8
ROOM-LWPOLYLINE
  0
VIEWPORT
  5
7B
 67
     1
  8
0
 10
4.7994580606775941
 20
4.0218994936605128
 30
0.0
 40
12.74104996238982
 41
8.9929997457669462
 68
     1
 69
     1
1001
ACAD
1000
MVIEW
1002
1070
    16
1010
0.0
1020
0.0
1030
0.0
1010
0.0
1020
0.0
1030
1.0
1040
0.0
1040
8.9929997457669462
1040
4.7994580606775941
1040
4.0218994936605128
1040
50.0
1040
0.0
1040
0.0
1070
     0
1070
   100
1070
     1
1070
     1
1070
     0
1070
     0
1070
     0
1070
     0
1040
0.0
1040
0.0
1040
0.0
1040
0.5
1040
0.5
1040
0.5
1040
0.5
1070
     0
1002
1002
1002
  0
Re: Stumped!! Need assistance with X-Data
« Reply #3 on: September 30, 2006, 07:12:06 AM »
Using elist I get this --
   (-1 . <Entity name: 7ef63ec8>)
   (0 . "LWPOLYLINE")
   (330 . <Entity name: 7ef63cf8>)
   (5 . "91")
   (100 . "AcDbEntity")
   (67 . 0)
   (410 . "Model")
   (8 . "Room-LWPolyline")
   (100 . "AcDbPolyline")
   (90 . 4)
   (70 . 1)
   (43 . 0.0)
   (38 . 0.0)
   (39 . 0.0)
   (10 311.541 8.79217)
   (40 . 0.0)
   (41 . 0.0)
   (42 . 0.0)
   (10 311.541 224.792)
   (40 . 0.0)
   (41 . 0.0)
   (42 . 0.0)
   (10 11.541 224.792)
   (40 . 0.0)
   (41 . 0.0)
   (42 . 0.0)
   (10 11.541 8.79217)
   (40 . 0.0)
   (41 . 0.0)
   (42 . 0.0)
   (210 0.0 0.0 1.0)
   (-3
            "IRD"
            (1002 . "{")
            (1070 . 515)
            (1071 . 1)
            (1004 . "010030003000300030003000000...")
            (1004 . "003200380039003300360000000000")
            (1002 . "}")
Note, I manually trimmed down the first 1004 group (ergo the ...) lest it spill off the page.
FengK
« Reply #4 on: October 01, 2006, 04:35:07 AM »
Do you have express tool installed? If so, try using command XDLIST.
V-Man
« Reply #5 on: October 02, 2006, 07:40:05 AM »
Thanks for all of the replies fellas. I got kind of busy this weekend and could not respond.
