Author Topic: vla-functions  (Read 3140 times)
viva
vla-functions
« on: September 28, 2006, 08:47:05 AM »
hi everybody,
             i had copied the polyline features by using
(setq sel(ssget "x" (list(cons 0 "lwpolyline")(cons 8 "layer1"))))
     (if sel
     (setq cnt 0)
     (repeat (- (length sel) 1)
     (setq ent(ssname sel cnt))
      (setq obj(vlax-ename->vla-object ent)
(setq cop(vla-copy obj)then i want 2 create a new layer and put the copied features in that layer thru vla functions.
i had used
vla-add
but it is showing  " activex error"
can anyone help regarding this things
thanks in advance
regards
vivek
<edit: corrected code tags>
« Last Edit: September 28, 2006, 08:56:43 AM by CAB »
Re: vla-functions
« Reply #1 on: September 28, 2006, 09:05:49 AM »
Look into this:
(vla-put-layer newpline (vla-get-layer obj))
viva
Re: vla-functions
« Reply #2 on: September 28, 2006, 09:22:35 AM »
hi cab,
           thanks for ur immediate reply. (vla-get-layer obj) .can u tell me here obj means. obj means layername or objectname. plz explain me. that will help me alot. i cant able 2 find out vla functions in help.
 i got error while using
; error: bad argument type: VLA-OBJECT nil
thanks
regards
vivek
Re: vla-functions
« Reply #3 on: September 28, 2006, 09:56:46 AM »
it is the object layer property name <correction>
(setq obj (vlax-ename->vla-object (car(entsel))))
« Last Edit: September 28, 2006, 11:45:30 AM by CAB »
Re: vla-functions
« Reply #4 on: September 28, 2006, 11:17:37 AM »
You use (vla-add ... ) when you want to create something new somewhere.  In your case, you would use it if the layer doesn't exist in the drawing.  To get the active drawing (document) use
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))Then if you want to add a layer, you have to get the layer collection (table) first, like so
(setq LayCol (vla-get-Layers ActDoc))Now if you want to add the new layer, now you use add like so
(vla-Add LayCol "MyNewLayerName")
Now if you want to put the objects returned by (vla-copy ... ), I would use 'copy' like you have it, and then you just need to update the layer of the new object you created, so add this portion to your code after you copy.
(vla-put-Layer cop "MyNewLayerName")
Hope that makes sense.
Re: vla-functions
« Reply #5 on: September 28, 2006, 11:48:23 AM »
Thanks Tim for the clarification & correction.
I guess I shot through here too fast this morning. :-)
Re: vla-functions
« Reply #6 on: September 28, 2006, 11:55:36 AM »
No problem Alan.  I help where I can.  :-)
Krushert
  • FREE BEER Tomorrow!!
Re: vla-functions
« Reply #7 on: September 28, 2006, 12:55:32 PM »
Thanks to both of you for clarifying and explaining how things work.
I will go back to watch and learning now.
viva
Re: vla-functions
« Reply #8 on: September 29, 2006, 12:36:50 AM »
hi
    thanks for both. i had learned new things from ur discussion. it helped alot
regards
vivek
Re: vla-functions
« Reply #9 on: October 09, 2006, 09:44:40 PM »
The ``vla'' prefix is used for accessing methods and properties of ActiveX objects.
The ``vlax'' prefix is a general prefix used for other ActiveX objects. (like word, excel, …Other applications in general.) You use this prefix to get/put properties of other ActiveX objects.
