Author Topic: ObjectDBX  (Read 7165 times)
Humbertogo
ObjectDBX
« on: September 28, 2006, 06:50:23 AM »
is there a way to read some systemvariables with ObjectDBX?
Re: ObjectDBX
« Reply #1 on: September 28, 2006, 01:07:06 PM »
no....not that I'm aware of :(
FengK
Re: ObjectDBX
« Reply #2 on: September 28, 2006, 01:20:49 PM »
I vaguely remember it returns the system variables from current drawing in which your code is excuted (could be wrong).
Suggestion: Store the system variables that you're interested in in a custom dictionary or attach as xdata to some objects in the drawing and later you can access them via objectdbx.
deegeecees
Re: ObjectDBX
« Reply #3 on: September 28, 2006, 02:31:50 PM »
Since ObjectDBX is most useful with unopened drawings, and AutoCADs' System Variables are either stored in the drawing or at the application level, why (if I may be so bold to ask) would you want to read them?
Just wondering what you're trying to do.
Humbertogo
Re: ObjectDBX
« Reply #4 on: September 28, 2006, 05:22:47 PM »
I need to check is the drawing is metric or imperial.
AutoCAD System Variables Measurement
0 is Imperial
1 is Metric
be for open or insert the files as block
« Last Edit: September 28, 2006, 05:24:08 PM by Humbertogo »
Fatty
Re: ObjectDBX
« Reply #5 on: September 29, 2006, 05:59:24 AM »
0 is Imperial
1 is Metric
Not sure exactly but I think this will be impossible
do doing with ObjectDBX method IMHO
Try this instead:
Option Explicit
Public Function GetVars(selfiles As Variant, sysVarName As String) As Variant
Dim fName As String
Dim acdoc As AcadDocument
Dim sysvar() As Variant
Dim m As Integer
For m = 0 To UBound(selfiles)
fName = selfiles(m)
Set acdoc = Application.Documents.Open(fName, True)
ReDim Preserve sysvar(m)
sysvar(m) = acdoc.GetVariable(sysVarName)
acdoc.Close
Next m
GetVars = sysvar
End Function
Public Sub FindFile(ByRef files As Collection, strDir, strExt)
  Dim strFileName
  If (Right(strDir, 1) <> "\") Then
    strDir = strDir & "\"
  End If
  strFileName = Dir(strDir & "*.*", vbDirectory)
  Do While (strFileName <> "")
    If (UCase(Right(strFileName, 3)) = UCase(strExt)) Then
      files.Add strDir & strFileName
    End If
  strFileName = Dir
  Loop
End Sub
Sub Test()
Dim dmod
dmod = ThisDrawing.GetVariable("SDI")
If dmod <> 0 Then
ThisDrawing.SetVariable "SDI", 0
End If
Dim path As String
path = "D:\AUTOLISP\LISPS\PRIMITIVES\#FILE&S\PURGE" '' change your path here
Dim collFiles As New Collection
Call FindFile(collFiles, path, "DWG")
Dim i As Integer
ReDim selfiles(collFiles.Count - 1) As String
For i = 1 To collFiles.Count
selfiles(i - 1) = collFiles.Item(i)
Next
sysvar = GetVars(selfiles, "measurement")
ThisDrawing.SetVariable "SDI", dmod
Dim dataVar(999, 1) As Variant
For i = 0 To UBound(sysvar)
dataVar(i, 0) = selfiles(i)
dataVar(i, 1) = sysvar(i)
Next
End Sub
Fatty
~'J'~
Chuck Gabriel
Re: ObjectDBX
« Reply #6 on: September 29, 2006, 07:56:51 AM »
What version of AutoCAD are you using?
Humbertogo
Re: ObjectDBX
« Reply #7 on: September 29, 2006, 09:04:32 AM »
I use Autocad mechanical 2006
Chuck Gabriel
Re: ObjectDBX
« Reply #8 on: September 29, 2006, 10:53:04 AM »
In that case, I think there is a way you can do it through the .NET API using C# or VB.NET.
Are you interested in giving it a try?
Humbertogo
Re: ObjectDBX
« Reply #9 on: September 29, 2006, 11:06:24 AM »
oh yes I'm
Chuck Gabriel
Re: ObjectDBX
« Reply #10 on: September 29, 2006, 11:13:08 AM »
Give me a little time to formulate something, and I'll post back with some starter code.
Chuck Gabriel
Re: ObjectDBX
« Reply #11 on: September 29, 2006, 12:01:29 PM »
This C# code should get you started.  I translated this from some similar C++ code of mine, but hopefully the .NET gurus will come along and point out anything stupid I may have done.
using System;
using System.IO;
using System.Text;
namespace MetricOrImperial
    public class Main
        public static int metricOrImperial(string fileName)
            if(!File.Exists(fileName)) return -1;
            Database db = new Database(false, true);
            try
                db.ReadDwgFile(fileName, System.IO.FileShare.Read, false, string.Empty);
                return db.Measurement == MeasurementValue.English ? 1 : 0;
            catch (Exception e)
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(e.ToString());
                return -1;
Humbertogo
Re: ObjectDBX
« Reply #12 on: September 29, 2006, 12:22:50 PM »
thanks Chuck Gabriel
Chuck Gabriel
Re: ObjectDBX
« Reply #13 on: September 29, 2006, 12:33:43 PM »
You're welcome.
By the way, I think I got the return values backwards (assuming you want to follow the convention of the MEASUREMENT system variable).  It should return 0 for English and 1 for Imperial.
Humbertogo
Re: ObjectDBX
« Reply #14 on: September 29, 2006, 01:54:44 PM »
The AutoCAD System Variables Measurement  is the autocad way i think
for  Autocad Mechanical i wrote  this function
and  will try to convert this function in a C# code
Public Function Mcad_StandardIsMetric() As Boolean
Set symbb = ThisDrawing.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
Set Ge = ThisDrawing.Application.GetInterfaceObject("Ge.Application")
Set stdmgr = symbb.StandardMgr
Set currStand = stdmgr.CurrentStandard
 Mcad_StandardIsMetric = currStand.IsMetric
End Function
