Author Topic: Revision Cloud w/ ORTHO  (Read 3258 times)
TomREd
« on: September 27, 2006, 10:24:45 AM »
I have been searching for a revcloud routine that has the abitilty to be along a straight line. Does anyone have a modified lisp routine that accepts ORTHO ON/OFF.
I just dont like not having a straight cloud line in a schedule. Looks like poop to me if all "bumpy" so to say...
David Hall
  • Automatic Duh Generator
Re: Revision Cloud w/ ORTHO
« Reply #1 on: September 27, 2006, 10:26:14 AM »
what version of acad? in 06/07 the rev cloud in the draw menu will except a closed polyline, so you can draw a rectangle or closed polyline first, then convert to cloud.  Thats what I do.
hudster
« Reply #2 on: September 27, 2006, 10:35:38 AM »
*^C^Crectangle;\\revcloud;a;5;10;object;l;no;
here is a copy of the macro I use in 2007 which draws the rectangle, then converts to a revcloud, and repeats till cancelled.
Just change the arc size to suit.
GDF
« Reply #3 on: September 27, 2006, 10:43:26 AM »
Here is a box cloud routine...
;;;;;;;;;;;;;;;;;;;;;;;;;;;; Box Cloud Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun BXCLOUDIT (/ OS S1 D1 D2 D3 P1 P2 P3 P4 P5 PN PH)
  ;;(cond
  ;;((= cloud 0)(setvar "plinewid" 0))
  ;;((= cloud 1)(setvar "plinewid" 3))
  (setq OS (getvar "osmode"))
  ;;(alert (strcat "Box Cloud Placed on\nLayer : " (getvar "clayer")))
  (graphscr)
  (command "osmode" 0 "cmdecho" 0)
  (setq P1 (getpoint "\n* Pick the Lower Left Corner *")
P3 (getcorner P1 "\n* Pick the Upper Right Corner *")
PN (getint
     "\n* Enter number of Arcs along width of Rectangle <default=7> * "
   ) ;_ end of getint
P2 (list (car P3) (cadr P1))
P4 (list (car P1) (cadr P3))
D1 (- (distance P1 P2) (distance P2 P3))
  (if (= PN nil)
    (setq PN 7)
  (setq D3 (/ (distance P1 P2) PN))
  (setq PH (polar P1 (angle P1 P2) D3))
  ;;(command "pline" P1 "w" 0 0 "a" "a" "130" PH "")
  (command "pline" P1 "a" "a" "130" PH "")
  (setq S1 (entlast))
  (while (> (distance PH P2) (+ D3 1))
    (setq P5 PH)
    (setq PH (polar P5 (angle P1 P2) D3))
    (command "pline" P5 "a" "a" "130" PH "")
    (command "pedit" "l" "j" S1 "" "")
    (setq S1 (entlast))
  ) ;_ end of while
  (setq P5 PH)
  (setq PH (polar P2 (angle P2 P3) D3))
  (command "pline" P5 "a" "a" "180" PH "")
  (setq S1 (entlast))
  ;;Right side
  (while (> (distance PH P3) D3)
    (setq P5 PH)
    (setq PH (polar P5 (angle P2 P3) D3))
    (setq S1 (entlast))
  ) ;_ end of while
  (setq P5 PH)
  (setq PH (polar P3 (angle P3 P4) D3))
  (setq S1 (entlast))
  ;;Top side
  (while (> (distance P4 PH) D3)
    (setq P5 PH)
    (setq PH (polar P5 (angle P3 P4) D3))
    (setq S1 (entlast))
  ) ;_ end of while
  (setq P5 PH)
  (setq PH (polar P4 (angle P4 P1) D3))
  (setq S1 (entlast))
  ;;Left side
  (while (> (distance P1 PH) D3)
    (setq P5 PH)
    (setq PH (polar P5 (angle P4 P1) D3))
    (setq S1 (entlast))
  ) ;_ end of while
  (command "pline" PH "a" "a" "130" P1 "")
  (command "osmode" OS)
  (BULGELASTIT) ;;reverse bulge
(defun BULGELAST-IT (/ CNT COORDS DIV EOBJ)
  (setq EOBJ (vlax-ename->vla-object
       ;;(car (entsel "\n* Select pline: "))
               (entlast)
  (if EOBJ
      (setq COORDS (vlax-safearray->list
     (vlax-variant-value
       (vla-get-coordinates EOBJ)
      (setq CNT 0)
      (if (or (= (vla-get-objectname EOBJ) "AcDb2dPolyline")
      (= (vla-get-objectname EOBJ) "AcDb3dPolyline")
(setq DIV 3)
(setq DIV 2)
      (while (< CNT (/ (length COORDS) DIV))
(if (< (vla-getbulge EOBJ CNT) 0.0)
  (vla-setbulge EOBJ CNT 1.0)
  (vla-setbulge EOBJ CNT -1.0)
(setq CNT (1+ CNT))
  (prin1)
(defun BULGELASTIT ()
  (initget "Y N")
  (if (= "Y" (getkword "\n* Reverse Cloud Bulge - Yes/No <No> *"))
    (BULGELAST-IT)
Gary
TomREd
« Reply #4 on: September 27, 2006, 10:44:32 AM »
Im using what seems to be Ancient now but still very effective..ADT3.3
I found a lisp from CAB that looks like a superior LISP to what I'm using now..Express Tools REVCLOUD.LSP
I just couldn't find a link for the newest version of his updated lisp. I'm so glad to find a forum where I can actually get some answers. Thanks Guys
