Author Topic: elipse into a dome 3d  (Read 12456 times)
Jochen
Re: elipse into a dome 3d
« Reply #15 on: September 27, 2006, 06:35:58 AM »
I made a Surface-model of the eight part by EDGESURF-command and then I performed it into 3DSOLID using F2S.lsp by Bill Gilliss (see attachement).
Regards
Jochen
Cavediver
« Reply #16 on: September 27, 2006, 09:07:23 AM »
Confusion reigns supreme ..
How do you get a 3d dome from a plywood sheet ?
I think they're making the framing from plywood, and then putting a skin on it.
rktect3j
« Reply #17 on: September 27, 2006, 11:14:42 AM »
OK First I started with this.
Which got me to this.
Then I took the ribs out and did the string and pencil trick in the horizontal. (X)
And then in the vertical. (Y)
Somebody please tell me I didn't screw this up.
