Author Topic: 3D in acad 2002 best way about it?  (Read 11254 times)
rktect3j
Re: 3D in acad 2002 best way about it?
« Reply #15 on: September 25, 2006, 11:01:00 AM »
in 02, you may have to define your cutting plane w/ 3 points.  Pick first point on 45 line, pick other endpoint, and type @0,0,1
Whcih would be 1 inch above first point.  that should define the plane for you
It finally worked.  Thanks.  I kept slicing off the wrong end.  The third point kept throwing me off I think.  I'll try the 0,0,1  Thanks
David Hall
  • Automatic Duh Generator
« Reply #16 on: September 25, 2006, 06:26:08 PM »
dont forget the "@" to go with your 0,0,1
