Author Topic: Block Cleanup and Update Routine  (Read 3215 times)
Vince
« on: September 20, 2006, 08:01:01 AM »
Hi Swamp Members:
I have inherited a mess of drawings where I need to perform a lot of cleanup and reorganizing to get the blocks on the drawings standardized to company format and in usable shape.
I am relatively new to VBA and have been trying to develop a routine that could be used on a selected group of drawings and provide buttons with the following options:
1) Rename blocks on the drawings
2) Redefine blocks on the drawings
3) Replace blocks on the drawings (replace existing existing blocks with new ones)
4) Update a block and sync the attributes on the drawings
So far I have had little success in accomplishing this task.....can anyone provide some assistance or give me direction as to where I could find the sub-routines I am looking for or do some research to develop them.
Any help would be appreciated.....!
Regards,
Vince
Arizona
Re: Block Cleanup and Update Routine
« Reply #1 on: September 20, 2006, 12:41:29 PM »
This might help you for a part of it. This was originally written to changeout an old title block for a new one.
The piece below creates the Selection set of block references. I'm using an array of block names as my list. This allows me to handle different blocks in different manners. Once I find a block I'm looking for, the insert point, scale, and rotation angle are stored in variables to use later. If there are attributes these are stored an an array so that the values are not destroyed when the block is deleted.
Set objAcadSSet = ThisDrawing.SelectionSets.Add("sSet2")
intTextCodes(0) = 0 'set code for entities
varCodeValues(0) = "INSERT" 'set entity type to filter
objAcadSSet.Select acSelectionSetAll, , , intTextCodes, varCodeValues   'create set
For Each objOldBlk In objAcadSSet
   BName = UCase(objOldBlk.Name)
      Select Case BName
          Case arOldBlkNames(0)     'ctml0011
              InsertPt(0) = objOldBlk.InsertionPoint(0)
              InsertPt(1) = objOldBlk.InsertionPoint(1)
              InsertPt(2) = objOldBlk.InsertionPoint(2)
              xScale = objOldBlk.XScaleFactor
              yScale = objOldBlk.YScaleFactor
              zScale = objOldBlk.ZScaleFactor
              Rot = objOldBlk.Rotation
           If objOldBlk.HasAttributes Then
              varOldAtt = objOldBlk.GetAttributes     'get block attributes
            End If
          For intOldCnt = LBound(varOldAtt) To UBound(varOldAtt)
            Set objOldAttRef = varOldAtt(intOldCnt)
          Next intOldCnt
            NewBlkName = "CTML0013.dwg"
      NewBlk
And this piece is the new block going back in with the attributes fed back in.
Case arOldBlkNames(0)         'CTMl0011
   Set objNewBlk = ThisDrawing.ModelSpace.InsertBlock(InsertPt, NewBlkName, xScale, yScale, zScale, Rot) 'insert new tblock
   varNewAtt = objNewBlk.GetAttributes 'get attributes
       For intNewCnt = LBound(varNewAtt) To UBound(varNewAtt)
            If varNewAtt(intNewCnt).TagString = varOldAtt(intOldCnt).TagString Then
                varNewAtt(intNewCnt).TextString = varOldAtt(intOldCnt).TextString
            End If
      Next
   Next
mohnston
  • CAD Programmer
« Reply #2 on: September 26, 2006, 03:26:41 PM »
Hi Swamp Members:
Regards,
Vince
I will cherry-pick the easy one.
Thisdrawing.Blocks("OldBlockName").Name = "NewBlockName"
CAD Programming Solutions
Fatty
« Reply #3 on: September 28, 2006, 06:24:18 AM »
Hi, Vince
Here is my poor attemt to solve your task,
not completed though :(
Fatty
~'J'~
« Reply #4 on: September 28, 2006, 06:33:50 AM »
All of those tasks have tools written for them in either ACAD or express tools. Just have a look at your menus ...
