Author Topic: Commit vs Abort  (Read 9165 times)
Glenn R
Re: Commit vs Abort
« Reply #15 on: September 21, 2006, 01:07:23 AM »
I agree...I rarely if ever used transactions in ARX.
Re: Commit vs Abort
« Reply #16 on: September 21, 2006, 04:18:55 AM »
.....  I've had problems using transactions for read-only object access, regardless of whether they are committed or aborted (the manifestation is that it disables REDOing of the operation(s) after the transaction is ended, if they are undone).
Thanks Tony .. time for me to have a rethink ..
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
Re: Commit vs Abort
« Reply #17 on: September 21, 2006, 07:35:41 AM »
Tony! VS2002 C# (not VB.NET) has using statement in context:
using (...) {
For example this code is working under AutoCAD 2006 / VS 2002:
http://discussion.autodesk.com/servlet/JiveServlet/download/152-500641-5307312-121115/Zoom.txt
TonyT
Re: Commit vs Abort
« Reply #18 on: September 21, 2006, 11:07:56 AM »
using (...) {
Hi Alex.  I believe it was VB.NET that was missing it in VS2002.
