Author Topic: acedRedraw .NET Equivalent  (Read 5454 times)
Nathan Taylor
« on: September 14, 2006, 02:49:58 AM »
Is there a .NET equivalent of the ARX acedRedraw function?
Regards - Nathan
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
Re: acedRedraw .NET Equivalent
« Reply #1 on: September 14, 2006, 02:00:47 PM »
What about P/Invoke this function?
Nathan Taylor
« Reply #2 on: September 14, 2006, 07:42:09 PM »
If it is not exposed I will just use the way I have been doing it in VBA which is to use the VisualLisp Activex Module to evaluate the lisp function.
Alexander Rivilis
« Reply #3 on: September 15, 2006, 04:19:51 AM »
This function can be used in next ways:
1) Redraw screen
2) Show/hide entity -> Entity.Visible  = true (or false)
3) Highlight/Unhighlight entity -> Entity.Highlight(..)/Entity.Unhighlight(...)
#define ACADR16
using System ;
using System.Runtime.InteropServices ;
using Autodesk.AutoCAD.Runtime ;
using Autodesk.AutoCAD.ApplicationServices ;
using Autodesk.AutoCAD.EditorInput ;
using Autodesk.AutoCAD.DatabaseServices ;
using Autodesk.AutoCAD.Geometry ;
[assembly: CommandClass(typeof(Rivilis.Redraw))]
namespace Rivilis
  public class Redraw
    [System.Security.SuppressUnmanagedCodeSecurity]
    [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl)]
    private static extern Int32 acedRedraw(long [] name, Int32 mode);
#if ACADR16
    [DllImport("acdb16.dll", CallingConvention=CallingConvention.Cdecl, EntryPoint="?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AAY01JVAcDbObjectId@@@Z")]
#elif ACADR17
    [DllImport("acdb17.dll", CallingConvention=CallingConvention.Cdecl, EntryPoint="?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AAY01JVAcDbObjectId@@@Z")]
#endif
    private static extern int acdbGetAdsName(long [] name, ObjectId objId);
    [CommandMethod("MyRedraw")]
    static public void MyRedraw()
      acedRedraw(null, 1);
    // Highlight entity
    [CommandMethod("HlEnt")]
    static public void HlEnt()
      PromptEntityOptions entityOpts = new PromptEntityOptions("\nSelect entity: ");
      PromptEntityResult rc = Application.DocumentManager.MdiActiveDocument.Editor.GetEntity(entityOpts);
      if (rc.Status == PromptStatus.OK)
        long [] ent = new long [] { 0, 0};
        acdbGetAdsName(ent,rc.ObjectId);
        acedRedraw(ent, 3);
    // Unhighlight entity
    [CommandMethod("UlEnt")]
    static public void UlEnt()
        acedRedraw(ent, 4);
« Last Edit: September 15, 2006, 05:20:28 AM by Alexander Rivilis »
« Reply #4 on: September 15, 2006, 05:42:05 AM »
Looks nice Alex' ... developed on a theme that is becoming familiar .. thanks.
Nathan Taylor
« Reply #5 on: October 03, 2006, 02:04:04 AM »
For anyone using VB.NET.
    <System.Security.SuppressUnmanagedCodeSecurity()> _
    <System.Runtime.InteropServices.DllImport("acad.exe", CallingConvention:=System.Runtime.InteropServices.CallingConvention.Cdecl)> _
    Private Shared Function acedRedraw(ByVal name As Long(), ByVal mode As Integer) As Integer
    End Function
    <CommandMethod("MyRedraw")> _
    Public Sub MyRedraw()
        acedRedraw(Nothing, 1)
    End Sub
Regards - Nathan
