Author Topic: Whats a good start for Visual Lisp?  (Read 7059 times)
psuchewinner
Re: Whats a good start for Visual Lisp?
« Reply #15 on: September 14, 2006, 07:25:15 AM »
I am glad Afralisp is back!  I learned so much from that site and the newsletters.  The tutorials and the function explanations make it really easy to understand.  Be careful though, it could become an obsession.  I like to figure out how people do different things.  It is challenging and fun.  Good luck!
CECE_CAD
« Reply #16 on: September 18, 2006, 05:22:50 PM »
Your problem is this line
(vlax-for x (vla-item (vla-get-blocks jbThisDrawing) nameStr)
I'm pretty sure 'jbThisDrawing' is a global variable to hold the active document.  I would just rewrite that line like
(vlax-for x (vla-Item (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-Acad-Object))) nameStr)And it should work then.
Edit:  And when you post code, place it in code tags [ code ] to start the code, and [ /code ] to end it (without the spaces).
Ok, so the block changes to zero but it does not get set to the new layer..? Hey what does the "Jb" mean when used like
this -> (jbthisdrawing)
(defun jb:BlockLayerZero(nameStr newLayer / jbThisDrawing)
(setq jbThisDrawing(vla-get-activedocument(vlax-get-acad-object)))
(if (not (tblsearch "layer" newLayer))
(alert (strcat newLayer " does not exist - please creat it first!"))
(if (tblsearch "block" nameStr)
(vlax-put-property x 'layer "0")
(vlax-put-property x 'color acByLayer)
(princ "\nLayer changed!"))
(vlax-for blks (vla-get-blocks jbThisDrawing)
(vlax-for blk blks
(if (vlax-property-available-p blk 'name)
(if (=(vla-get-name blk) nameStr)
(vla-put-layer blk newLayer)))))
(alert (strcat NameStr " not found!")))))
(princ))
(COMMAND "LAYER" "M" "A-Lite-01")
(defun c:FixLiteBlock( / )
(jb:BlockLayerZero "AL2x4" "A-Lite-01"))
« Reply #17 on: September 18, 2006, 05:30:10 PM »
jb = The authors initials.
It should work, I don't see anything out of the ordinary.  It changes the blocks objects to layer 0, and then it searchs the block collection (which is where the definition for the spaces are) and if it finds your block, it changes it to the new layer.  The only thing I can think of is that your block is a nested one, or with the new dynamic blocks.  If the block is a dynamic one, and has been changed, then the name isn't the one that defines it.
Hope that makes sense.
CECE_CAD
« Reply #18 on: September 18, 2006, 05:42:30 PM »
Hey I added the
is there a better way to write that? is that a generic way to creat a layer?
« Reply #19 on: September 18, 2006, 05:51:54 PM »
The command isn't finished.  Have to put that one the comamnd line, and see if it works?  You will need one more enter to exit the command. An enter in lisp if a pair of double quotes.  So you would want
(command "_.layer" "_m" "A-Lite-01" "")
The underscore before native commands is so that the routine will run with internation versions (I just have a habit now of doing it), and the period before the layer command is so it will use the the built in command instead of one that has been redefined, if it has been redefined.
« Reply #20 on: September 18, 2006, 06:03:20 PM »
CECE,
Just make sure you understand what that command is doing.
It makes the layer (if not existing) and sets it current when you load the routine.
If it was me, I'd rather not have that happen.
There is no checking that the layer exists when it is needed.
This may give you some ideas :
(setq newLayer "TestLayer")
    (vl-cmdf "._LAYER" "_NEW" newLayer "")
    (alert (strcat "LAYER " newLayer
                   " Has been created, Please confirm it's COLOR and LINETYPE."
« Last Edit: September 18, 2006, 06:06:23 PM by Kerry Brown »
LE
« Reply #21 on: September 18, 2006, 06:03:47 PM »
just to get a little confused:
(command "_.layer" "_m" "A-Lite-01" ^)
(command "_.layer" "_m" "A-Lite-01" p)
(command "_.layer" "_m" "A-Lite-01" nil)
(command "_.layer" "_m" "A-Lite-01" enter)
will work too....   :-P
CECE_CAD
« Reply #22 on: September 18, 2006, 06:07:24 PM »
Do I have to note the layer that the block is on to change to the layer that i'm trying to put it on?
« Reply #23 on: September 18, 2006, 06:12:13 PM »
Nope, not with the way this routine is written.  It just cares about the block name, and the new layer.
