Author Topic: How would you handle this: Timer function?  (Read 22446 times)
nivuahc
« on: September 12, 2006, 11:09:59 AM »
A friend asked me to throw something together for him as an art project and this is, essentially, what he wants to do;
Open a drawing
Wait a specified amount of time (5 minutes or so)
Close the drawing
Open the next
Close the drawing
Open the next
Close the drawing
Open the next
etc...
But here's the catch: He wants the user (gallery patron) to be able to use the 3DOrbit command via touchscreen for those 5 minutes or so...
Now I haven't put a tremendous amount of thought into the process but the half a dozen things I considered didn't seem to work.
While he is a very talented 3D artist and quite proficient with AutoCAD, he wouldn't know a Lisp routine from a script so I'm trying to make this as simple as possible for him.
I've got it setup now to write a script based on the drawings contained in a selected folder, then run the script. No problems there. It's the "start a timer, begin the 3dOrbit command, cancel the command at the specified time" part that's giving me trouble.
Any suggestions or advice?
uncoolperson
Re: How would you handle this: Timer function?
« Reply #1 on: September 12, 2006, 11:43:01 AM »
.net should be able to handle this pretty easily, i don't think lisp would like it much though.
« Reply #2 on: September 12, 2006, 11:57:06 AM »
I second that.  I have written a basic countdown program in C# if you want to see it.  It has been posted in the .Net forum, here.
nivuahc
« Reply #3 on: September 12, 2006, 12:05:49 PM »
Well, to think I was trying to make this as simple as possible for my friend... honestly, that code was all Greek to me. :)
Okay, it wasn't that bad, but I have no idea how to use code written in C# in AutoCAD. And I have no idea how to hack your routine to make it do only what I want. And I have no idea how to explain it to anyone else.
Basically, I'm (as usual) quite lost and confused.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: September 12, 2006, 12:12:27 PM »
Use View object...
TimSpangler
  • CAD Naked!!
« Reply #5 on: September 12, 2006, 12:19:32 PM »
I would think that you would need a reator of some sort so that the user couldn't cancel the ORBIT command and if they do reinvoke it til the time runs out.  I wouldn't se why it couldnt be done with lisp, but it would be hard to control.
ACA 2015 - Windows 7 Pro
« Reply #6 on: September 12, 2006, 12:21:51 PM »
Okay.  :-)
If I understand you correctly, you want to select a certain amout of drawings, have one open for 5 minutes, and then close it (without saving), and open the next one?  I think this shouldn't be too hard.  Let me see what I can come up with.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: September 12, 2006, 12:25:09 PM »
It is possible to write orbit program...
From a script we open the drawing and we start for my_orbit program which watches an operating time and itself it is completed, further the script opens the following drawing.
« Reply #8 on: September 12, 2006, 12:35:18 PM »
How do you get it to watch the time?  I have never seen a way to do that, and I have seen a couple of people asking for this.  Very interesting.
nivuahc
« Reply #9 on: September 12, 2006, 12:50:09 PM »
x2
Which is why I posted in the first place. I've already got a very simple "select a drawing from your folder, write the script, run it" routine setup I'm just stuck on the whole "after this period of time (during which the 3DOrbit command is being used) go to the next drawing" bit.
« Reply #10 on: September 12, 2006, 08:29:46 PM »
> How would i handle this?
With a program.
Then you havnet paid attention.
EDIT: Fat fingers!!!
Try this on for size. Its real sloppy, but it was a once thru quickie.
(defun tryme ( / sec flag)
  (alert "I will give you a few seconds to draw as many lines as you can GO!")
  (command "_.line")
  (setq sec (atoi (substr (rtos (getvar "cdate")2 8) 12 2)))
  (if (= 1 (logand (getvar"cmdactive") 1))
    (setq flag T))
  (while flag
         (command pause)
         (if (> (atoi (substr (rtos (getvar "cdate")2 8) 12 2)) sec)
           (setq flag nil)))
  (command) (command)
  (alert "Alright, that's enough!")
« Last Edit: September 12, 2006, 08:31:22 PM by Se7en »
« Reply #11 on: September 13, 2006, 11:14:54 AM »
Works.
nivuahc
« Reply #12 on: September 13, 2006, 11:16:15 AM »
Not with 3DOrbit. :)
« Reply #13 on: September 13, 2006, 05:49:38 PM »
> Works.
Yep, sorta.  It's bloated, crapy, and redundant, but when it comes time we can put a dress on the theory and send it off to the prom.
> Not with 3DOrbit.
Not with the native one. But i was under the impression that we were going to roll our own.  (hence the ``simple'' code. ...I was using something like ``working pseudo code'' to drive a point home.)
« Reply #14 on: September 13, 2006, 05:56:31 PM »
Hi John, long time ...
