Author Topic: How would you handle this: Timer function?  (Read 22521 times)
ElpanovEvgeniy
  • Moscow (Russia)
Re: How would you handle this: Timer function?
« Reply #45 on: September 15, 2006, 02:25:51 PM »
The program is indifferent to buttons of the mouse and the keyboard...
Certainly, all can be stopped.
I with you agree! (For example a hammer...)
Greg B
  • Tell me a Joke!
« Reply #46 on: September 15, 2006, 02:27:31 PM »
Kinda extreme, but yeah that would work.  I was thinking the power button.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #47 on: September 15, 2006, 02:32:06 PM »
If I have correctly understood, the program is necessary for presentation and should not stop...
I badly understand English and could understand explanations incorrectly.  :-(
Greg B
  • Tell me a Joke!
« Reply #48 on: September 15, 2006, 02:36:28 PM »
No....you did just fine!
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #49 on: September 15, 2006, 02:46:02 PM »
I do not have time to complete this program (command PAN) is not processed, if who that will make, it will be interesting to look!
« Reply #50 on: September 15, 2006, 02:47:40 PM »
Second!
nivuahc
« Reply #51 on: September 15, 2006, 02:52:24 PM »
Evgeniy!
The way the routine works right now is more than anyone could ask for. I'm completely blown away by how awesome that is!
« Reply #52 on: September 17, 2006, 10:55:38 PM »
Yes, That  is very nice Elpanov!
How's the main program going now nivuahc?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #53 on: September 18, 2006, 07:57:17 AM »
During work it is possible to use PAN and ZOOM in a transparent mode.
(defun time-3dorbit (/ s)
  ;;  ElpanovEvgeniy, Russia, Moscow, 2006
  ;;  Timer for test-3dorbit
  ;; (time-3dorbit)
  (princ "\n tiner set 60 sec ")
  (setq s ((lambda (sec) (+ (* 86400 (- sec (fix sec))) 60)) (getvar "DATE")))
  (while (> s ((lambda (sec) (* 86400 (- sec (fix sec)))) (getvar "DATE")))
    (VL-CATCH-ALL-APPLY (function test-3dorbit) (list s))
  ) ;_  while
) ;_  defun
(defun my-3dorbit (sec / PT1 PT2 R S V V1 VD W)
  ;;  Function "3dorbit"
  ;;  During work it is possible to use PAN and ZOOM
  ;;  in a transparent mode.
  ;;  (my-3dorbit)
  (if (tblsearch "VIEW" "tmp1")
    (setq
      v1  (tblobjname "VIEW" "tmp1")
      pt2 (trans (cadr (grread nil 5)) 1 2)
    ) ;_  setq
    (setq
      v1  (entmakex
            (list
              '(0 . "VIEW")
              '(100 . "AcDbSymbolTableRecord")
              '(100 . "AcDbViewTableRecord")
              '(2 . "tmp1")
              '(70 . 0)
              (cons 40 (getvar "VIEWSIZE"))
              (cons 10 (getvar "VIEWCTR"))
              (cons
                41
                (* (getvar "VIEWSIZE")
                   (apply
                     (function /)
                     (getvar "SCREENSIZE")
                   ) ;_  apply
                ) ;_  *
              ) ;_  cons
              (cons 11 (getvar "VIEWDIR"))
              '(12 0. 0. 0.)
              (cons 42 (getvar "LENSLENGTH"))
              (cons 43 (getvar "FRONTZ"))
              (cons 44 (getvar "BACKZ"))
              (cons 50 (getvar "VIEWTWIST"))
              (cons 71 (getvar "VIEWMODE"))
              '(281 . 6)
              '(72 . 0)
            ) ;_  list
          ) ;_  entmakex
    ) ;_  setq
  ) ;_  if
  (while (and (= (car (setq pt1 (grread nil 5))) 5)
              (> sec ((lambda (sec) (* 86400 (- sec (fix sec)))) (getvar "DATE")))
         ) ;_  and
    (setq r   (/ (getvar "VIEWSIZE") 4.)
          w   (trans (getvar "VIEWCTR") 1 2)
          pt1 (trans (cadr pt1) 1 2)
          v   (trans
                ((lambda (x1 y1 x2 y2)
                   (list
                     (- x1 x2)
                     (- y1 y2)
                     (- (sqrt (abs (- (* R R) (* x1 x1) (* y1 y1))))
                        (sqrt (abs (- (* R R) (* x2 x2) (* y2 y2))))
                     ) ;_  -
                   ) ;_  list
                 ) ;_  lambda
                  (- (car pt2) (car w))
                  (- (cadr pt2) (cadr w))
                  (- (car pt1) (car w))
                  (- (cadr pt1) (cadr w))
                2
                1
              ) ;_  trans
          pt2 pt1
          s   (/ r (distance '(0. 0. 0.) (getvar "VIEWDIR")))
          vd  (mapcar (function (lambda (x) (* x s))) (getvar "VIEWDIR"))
          v   (mapcar (function +) vd v)
          s   (/ r (distance '(0. 0. 0.) v))
          v   ((lambda (s) (list (* (car v) s) (* (cadr v) s) (* (caddr v) s)))
          w   (* (/ r (getvar "VIEWSIZE"))
                    (apply
                      (function /)
                    ) ;_  apply
                 ) ;_  *
                 4.
              ) ;_  *
    ) ;_  setq
    (entmod
      (list
        (cons -1 v1)
        '(0 . "VIEW")
        '(2 . "tmp1")
        '(70 . 0)
        (cons 10 (trans (getvar "VIEWCTR") 1 2))
        (cons
          41
             (apply
               (function /)
             ) ;_  apply
          ) ;_  *
        ) ;_  cons
        (cons 11 v)
        '(12 0. 0. 0.)
        '(281 . 6)
        '(72 . 0)
      ) ;_  list
    ) ;_  entmod
    (entupd v1)
    (setview (tblsearch "VIEW" "tmp1"))
  ) ;_  while
) ;_  defun
jxphklibin
« Reply #54 on: August 19, 2009, 02:21:32 AM »
 Waiting!!!!
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #55 on: August 19, 2009, 05:20:33 AM »
Waiting!!!!
You wish to lift this theme?
« Reply #56 on: August 19, 2009, 08:30:35 AM »
LeeBen what are you waiting for exactly?
Shinyhead
« Reply #57 on: August 19, 2009, 09:26:45 AM »
Not to derail things to much, but wouldn't having an application open and close a series of 3D dwfs be easier and look better?
jxphklibin
« Reply #58 on: August 19, 2009, 09:39:17 PM »
Posts made the wrong place, sorry!
