Author Topic: How to run a lisp routine automatically when switching workspaces  (Read 2502 times)
Cawaugh
« on: September 11, 2006, 08:46:46 AM »
 This is driving me nuts!  :realmad: I haven't found a solution to my question and I have looked in many areas with no luck. I'm sure it's so simple that I'm missing it and I'm probably looking in the wrong area anyway. Maybe someone can make my day if there even is a solution to this.  :-D . Thanks for listening to my raving.   :ugly:
David Hall
  • Automatic Duh Generator
Re: How to run a lisp routine automatically when switching workspaces
« Reply #1 on: September 11, 2006, 09:01:14 AM »
i didn't see anything in the VBA area of AcadDocument, so maybe its not exposed
« Reply #2 on: September 11, 2006, 09:18:54 AM »
Reactor stuff here: http://www.theswamp.org/index.php?topic=9736.msg124522#msg124522
I don't do any but you might be looking for this:  vlr-documentBecameCurrent
Tramber
« Reply #3 on: September 11, 2006, 11:04:47 AM »
In my opinon, the easiest way would be to attach a reactor that react to the change of a variable. I know it exists.
Then each time the reactor is called, just make it check variables like TILEMODE and the others.
« Reply #4 on: September 11, 2006, 11:50:49 AM »
Here is something he is looking for.
(if (not GlbReactorWorkspaceChange)
 (setq GlbReactorWorkspaceChange (vlr-sysvar-reactor "MyWorkspaceReactor" '((:vlr-sysVarChanged . ShowCurrentWorkspace))))
(defun ShowCurrentWorkSpace (React SysVar)
(if (and (= (strcase (car SysVar)) "WSCURRENT") (= (cadr SysVar) T))
  (prompt (strcat "\n New workspace: " (getvar "wscurrent")))
Tramber
« Reply #5 on: September 11, 2006, 01:52:01 PM »
Yes, workspaces and not the CTAB or the TILEMODE variable I was talking about. WSCURRENT is so new to me that I was not able to give it  ;-)
« Reply #6 on: September 11, 2006, 01:53:41 PM »
No problem.  You were on the right path.  :wink:
