Author Topic: Getpoint func  (Read 1849 times)
Hangman
Getpoint func
« on: September 08, 2006, 02:28:52 PM »
OK, for some reason unbeknownst to me, I have a mental blockage (called thinking).
How do I get a point from a move command ??
  (setvar "orthomode" 0)
  (setvar "osmode" 2)
  (princ "\nMove ...")
  (command "._move" ss1 "" pt3 pause)
  (setvar "orthomode" 1)
  (princ "\nRotate ...")
  (command "._rotate" ss1 "" <??> pause)
So I'm moving an object from a point previously specified, "pt3".  The object is then moved by "pt3" to a new point, <??>.  I then want to rotate the object from that new point <??>.
How do I get the point <??> ?
Thank you.
Hangman  8)
Re: Getpoint func
« Reply #1 on: September 08, 2006, 02:34:44 PM »
After your first move command, use this to get the point used.
(setq pt4 (getvar "lastpoint"))
