Author Topic: Matching block attributes  (Read 2880 times)
hyposmurf
« on: April 11, 2004, 07:08:02 AM »
Ive been updating some of my titleblocks at work to feature our new logo.Something Ive found a bit annoying is that jobs that have already been started whilst the logo was being changed now require their titleblocks to be updated so we arent trading under our previous company logo.Ive found a lisp that is pretty dam helpfull and saved me a fair bit of time.This lisp will match the block attributes values from one block by matching attribute tags and then the values.
;;   matchblocks.lsp
;;   Written By: Colin Guze
;;          Copyright 2001. Use with permission only.
;;   This program will match the block attributes values from one
;;   block by matching attribute tags and then the values.  Once installed
;;   type "MB" to run.
;;   Colin Guze
;;   Box 201
;;   Nelson, BC
;;   Canada
;;   V1L 5P9
(princ "\nType MB to Run")
(defun C:MB (/)
   (setq baselist (list))
   (setq ename (car (entsel "\nSelect Base Block:")))
   (while (= ename nil)
      (princ "\nNothing Picked")
   );end while
   (setq ename1 (car (entsel "\nSelect Block To Apply Changes:")))
   (while (= ename1 nil)
   );end while
   (setq ename (entnext ename))
   (setq elist (entget ename))   ;the entity list of the base border
   (setq etype (cdr (assoc 0 elist)))   ;should be attrib
   (while (= etype "ATTRIB")      ;puts all the attribute in a list
      (setq tag (cdr (assoc 2 elist)))      ;the attribute tag
      (setq val (cdr (assoc 1 elist)));the attribute value
      (setq baselist (append (list (list tag val)) baselist));put the attribute in list
      (setq ename (entnext ename))         ;move onto the next attribute
   );end while
   (setq ename1 (entnext ename1))            ;get the next entity, should be "ATTRIB"
   (setq elist1 (entget ename1))            ;the entity list of the border
   (setq etype1 (cdr (assoc 0 elist1)))         ;should be attrib
   (while (= etype1 "ATTRIB")
      (setq attval nil)
      (setq tag (cdr (assoc 2 elist1)));the attribute tag
      (foreach item baselist
         (if (= tag (nth 0 item))
               (setq attval (nth 1 item))
            );end then
            (progn);else do nothing go to next in list till tag matches
         );end if
      );end foreach
      (if (/= attval nil)
         (progn   (setq elist1 (subst (cons 1 attval) (assoc 1 elist1) elist1))
            (entmod elist1));end then
         (progn);end else
      );end if
      (setq ename1 (entnext ename1))   ;move onto the next attribute
   );end while
   (command "REGEN")
);end defun
« Reply #1 on: April 11, 2004, 09:02:04 AM »
hyposmurf
Just to look at this from another perspective.
The Library code < second code block > is just that ; a group of generic modules, each to do a specific single task.
This method allows your function to be written with a smaller footprint and be error trapped and reasonably easy to read and test.
... and the library stuff can be re-used in the next function you write.
(setq kbsg:activedoc (vla-get-activedocument (vlax-get-acad-object)))
(defun c:matchblocks (/ *error* master clone)
  (defun *error* (msg /) (kbsl_on-error msg))
  (vla-endundomark kbsg:activedoc)
  (vla-startundomark kbsg:activedoc)
  (setq master (car (kbsl_entsel "Select Master block" nil nil (list "INSERT") nil t))
        clone  (car (kbsl_entsel "Select block to update" nil nil (list "INSERT") nil t))
  (kbsl_setattributes (vlax-ename->vla-object clone)
                      (kbsl_getattributelist (vlax-ename->vla-object master))
  (*error* nil)
LIBRARY CODE
;;; kwb 20021103
;;; kbsl_entsel (msg kwd def typelist selectflag lockflag
;;; Arguments:
;;; msg : The prompt string.
;;; kwd : Initget keywords string.
;;; def : Value to return if response is <enter>.
;;; typelist  : Stringlist of entity types allowed for selection. If nil select anything.
;;; selectflag : If true nentsel permitted , otherwise use entsel.
;;; lockflag  : If true dont allow selection from locked layers.
;;; Note : Arguments may be set to nil
;;; Return output from (n)entsel, a key word, the default argument, or nil.
;; example1 : (kbsl_EntSel "Select Arc Object" nil nil (list "ARC" "CIRCLE") nil T)
;;  ==>  (<Entity name: 40bcd540> (-28175.1 154575.0 1250.0))
;; example2 : (kbsl_EntSel "Select Datum Line" nil nil (list "LINE") T T) ; line in block
;;  ==>  (<Entity name: 4022c680> (-21613.1 142392.0 0.0)
;;  ((70.0 0.0 0.0) (0.0 70.0 0.0) (0.0 0.0 70.0) (-21611.9 142635.0 0.0))
;;          (<Entity name: 4022c6b8>)  )
(defun kbsl_entsel (msg kwd def typelist selectflag lockflag / pickok returnvalue tmp)
  (setq msg (strcat "\n"
                    (cond (msg)
                          ("Select object")
  (while (not pickok)
    (setvar "ERRNO" 0)
    (if kwd
      (initget kwd)
    (setq returnvalue (if selectflag
                        (nentsel msg)
                        (entsel msg)
      ((= (getvar "ERRNO") 52)     ; enter
       (if def
         (setq returnvalue def)
       ;; skip out
       (setq pickok t)
      ((= (getvar "ERRNO") 7) (princ "Nothing found at selectedpoint. "))
      ((= (type returnvalue) 'str) (setq pickok t)) ; keyword
      ((and (setq tmp (entget (car returnvalue))) ; object type
            typelist
            (not (member (cdr (assoc 0 tmp)) (mapcar 'strcase typelist)))
       )                           ; wrong type
       (alert (strcat "Selected object is not"
                      "\na "
                      (apply 'strcat
                             (cons (car typelist)
                                   (mapcar '(lambda (x) (strcat "\nor " x)) (cdr typelist))
      ((and lockflag               ;Locked Layer Not Permitted
            (setq                  ;layer name
              tmp (entget (tblobjname "LAYER" (cdr (assoc 8 tmp))))
            (= (logand 4 (cdr (assoc 70 tmp))) 4) ;is layer locked
       (princ "Selected object is on a locked layer. ")
      ;; skip out
      ((setq pickok t))
  returnvalue
(defun kbsl_on-error (msg / tmp)
  ;;----- Cancel any Active Commands -----------------------------
  (while (< 0 (getvar "cmdactive")) (command))
  (setvar "menuecho" 1)
  ;;----- Display error message if applicable _-------------------
  (cond ((not msg))                ; no error, do nothing
        ((member (strcase msg t)   ; cancel
                 '("console break" "function cancelled" "quit / exit abort")
        ((princ (strcat "\nApplication Error: " (itoa (getvar "errno")) " :- " msg)))
  (setvar "errno" 0)
  ;;----- Display backtrace if in debug mode ---------------------
  (if kbsg:debug_on
    (vl-bt)
  ;;----- Release Bound Activex Objects --------------------------
  (foreach varname kbsg:objectsbound
    (if (= (type (setq tmp (vl-symbol-value varname))) 'vla-object)
      (if (not (vlax-object-released-p tmp))
        (progn (vlax-release-object tmp) (set varname nil))
  ;;----- Reset System Variables from global list ----------------
  (foreach item kbsg:sysvarlist (setvar (car item) (cadr item)))
  (setq kbsg:sysvarlist nil
        kbsg:objectsbound nil
(defun kbsl_getattributelist (blockref / catchit returnval)
  (if (vl-catch-all-error-p
        (setq catchit (vl-catch-all-apply 'vlax-invoke (list blockref 'getattributes)))
    (alert (vl-catch-all-error-message catchit))
    ;; else
    (setq
      returnval (mapcar '(lambda (attref)
                           (cons (vla-get-tagstring attref) (vla-get-textstring attref))
                        catchit
  returnval
(defun kbsl_setattributes (blockref dotlist / catchit attval)
    ;; else
    (progn (mapcar '(lambda (attref)
                      (if (setq attval (cdr (assoc (vla-get-tagstring attref) dotlist)))
                        (vla-put-textstring attref attval)
                   catchit
           (vla-update blockref)
