Author Topic: How do you delete a LayerState?  (Read 5867 times)
Re: How do you delete a LayerState?
« Reply #15 on: September 11, 2006, 05:21:46 PM »
How do I find that?
In the help, developers guide, VBA ActiveX reference, objects, LayerStateManager
« Reply #16 on: September 11, 2006, 05:24:18 PM »
Here's a quick example for 2007:
Sub LS_test()
    Dim oLSM As AcadLayerStateManager
    Set oLSM = ThisDrawing.Application. _
       GetInterfaceObject("AutoCAD.AcadLayerStateManager.17")
    oLSM.SetDatabase ThisDrawing.Database
    On Error Resume Next
    oLSM.Delete "abcd"
    If Err Then
        MsgBox "Layerstate not found...."
        Err.Clear
    Else
        ThisDrawing.Utility.Prompt vbCr & "Layerstate {abcd} deleted."
    End If
End Sub
David Hall
  • Automatic Duh Generator
« Reply #17 on: September 11, 2006, 05:27:10 PM »
Thanks Jeff.  I haven't used the ThisDrawing.Application area much.  I need to explore that area.
T.W. - does it tell you where its found in code? (I haven't looked it up yet)  Looking in the developer guide is great only if it tells you where to find it in the IDE
Matersammichman
« Reply #18 on: September 12, 2006, 07:39:35 AM »
You guys have been such a great help to me, let me share this.
What I wanted to do was create a LayerState named "Temp" that I could save, and overwrite as needed. Here is the completed blurb of code in ADT2005)
Private Sub cmdTLS_Click()
    Dim colLayers As AcadLayers
    Dim objDict As AcadDictionary
    Dim objLayerStates As AcadDictionary
    Dim objXrec As AcadXRecord
    Set colLayers = ThisDrawing.Layers
    If colLayers.HasExtensionDictionary Then
       Set objDict = colLayers.GetExtensionDictionary
       Set objLayerStates = objDict("Acad_LayerStates")
       objLayerStates("temp").Delete
   End If
    ' Access the LayerStateManager object
       GetInterfaceObject("AutoCAD.AcadLayerStateManager.16")
    ' Associate the current drawing database with LayerStateManager
oLSM.Save "Temp", acLsOn + acLsFrozen + acLsLocked
Me.hide
End Sub
« Last Edit: September 12, 2006, 09:44:03 AM by CmdrDuh »
