Author Topic: How do you delete a LayerState?  (Read 6331 times)
Matersammichman
« on: September 07, 2006, 12:08:44 PM »
I have a named LayerState (Temp).
How can I make vba delete this?
David Hall
  • Automatic Duh Generator
Re: How do you delete a LayerState?
« Reply #1 on: September 07, 2006, 12:33:29 PM »
i dont think you can.  From what I remember, LayerStates are not exposed to VBA
DaveW
« Reply #2 on: September 07, 2006, 12:38:40 PM »
You can automate it via the command line.
You can bring up the layer manager, then sendkeys, the letter "r" will open the state manager.
Once inside tere you can access the commands with alt and sndkeys, as the letters are underlined.
Should work.
« Reply #3 on: September 07, 2006, 12:40:02 PM »
Here is how I got a list of them in lisp (ActiveX) which I think you can make into VBA pretty easliy
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq LayCol (vla-get-Layers ActDoc))
(setq LayDict (vla-GetExtensionDictionary LayCol))
(setq LayStDict (vl-catch-all-apply 'vla-Item (list LayDict "ACAD_LAYERSTATES")))
If 'LayStDict' isn't an error, then you have layer states in the current drawing.  Hope that helps.
DaveW
« Reply #4 on: September 07, 2006, 12:46:10 PM »
Quick stab at the command line one:
Public Sub DeleteLaterStateTemp()
        ThisDrawing.SendCommand "-layer" & vbCr
        ThisDrawing.SendCommand "a" & vbCr
        ThisDrawing.SendCommand "d" & vbCr
        ThisDrawing.SendCommand "temp" & vbCr & vbCr & vbCr
End Sub
SomeCallMeDave
« Reply #5 on: September 07, 2006, 10:25:00 PM »
This seems to work in v2004.  Maybe it will help
Public Sub DelLayerState()
    Dim colLayers As AcadLayers
    Dim objDict As AcadDictionary
    Dim objLayerStates As AcadDictionary
    Dim objXrec As AcadXRecord
    Set colLayers = Me.Layers
    If colLayers.HasExtensionDictionary Then
       Set objDict = colLayers.GetExtensionDictionary
       Set objLayerStates = objDict("Acad_LayerStates")
       objLayerStates("temp").Delete
   End If
End Sub
Needs more error checking and hasn't been fully tested
« Last Edit: September 07, 2006, 10:27:29 PM by SomeCallMeDave »
DaveW
« Reply #6 on: September 07, 2006, 11:03:23 PM »
Nice!
Matersammichman
« Reply #7 on: September 08, 2006, 08:50:39 AM »
Dave,
Thanks for the help, but... Vba choked on "Me.Layers"
ideas?
SomeCallMeDave
« Reply #8 on: September 08, 2006, 09:01:21 AM »
Try
ThisDrawing.Layers
Matersammichman
« Reply #9 on: September 11, 2006, 04:17:33 PM »
Worked beautifully!
Thanks!
David Hall
« Reply #10 on: September 11, 2006, 04:40:13 PM »
Learn something everyday!!!
David Hall
« Reply #11 on: September 11, 2006, 04:40:55 PM »
So my question is can you create a layerstate through code?
« Reply #12 on: September 11, 2006, 04:52:10 PM »
Look into the LayerStateManager object.......saves from having to mess with Dictionaries, it does all the work for you.
David Hall
« Reply #13 on: September 11, 2006, 05:07:37 PM »
I cant get the delete part to work in 07
    Set colLayers = ThisDrawing.Layers
       Set objLayerStates = objDict("ACAD_LAYERFILTERS")
       objLayerStates("adf").Delete
   End If
End Sub
David Hall
« Reply #14 on: September 11, 2006, 05:08:12 PM »
How do I find that?
