Author Topic: VBA Macros and Toolbars  (Read 1907 times)
Murphy
« on: September 06, 2006, 12:39:49 PM »
I have just been upgraded to 2006 and now my .mnl files will not work when I try to call a VBA macro.
I posted here because anyone that just works with Lisp may not know the fix.
MNL syntax:
(defun c:PICKME(/)
       (command "vbastmt" "PickMe"))
When I hit the toolbar button I get 'Syntax Error' in the text window.
Has anyone else encountered this and, if so, how did you fix it?
Murphy
Re: VBA Macros and Toolbars
« Reply #1 on: September 06, 2006, 12:59:24 PM »
Instead of deleting this I will post what I found out.
I quit out of Autocad and went back into it.
Everything works fine now.
Rassin, frassin, Autocad!!!
