Get Object Reactor
(1/1)
eachy:
First test
--- Quote ---;;Get Object Reactor by eachy
(defun get_object_reactor (e / elst lst etlst)
(setq elst (entget e))
(if (and (assoc 102 elst)
(= (cdr (assoc 102 elst)) "{ACAD_REACTORS")
(setq lst (cdr (member '(102 . "{ACAD_REACTORS") elst)))
(while (= (caar lst) 330)
(setq etlst (cons (cdar lst) etlst))
(setq lst (cdr lst))
etlst
--- End quote ---
Sample
--- Quote ---;;test object is a member of groups
(defun test (lst / g)
(foreach item (mapcar 'vlax-ename->vla-object lst)
(if (= (vla-get-objectname item) "AcDbGroup")
(setq g (cons (vla-get-name item) g)
g
--- End quote ---
Patrick_35:
Hi
I don't understand what you want ?
A list of object reactors ?
--- Code: ---(setq lst_obj (mapcar 'vlr-owners (cdr (car (vl-remove-if-not '(lambda (x) (eq (car x) :VLR-Object-Reactor)) (vlr-reactors))))))
--- End code ---
Navigation
[0] Message Index
Go to full version
