Author Topic: an old dog needs a new trick  (Read 3026 times)
Jim Yadon
« on: September 04, 2006, 12:19:31 PM »
This was originally written before the 'Garden Path' tutorial was made available to me. I am sure there is a much more elegant way to go about this. The layer control calls will need to be commented out prior to anyone trying to use this.
I already have some ideas for refining a few things but I wanted to submit it for speculation by you wizards before proceeding with any more changes.
I seem to be missing the finer points on a few things with LISP so here is a list of what I am lacking the skill to handle -
  • passing variables between subroutines
  • handling and escape form the command
  • ghosting of the viewport outline for placement in paper space
  • some other functionality of LISP I could use to accomplish this?
Once complete, I already have a menu, tool bar & pallette that go with the code that I can post in our collection.
; originally written by Jim Yadon in 1996
; hastily rewritten by Jim Yadon in 2004
; use at your own risk
(defun viewport_root_tool()
  (setq cl (getvar "clayer"))
  (setvar "tilemode" 1)
  (setq pnt1 (getpoint "\nWindow around objects for viewport:  "))
  (setq pnt2 (getcorner pnt1 "\nSelect other corner:  "))
  (setq vportsize
(list
   (* (+ (- (car pnt2) (car pnt1)) buffer2) scale1)
   (* (+ (- (cadr pnt2) (cadr pnt1)) buffer2) scale1)
  (setvar "tilemode" 0)
  ;(viewport_layer)
  (setq pnt3 (getpoint "\nSelect insertion point for viewport:  "))
  (setq pnt4 (list (+ (car pnt3) (car vportsize))
   (+ (cadr pnt3) (cadr vportsize))
  (command "mview" pnt3 pnt4)
  (command "mspace")
  (command "view" "ortho" "top")
  (command "shademode" "2d")
  ;(command "vplayer" "freeze" layoutlayer "current" "")
  (command "zoom" pnt1 pnt2)
  (command "zoom" "s" scale2)
  (command "layer" "s" cl "")
  (cvplockall)
  ;(viewport_layer_off)
  (command "pspace")
(defun c:vpa ();vport that zooms all
  (setq ccmde (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  ;(viewport_layer)
  (setq pnt1 (getpoint "\nSelect starting point:  "))
  (setq pnt2 (getcorner pnt1 "\nSelect finishing point:  "))
  (command "mview" pnt1 pnt2)
  (command "mview" "lock" "on" "last" "")
  (setvar "cmdecho" ccmde)
(defun c:vp1 ();vport that zooms to full scale
  (setq scale1 1)
  (setq scale2 "1xp")
  (setq buffer1 12.7)
  (setq buffer2 (/ buffer1 scale1))
  (viewport_root_tool)
(defun c:vp2 ();vport that zooms to 6" scale
  (setq scale1 0.5)
  (setq scale2 "0.5xp")
  (setq buffer1 12.7)
(defun c:vp3 ();vport that zooms to 3" scale
  (setq scale1 0.25)
  (setq scale2 "0.25xp")
  (setq buffer1 12.7)
(defun c:vp4 ();vport that zooms to 1 1/2" scale
  (setq scale1 0.125)
  (setq scale2 "0.125xp")
  (setq buffer1 12.7)
(defun c:vp5 ();vport that zooms to 1" scale
  (setq scale1 0.08333333333)
  (setq scale2 "0.08333333333xp")
  (setq buffer1 12.7)
(defun c:vp6 ();vport that zooms to 3/4" scale
  (setq scale1 0.0625)
  (setq scale2 "0.0625xp")
  (setq buffer1 12.7)
(defun c:vp7 ();vport that zooms to 1/2" scale
  (setq scale1 0.041666666667)
  (setq scale2 "0.041666666667xp")
  (setq buffer1 12.7)
(defun c:vp8 ();vport that zooms to 3/8" scale
  (setq scale1 0.03125)
  (setq scale2 "0.03125xp")
  (setq buffer1 12.7)
(defun c:vp9 ();vport that zooms to 1/4" scale
  (setq scale1 0.020833333333)
  (setq scale2 "0.020833333333xp")
  (setq buffer1 12.7)
(defun c:vp10 ();vport that zooms to 3/16" scale
  (setq scale1 0.015625)
  (setq scale2 "0.015625xp")
  (setq buffer1 12.7)
(defun c:vp11 ();vport that zooms to 1/8" scale
  (setq scale1 0.010416666667)
  (setq scale2 "0.010416666667xp")
  (setq buffer1 12.7)
(defun c:vp12 ();vport that zooms to 1/16" scale
  (setq scale1 0.005208333333)
  (setq scale2 "0.005208333333xp")
  (setq buffer1 12.7)
(defun c:vp13 ();vport that zooms to 1/32" scale
  (setq scale1 0.002604166667)
  (setq scale2 "0.002604166667xp")
  (setq buffer1 12.7)
(defun c:vp14 ();vport that zooms 1/64" scale
  (setq scale1 0.001302083333)
  (setq scale2 "0.001302083333xp")
  (setq buffer1 12.7)
;This section was refined from some tools found at the www.theswamp.org
; unlock all vp & set color to green  06/07/04
(defun c:vpunlockall ()
  ;(viewport_layer_on)
  (cvpunlockall)
(defun cvpunlockall()
 (vlax-for lay
               (vla-get-layouts
                 (vla-get-activedocument
                   (vlax-get-acad-object)
   (if (eq :vlax-false (vla-get-modeltype lay))
     (vlax-for ent (vla-get-block lay) ; for each ent in layout
       (if (= (vla-get-objectname ent) "AcDbViewport")
           (vla-put-displaylocked ent :vlax-false)
           (vla-put-color ent 3); 3 green
 (prompt "\n***  All viewports are UnLocked  ***")
;;  lock all vp and set color to red  06/07/04
(defun c:vplockall ()
  (cvplockall)
(defun cvplockall()
 (vlax-for lay
               (vla-get-layouts
           (vla-put-displaylocked ent :vlax-true)
           (vla-put-color ent 1);1 red
 (prompt "\n***  All viewports are Locked  ***")
;end of view port tools from the Swamp
(defun c:vplon ()
  (cvplockall)
(defun c:vploff ()
  (cvplockall)
(defun c:vpulon ()
  (cvpunlockall)
(defun c:vpuloff ()
  (cvpunlockall)
(princ "\nViewport tools have been loaded.")
edit by JAY - commented out the layer control code that could cause a burp
« Last Edit: September 05, 2006, 07:39:19 PM by JAY »
Jim Yadon
Re: an old dog needs a new trick
« Reply #1 on: September 05, 2006, 07:18:55 PM »
 :? hmmm... no takers?
« Reply #2 on: September 05, 2006, 07:36:03 PM »
How much are you planning on rewriting? and how much to you want to simplify calls?  I can help tomorrow, or maybe tonight, but I don't have cad at home so I can't test anything.
« Reply #3 on: September 05, 2006, 07:44:05 PM »
You will also need to include all of your subroutines. I do not see (viewport_layer) in your post.
Jim Yadon
« Reply #4 on: September 05, 2006, 09:14:20 PM »
I commented out the view port layer routine in the code example. That's a legacy item that is called and some of the code is not mine to post.
I am actually going to integrate a windowing feature that allows for selection of the window from any crossing points rather than the lower-left to upper-right that it's set up for. I am really looking for some ideas from you guys how to improve what's there while keeping that basic command call structure intact. I currently have somewhere in the neighborhood of 75 people using this and don't want to break other things that link to it.
« Reply #5 on: September 06, 2006, 03:01:43 PM »
I would change it like this. One real code change, and then the others just change how the call the one code that did change.
(defun viewport_root_tool(scale1 buffer1 / cl pnt1 pnt2 vportsize pnt3 pnt4 ccmde)
  (setq vportsize
(list
   (* (+ (- (car pnt2) (car pnt1)) (/ buffer1 scale1)) scale1)
   (* (+ (- (cadr pnt2) (cadr pnt1)) (/ buffer1 scale1)) scale1)
  ;(viewport_layer)
  (command "mspace")
  (command "zoom" "s" (strcat (rtos scale1 1 16) "xp"))
  (cvplockall)
  (command "pspace")
Then the ones that call it, change like so
  (viewport_root_tool 1 12.7)
  (viewport_root_tool 0.5 12.7)
Is this the type of thing you were looking for?
Jim Yadon
« Reply #6 on: September 06, 2006, 11:11:05 PM »
Cool T.W. It looks great. I'll put it through the paces while I draw this next job. That streamlines several things that were otherwise cumbersome.
« Reply #7 on: September 07, 2006, 01:03:04 AM »
You're welcome.  Just happy to help.
