Author Topic: P/Invoke acedSetVar  (Read 5340 times)
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
P/Invoke acedSetVar
« on: August 29, 2006, 04:11:55 PM »
Acad 2005
Can anyone see what I'm doing wrong?  The call to acedSetVar is returning -5001, and the MODEMACRO value doesn't change.  Thanks.
    [DllImport("acad.exe", CallingConvention=CallingConvention.Cdecl,  CharSet=CharSet.Auto)]
    public static extern int acedSetVar(string variableName, IntPtr value);
    public static void SetModeMacro(string value)
      ResultBuffer val = new ResultBuffer(new TypedValue((short)DxfCode.Text, value));
      int retval = acedSetVar("MODEMACRO", val.UnmanagedObject);
      Autodesk.AutoCAD.ApplicationServices.CommandLinePrompts.Message(retval.ToString());
« Last Edit: August 29, 2006, 04:16:27 PM by Bobby C. Jones »
Bobby C. Jones
MickD
Re: P/Invoke acedSetVar
« Reply #1 on: August 29, 2006, 06:18:10 PM »
I've noticed with some imports that they require the mangled name of the exported arx function, maybe this is the case here??
J.R.R. Tolkien
Glenn R
« Reply #2 on: August 29, 2006, 07:06:27 PM »
The compiler mangled name in 2006:
?acedSetVarFromBag@@YAHPBDPBUresbuf@@@Z
Dumpbin that ships with Visual studio will do this. Fire a Visual studio command prompt and change to acad folder.
Then type in: Dumpbin /EXPORTS "YourpathToAcad.exeHere" >> "C:\Temp\AcadExports.txt". Once you have the exported exports :D
just search the file for what you need.
Hope this helps.
Cheers,
Glenn.
« Reply #3 on: August 29, 2006, 07:08:33 PM »
<deleted>
Glenn beat me to it .. :lol:
Draftek
« Reply #4 on: August 30, 2006, 08:38:17 AM »
I've been playing with some late binding, Interop and Reflection.
This will work. (You don't need an Interop reference to Autocad since late binding is used:
            object[] parameters;
            object acadapp = null;
            object cmd = null;
            object dwg = null;
            acadapp = (object)Marshal.GetActiveObject("AutoCAD.Application");
            dwg = acadapp.GetType().InvokeMember("ActiveDocument",
                        BindingFlags.GetProperty, null, acadapp, null);
            string sTemp = "(Command " + @"""" + "MODEMACRO" + @"""" + " " + @"""" +
                        value + @"""" + " )" + "\r";
            parameters = new object[1];
            parameters[0] = sTemp;
            cmd = dwg.GetType().InvokeMember("SendCommand",
                BindingFlags.InvokeMethod, null, dwg, parameters);
I'd be interested in opinions as to which method to use.
Bobby C. Jones
« Reply #5 on: August 30, 2006, 09:55:29 AM »
I see both exports, but both give the same result :-(
    [DllImport("acad.exe", EntryPoint = "?acedSetVarFromBag@@YAHPBDPBUresbuf@@@Z", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Auto)]
Any other ideas?  Thanks.
Bobby C. Jones
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #6 on: August 30, 2006, 12:58:20 PM »
[CommandMethod("TEST")]
static public void test()
      SetModeMacro("12345");
// From adscodes.h :
const int RTSTR      = 5005; /* String */
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Ansi)]
      ResultBuffer val = new ResultBuffer(new TypedValue(RTSTR, value));
I think you can find yourself errors in yours code... :-)
« Last Edit: August 30, 2006, 12:59:33 PM by Alexander Rivilis »
Bobby C. Jones
« Reply #7 on: August 30, 2006, 01:34:23 PM »
CharSet.Ansi
const short RTSTR = 5005;
That did it.  Thank you Alexander.
Bobby C. Jones
Alexander Rivilis
« Reply #8 on: August 30, 2006, 01:36:38 PM »
