Author Topic: Delete Objects on Layers from List  (Read 8677 times)
Re: Delete Objects on Layers from List
« Reply #30 on: August 28, 2006, 05:22:42 PM »
I'm looking into this right now.
« Reply #31 on: August 28, 2006, 05:37:38 PM »
This works now.  I tested it.  Sorry about that.
(defun DeletLays_ExplodeBlk (Doc LayList BlkList / cnt)
(defun ExplodeList (ObjList BlkList / NewObjList)
(foreach Obj ObjList
  (and
   (= (vla-get-ObjectName Obj) "AcDbBlockReference")
   (vl-position
    T
    (mapcar
     '(lambda (y)
      (wcmatch (strcase (vla-get-Name Obj)) (strcase y))
     BlkList
   (vl-catch-all-error-p
    (setq NewObjList (vl-catch-all-apply 'vlax-invoke (list Obj "Explode")))
   (setq cnt (1+ cnt))
    (vla-Delete Obj)
    (ExPlodeList NewObjList BlkList)
(setq cnt 0)
(vlax-for Lo (vla-get-Layouts Doc)
 (vlax-for Obj (vla-get-Block Lo)
   ((vl-position T (mapcar '(lambda (x) (wcmatch (strcase (vla-get-Layer Obj)) (strcase x))) LayList))
    (vla-Delete Obj)
   ((and
     (vl-position
      T
      (mapcar
       '(lambda (y)
        (wcmatch (strcase (vla-get-Name oBJ)) (strcase y))
       BlkList
     (setq cnt (1+ cnt))
      (vla-Delete Obj)
LE
« Reply #32 on: August 28, 2006, 05:40:45 PM »
(defun c:tst  (/ ss)
  (if (setq ss
     (ssget
       (list (cons 8 "A-ARE*,A-DIM*,A-NOT*,A-PAT*,A-SHT*,A-SYM*")
     (cons 2 "UT*"))))
      (setvar "qaflags" 1)
      (command "_.explode" ss "")
      (setvar "qaflags" 0))))
GDF
« Reply #33 on: August 28, 2006, 05:41:52 PM »
(vlar-yourwelcome Gary)
Not sure if it will work with ObjectDBX though
Alan
I tried this also. Works now with the qaflags (as per Luis suggestion)
(defun exp_on_layer (layers / ss)
  (if (setq ss (ssget "_all" (list (cons 8 layers))))
    (vl-cmdf "_.explode" ss "")
(defun del_on_layer (layers / ss)
    (vl-cmdf "_.erase" ss "")
(defun C:TEST ()
  (exp_on_layer "0-XREF")
  (del_on_layer "A-ALT-WIND-2,A-ALT-WIND-3,A-ARE*,A-DIM*,A-NOT*,A-PAT*,A-SYM*,A-SHT*,DEF*,0-XREF,*NOTE")
Gary
GDF
« Reply #34 on: August 28, 2006, 05:51:23 PM »
Works great now...you da man.
Thank you. I like this version over Alan's because it can be used by objectdbx.
Anyway, I still have to fine tone it and add in the objectdbx code. Will post it
when I get it all togeher.
This routine is a big time saver.
I can now put up my "easy" button and get back to work.
Gary
« Reply #35 on: August 28, 2006, 05:56:45 PM »
Gary
Happy to help.  :wink:
