Author Topic: Delete Objects on Layers from List  (Read 8684 times)
GDF
« on: August 28, 2006, 11:21:40 AM »
Ok, you mapcar foreach wildcard gurus, I have a request.
I would like to take the following code below and modify it to delete layers from a wildcard list
like the following:
(setq layer_name (list "A-DIM*,A-NOT*,A-SYM*"))
;;;original code by Fatty
(defun C:DELL  (/ ent acapp acsp adoc allrs layer_name)
  ;;(setq layer_name (getstring t "\n* Enter Layer name to Delete : "))
  ;;(setq ent (entsel) layer_name (cdr (assoc 8 (entget (CAR ent)))))
  (setq acapp (vlax-get-acad-object)
        adoc  (vla-get-activedocument acapp)
        acsp  (vla-get-block (vla-get-activelayout adoc))
        allrs (vla-get-layers adoc))
  (vlax-for
         lt  (vla-get-layouts adoc)
    (vlax-for
           ob  (vla-get-block lt)
      (if (eq (vla-get-layer ob) layer_name)
        (progn (if (eq (vla-get-freeze (vla-item allrs (vla-get-layer ob))) :vlax-true)
                 (vla-put-freeze (vla-item allrs (vla-get-layer ob)) :vlax-false))
               (if (eq (vla-get-lock (vla-item allrs (vla-get-layer ob))) :vlax-true)
                 (vla-put-lock (vla-item allrs (vla-get-layer ob)) :vlax-false))
               (if (eq (vla-get-layeron (vla-item allrs (vla-get-layer ob))) :vlax-false)
                 (vla-put-layeron (vla-item allrs (vla-get-layer ob)) :vlax-true))
               (vla-delete ob)
               (vlax-release-object ob)))))
  (vla-regen adoc acallviewports)
  (princ))
I'm not lazy, just lisp impaired...
Gary
Re: Delete Objects on Layers from List
« Reply #1 on: August 28, 2006, 11:29:30 AM »
I didn't look at the code, it is easier to write one to suit your needs.
(defun DeletObjLays (Doc LayList)
(vlax-for Lo (vla-get-Layouts Doc)
 (vlax-for Obj (vla-get-Block Lo)
  (if (vl-position T (mapcar '(lambda (x) (wcmatch (strcase (vla-get-Layer Obj)) (strcase x))) LayList))
   (vla-Delete Obj)
Called like (for current drawing, not case specific)
(DeleteObjLays (vla-get-ActiveDocument (vlax-get-Acad-Object)) '("A-dims*" "a-not*))
EDIT: The formatting fairy strikes again
« Last Edit: August 28, 2006, 12:19:01 PM by nivuahc »
GDF
« Reply #2 on: August 28, 2006, 11:41:25 AM »
Thanks. That was easier than hitting my "easy" button.
Works perfectly
(DeletObjLays (vla-get-ActiveDocument (vlax-get-Acad-Object)) '("A-DIM*" "A-NOT*" "A-SYM*"))
Gary
« Reply #3 on: August 28, 2006, 11:47:23 AM »
You're welcome.  :-D
GDF
« Reply #4 on: August 28, 2006, 12:11:47 PM »
One more request.
In a related routine I want to xplode blocks from a wildcard list
similar to the routine you provided. Can this be done?
Once I have all of the pieces together I will post what I am
doing.
Gary
« Reply #5 on: August 28, 2006, 12:18:18 PM »
One more request.
doing.
Gary
It can be unless they are NUS.  Here is what you want.
(defun ExplodeBlkList (Doc BlkList / cnt)
(setq cnt 0)
    (= (vla-get-ObjectName Obj) "AcDbBlockReference")
    (vl-position T (mapcar '(lambda (x) (wcmatch (strcase (vla-get-Name Obj)) (strcase x))) BlkList))
   (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-Explode (list Obj)))
    (setq cnt (1+ cnt))
(prompt (strcat "\n " (itoa cnt) " were not able to be exploded."))
Call the same way.  I think it should work, haven't tested it.
GDF
« Reply #6 on: August 28, 2006, 12:36:35 PM »
Yes it works. Thanks again.
Here is what I am trying to do. We have a building plan that has multiple unit plan xrefs in it.
We are asked to provide a CAD background files for the client. These files need to be bind
inserted with all unnessary layers deleted. The bind inserted blocks are the "UT*"
This is still a work in progress, no error checking, etc.
(defun C:XXX  ()
;;;by Tim Willey 8/24/06
(defun ReloadBindXrefs (Doc / XrefList LstLen TroubleList)
  (vlax-for
Blk  (vla-get-Blocks Doc)
    (if (= (vla-get-IsXref Blk) :vlax-true)
(if (vl-catch-all-error-p (vl-catch-all-apply 'vla-Reload (list Blk)))
  (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-Detach (list Blk)))
    (setq TroubleList (cons Blk TroubleList))
    (prompt (strcat "\n Detached xref: " (vla-get-Name Blk))))
  (progn (vla-Bind Blk :vlax-true)
(if (and (= (vla-get-IsXref Blk) :vlax-true)
  (not (vl-position (vla-get-Name Blk) XrefList)))
   (setq XrefList (cons Blk XrefList))))))))
  (setq LstLen (length XrefList))
  (while (and (> LstLen 0) (> LstLen (setq LstLen (length XrefList))))
    (foreach
   Blk XrefList
      (if (or (= (vla-get-IsXref Blk) :vlax-false)
      (and (vla-Bind Blk :vlax-true) (= (vla-get-IsXref Blk) :vlax-true)))
(setq XrefList (vl-remove Blk XrefList)))))
  (foreach
Blk  (append XrefList TroubleList)
    (prompt (strcat "\n Unable to bind xref: " (vla-get-Name Blk))))
  (princ))
;;;by Tim Willey 8/28/06
    (vlax-for
      (vlax-for
  (vl-position
    T
    LayList))
   (vla-Delete Obj))))
    (princ))
  (setq cnt 0)
  (vlax-for
    (vlax-for
(and (= (vla-get-ObjectName Obj) "AcDbBlockReference")
     (vl-position
       T
       BlkList)))
   (setq cnt (1+ cnt)))))
    (princ)))
  (ReloadBindXrefs (vla-get-ActiveDocument (vlax-get-Acad-Object)))
  (ExplodeBlkList
  '("UT*"))
  (DeletObjLays
    '("*A-ARE*" "*A-DIM*" "*A-NOT*" "*A-PAT*" "*A-SYM*"))
  (princ))
Gary
« Reply #7 on: August 28, 2006, 12:40:52 PM »
All of those can be called with an ObjectDBX document if you want Gary.  Hope they all work the way you want them to.
Edit:  If speed is an issue, I would combind the two I just gave you, as they both step through each object in each space.  Might as well only do that once, instead of two seprate times.
« Last Edit: August 28, 2006, 12:43:09 PM by T.Willey »
GDF
« Reply #8 on: August 28, 2006, 12:48:03 PM »
Yes, that will be my next stage. I can handle that one, will post when it is ready.
I just noticed that when I have multiple xrefed unit plans that have been bound
within the building plan do not all get exploded when the have the same name.
For example the building plan has within it: first, second and third floors (not on top of
each other of course, but located within the same file "x" distance away)
All of these bound unit plans need to be exploded so that all of the wildcard layers
can be removed.
Gary
Gary
« Reply #9 on: August 28, 2006, 12:58:47 PM »
That problem is because of nesting.  I think I can come up with a way to do that.  Give me a minute.
« Reply #10 on: August 28, 2006, 01:01:34 PM »
For those who don't mind using a command.
(del_on_layer "A-DIM*,A-NOT*,A-SYM*")
  ;;  layers is a string containing layers
  ;;  ignores case & excepts wild cards
This honers locked layers but not frozen layers.
(defun del_on_layer (layers / ss)
  (if (setq ss (ssget "_X" (list (cons 8 layers))))
    (vl-cmdf "_.erase" ss "")
This one honers locked & frozen layers
  (if (setq ss (ssget "_all" (list (cons 8 layers))))
« Reply #11 on: August 28, 2006, 01:14:14 PM »
Here you go Gary.  I combined them both.  Now it will check for nested blocks also.  I'm not sure about Locked layers (good point Alan) and this routine, if it is a problem, then it can be fixed easily.
(defun DeletLays_ExplodeBlk (Doc LayList BlkList / cnt)
(defun ExplodeList (ObjList BlkList / NewObjList)
(mapcar
 '(lambda (x)
    (= (vla-get-ObjectName x) "AcDbBlockReference")
    (vl-position (strcase (vla-get-Name x)) (mapcar 'strcase BlkList))
      (setq NewObjList (vla-catch-all-apply 'vlax-invoke (list x "Explode")))
    (setq cnt (1+ cnt))
    (ExPlodeList NewObjList BlkList)
(setq cnt 0)
   ((vl-position T (mapcar '(lambda (x) (wcmatch (strcase (vla-get-Layer Obj)) (strcase x))) LayList))
    (vla-Delete Obj)
   ((and
     (setq cnt (1+ cnt))
GDF
« Reply #12 on: August 28, 2006, 02:31:13 PM »
I get an unbalanced closing bracket.
And this gives me a syntax error
    (mapcar
      '(lambda (x)
(if (and (= (vla-get-ObjectName x) "AcDbBlockReference")
  (vl-position (strcase (vla-get-Name x)) (mapcar 'strcase BlkList)))
       (setq NewObjList (vla-catch-all-apply 'vlax-invoke (list x "Explode")))))
   (setq cnt (1+ cnt))
   (ExPlodeList NewObjList BlkList))))) ;(princ))
  (setq cnt 0)
  (vlax-for
    (vlax-for
((vl-position
   T
   LayList))
(vla-Delete Obj))
((and (= (vla-get-ObjectName x) "AcDbBlockReference")
   (setq cnt (1+ cnt))
   (ExPlodeList NewObjList BlkList))))))
  (princ))
Gary
GDF
« Reply #13 on: August 28, 2006, 02:47:48 PM »
Alan
vla-Thanks, I like it. I may have to use this one.
Gary
« Last Edit: August 28, 2006, 02:49:36 PM by Gary Fowler »
« Reply #14 on: August 28, 2006, 02:51:36 PM »
Sorry about that Gary.  I didn't finish one part of the code.  This should work.
(mapcar
 '(lambda (x)
    (setq cnt (1+ cnt))
  ObjList
(setq cnt 0)
    (vla-Delete Obj)
   ((and
     (setq cnt (1+ cnt))
