Hi Alls,
I have a problem to find/search area a rectangular in xref,now we back
to original drawing(not xref),it that a rectangular,then you check by "list" command
here that data
Command: _list
Select objects: 1 found
Select objects:
LWPOLYLINE Layer: "0"
Space: Model space
Handle = 8E
Closed
Constant width 0.0000
area 10000.0000
perimeter 400.0000
at point X= 0.0000 Y= 0.0000 Z= 0.0000
at point X= 100.0000 Y= 0.0000 Z= 0.0000
at point X= 100.0000 Y= 100.0000 Z= 0.0000
at point X= 0.0000 Y= 100.0000 Z= 0.0000
; use active system
(setq ss (ssget "x")) ; <Selection set: a>
(setq ssn (ssname ss 0)) ; <Entity name: 6e772f38>
(setq vveo (vlax-ename->vla-object ssn)) ; #<VLA-OBJECT IAcadExternalReference 0f5b2224>
(vlax-dump-object vveo)
; IAcadExternalReference: IAcadExternalReference Interface
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 00b9b5e4>
; Document (RO) = #<VLA-OBJECT IAcadDocument 0f537280>
; Handle (RO) = "A7"
; HasAttributes (RO) = 0
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0f5b3794>
; InsertionPoint = (0.0 0.0 0.0)
; Layer = "0"
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; Name = "Rectangular"
; Normal = (0.0 0.0 1.0)
; ObjectID (RO) = 1853304632
; ObjectName (RO) = "AcDbBlockReference"
; OwnerID (RO) = 1853304056
; Path = "D:\\YBI\\Drawing\\Lat\\Rectangular.dwg"
; PlotStyleName = "Color_1"
; Rotation = 0.0
; TrueColor = #<VLA-OBJECT IAcadAcCmColor 0f5b4a40>
; Visible = -1
; XScaleFactor = 1.0
; YScaleFactor = 1.0
; ZScaleFactor = 1.0
T
_$
; use with lisp
(setq ss (car (entsel "\nSelect a xref object")))
(setq sse (entget ss))
((-1 . <Entity name: 6e772f38>)
(0 . "INSERT")
(330 . <Entity name: 6e772cf8>)
(5 . "A7")
(100 . "AcDbEntity")
(67 . 0) (410 . "Model")
(8 . "0") (62 . 1)
(100 . "AcDbBlockReference")
(2 . "Rectangular")
(10 0.0 0.0 0.0) (41 . 1.0) (42 . 1.0) (43 . 1.0)
(50 . 0.0)
(70 . 0) (71 . 0)
(44 . 0.0) (45 . 0.0)
(210 0.0 0.0 1.0))
_$
(setq enam330 (cdr (assoc 330 sse)))
(setq sse_330 (entget enam330))
((-1 . <Entity name: 6e772cf8>)
(0 . "BLOCK_RECORD")
(330 . <Entity name: 6e772c08>)
(5 . "1F")
(100 . "AcDbSymbolTableRecord")
(100 . "AcDbBlockTableRecord")
(2 . "*Model_Space")
(360 . <Entity name: 6e772d00>)
(340 . <Entity name: 6e772d10>))
_$
