I should have realized that as well...
A quick check will reveal there is no "coordinates" property of a region, probably because a region can have multiple shaped segments, such as arcs, circles, splines and ellipses.
If you need to get the coordinates, you could explode the region, extract the coordinates of the resultant explode, then region the entities again.
