Author Topic: XREF-reload, unload, detach  (Read 7002 times)
CADaver
« on: August 22, 2006, 06:19:46 PM »
I have this old code I've been using for years and today one of our new guys wanted to know if there was a more elegant option for these functions.  My first answer was "Surely", when he then asked "What are they?", I said "I dunno". So I thought I just ask you guys.  Each one functions on the selected XREF's to either reload, unload or detach (no error check) tear 'em up, guys:
(defun c:xre ()
(prompt "\N Select Element in XREF to RELOAD  ")
(xref-loader "reload")
(defun c:xru ()
(prompt "\N Select Element in XREF to UNLOAD  ")
(xref-loader "unload")
(defun c:xrd ()
(prompt "\N Select Element in XREF to DETACH  ")
(xref-loader "detach")
(defun xref-loader ( xref-action / old setlgth co t2 temp blkname)
(command ".undo" "BEGIN")
   (setvar "cmdecho" 0)
      (setq
        old (ssget)
        setlgth (sslength old)
        co -1
        t2 "t"
  (while (boundp 't2)
       (setq
         co (1+ co)
         temp (entget (ssname old co))
         blkname (cdr (assoc 2 temp))
         t2 (ssname old (1+ co))
         (command "-xref" xref-action blkname)
       )      ;; end progn
   )          ;; end while
(setq co (1+ co))
(command ".undo" "END")
Re: XREF-reload, unload, detach
« Reply #1 on: August 22, 2006, 06:21:56 PM »
What is your idea of more elegant?
nivuahc
« Reply #2 on: August 22, 2006, 06:51:40 PM »
Seriously.
I would say it's elegant in its simplicity.
« Reply #3 on: August 22, 2006, 06:57:38 PM »
If you wanted to get it to eliminate the echos to the command line then converting it to use ActiveX is quite simple:
;;add near beginning of xref-loader code
(setq doc (vla-get-activedocument
    (vlax-get-acad-object)))
;(command ".undo" "BEGIN")...change to:
(vla-startundomark doc)
;(command "-xref" xref-action blkname)...change to:
(vlax-invoke
  (vla-item
    (vla-get-blocks
      doc)
    blkname)
  xref-action)
;(command ".undo" "END")...change to:
But consider what Chuck said......
« Last Edit: August 22, 2006, 07:16:27 PM by Jeff_M »
« Reply #4 on: August 22, 2006, 06:59:25 PM »
The only thing I could think of is the use of command.  Take that out, but you don't really gain anything, since you are only using it in the current drawing.
Seriously.
Second.
Guess Jeff thought the same before I could post.
CADaver
« Reply #5 on: August 22, 2006, 10:19:19 PM »
I guess I was looking for something along the lines of Jeff's response with the activeX conversion. (Thanks Jeff)  And the reason it's simple is that 'simple" is all I can do.
LE
« Reply #6 on: August 22, 2006, 10:33:01 PM »
I do not see any control of knowing if the selected item is an xref, or I missing something?
CADaver
« Reply #7 on: August 23, 2006, 06:01:30 AM »
THere's not, there's very little control of anything.  It'll choke if you get a block in the selection set.
« Reply #8 on: August 23, 2006, 06:07:24 AM »
Nothing to do with elegance, but this ;
will work as anticipated like this ;
(prompt "\n Select Element in XREF to RELOAD  ")
{ie: lowercase \n }
Joe Burke
« Reply #9 on: August 23, 2006, 08:55:37 AM »
(vlax-invoke
  (vla-item
    (vla-get-blocks
      doc)
    blkname)
  xref-action)
Hi Jeff,
I believe there's an additional advantage here. It would allow pre-selection of the xref. Whereas (command ".undo" "BEGIN") would deselect any pre-selection.
« Reply #10 on: August 23, 2006, 11:05:28 AM »
I can't believe that no one caught this:
:oops: should be
(vla-endundomark doc)
Joe, that's an excellent point!
CADaver
« Reply #11 on: August 23, 2006, 01:00:52 PM »
ooooo, excellent point.  We have some new guys that use pickfirst the "other" way, while us older hacks are still doing it the old way.  Thanks.
Krushert
  • FREE BEER Tomorrow!!
« Reply #12 on: August 23, 2006, 01:05:15 PM »
hello folks
Recently I barrowed <cough> a piece code from Daron that he posted a while back  REQ: XREF Reload/Open ....
dam it wrong button I wasn't done yet
....which a basically copied and added the unload part in place of the reload.  I get a nasty hick up when I select a non-xref.  To me it is a minor nu sinace, so I live with it.  I would say, have the routine filter out non-xrefs so that it keeps going or be intelligent enough to select the xref that is underneath a piece of geometry.  (Yep using draworder over here).
Daron thanks for your routine. I have been using the hell out of it.   :-D
« Last Edit: August 23, 2006, 01:14:54 PM by Krushert »
CADaver
« Reply #13 on: August 23, 2006, 01:25:47 PM »
hmmm... I don't think I stole the idea from Daron, but I've been known to pinch a bit of code now and then, and if I did, sorry...
... well not really, ... but you know what I mean.... or not....
...how about this; If I did, Thanks Daron.
Krushert
« Reply #14 on: August 23, 2006, 01:39:45 PM »
If you pinch a code does it yell.  sorry bad pun.   :-D
CADaver, sorry  I didnt mean to imply that you stole barrow (or whatver) I did and I did thank him.  <I got the proof>   :-)
