Author Topic: One View Port in my DWG won't Cooperate...  (Read 6513 times)
pochrist
« on: April 03, 2004, 11:29:14 PM »
I have a drawing that has multiple View ports, I used Multiblocks and AEC Elevations / Sections. When I plot the DWG the same Viewport will always plot with a "0" / light line thickness. If I turn on the LWT button (at the bottom of the Acad window) it will display the Line thicnkess fine but will still plot "lightly" I'm baffled the object is a Multiview block in a 3D South east view (useing a Named View). All the other Viewports plot fine. Now I know it's not the Plotter. I Started a New DWG, I imported the Named view, I even put a couple of 3D solids and 2D objects in the new Dwg and then I did a copy-paste with a base point of the Mutli view block and put it in the New drawing, Created few new view ports in a layout tab and displayed all my new objects in one Viewport and made a new Viewport for the Copied Mutli view block, activated the named view and it plotted - Perfect, the Line thickess were exactly what I was supposed be getting from the other Dwg. I tried few differn't times to fix the Viewport problem in the 1st drawing I created: I made a new Named View, New Viewport, I even checked the Style Manager and the View port is set to "System Default" in both the old and New drawing (changing the View "Style" had no effect) - Yet the New Dwg is plotting it fine. I didn't put this post this in the "Plotting Newsgroup" because the problem isn't with a plotter but with a Drawing and a Viewport. Has any one seen this before? TIA
« Reply #1 on: April 04, 2004, 10:11:18 AM »
Well, actually the only thing close I have seen is the shademode of the viewport. It does some strange things if it is set to anythig other than 2d.
pochrist
« Reply #2 on: April 05, 2004, 09:01:33 AM »
Thanks for the Advice unfortunatly that did not fix the issue, I may have to try to reconstrct the dwg in a blank dwg in order to fix this problem.
pochrist
« Reply #3 on: April 06, 2004, 09:04:59 AM »
****Update****
I did narrow down who may be the cause, I have a
2nd Layout in the drawing and in it I displayed 3 details, (1) is and AEC Section and (2) copied, exploded and modified version of the same detail. If I delete all of them (the details, not the layout) and purge the drawing, the problem with the View port line thickness goes away. I tried just deleting just the AEC Section or just the Exploded - Modfied versions, but the problem persists unless ALL have been removed. I'm baffled as to why these objects are causing the problem - none of the objects apear in the Problem view port (Frozen thowed or otherwise. Hopefully some one can glean from this the reason for this anomally. TIA
