A routine that creates a Sheet List that stores a link betwen the title blocks and itself.The sheet list can be made with a table object or an Excel Spreedsheet or even better let the user to choosewhere to send the information
If you want a real challenge... see if you can put back in the ability to "knock out" alpha channels representing backgrounds in model/layout space in AutoCAD 2007... seeing as our overlords at AutoDesk have seen fit to remove it (which immediately means our entire company will not be upgrading to any newer versions of autocad as this is quite an integral part to quite a lot of what we need AutoCAD to do...)
