Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Disappearing Attributes
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Disappearing Attributes (Read 1051 times)
ELOQUINTET
Guest
on:
August 15, 2006, 09:16:58 AM »
I've noticed problems with my attributes disappearing lately and I'm trying to figure out what's going on. If you look at the drawing I've uploaded all of the titles look fine but when I preview it the DD attribute does not appear. If I burst the block it appears but the CC then disappears. I've also encountered my titleblocks being blank when previewed and it's annoying me. Any thoughts as to what's going on here?
http://www.theswamp.org/lilly_pond/index.php?dir=dan/&file=block%20test.dwg
Logged
Bryco
Water Moccasin
Re: Disappearing Attributes
Reply #1 on:
August 15, 2006, 10:02:43 AM »
Too weird. Copy the dd and the original previews fine but the new one doesn't.
Audit found no errors but seemed to fix the problem
Logged
pmvliet
Guest
Reply #2 on:
August 15, 2006, 01:23:42 PM »
I can't open the 2006 file today
A couple things, Is the attribute still a real attribute (as in it's not exploded?)
Is the attribute in a nested block?
Pieter
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #3 on:
August 15, 2006, 05:28:30 PM »
Same in 2007 ... whacko
Ditto Bryco, Audit did fix the issue.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
