*snip*
I did do UPDATE on the dimensions and that does bring them back, but it's a long
process because I have to update each dimension. That's why I can't post a drawing
now.
*/snip*
My last client that was on R14 just updated to 2002 a few months back so I uninstalled R14 from all of my machines. Thus, I am working from memory with this so you'll have to do alot of the finger work. I think I know what the problem may be but I need you to answer a couple of questions first.
- Are you updating the dimension using the UPDATE command or are you updating the style to get the text back?
-------> if the UPDATE command is working, try typing ALL at the command line rather than selecting individual dimensions.
-------> if you're updating the dimension style to bring them back, I might suggest that you watch the messages that come up when the drawing loads as someone else had previously suggested. If one does, just try substituing a different font in the parent text style for your dimensions.
- Does the geometry of your dimension still look right or have the arrows/hash marks & extensions of the lines disappeared as well?
-------> if this is the case, then you just need to adjust your DIMSCALE variable to the appropriate value. this is the one that caused me the most problems.
