Well, if you want to know the truth, it can also be used in Microstation....Excel, Word, and ANY VBA enabled program....You just need to export the DVB to a BAS file then import it into the VBA enabled application.
Now that is better isn't it.....
You can now create sound events using mp3 files in any VBA enabled application...just by using the MCI command calls.
