Author Topic: CadAMP Windowless MP3 player for AutoCAD  (Read 24177 times)
ELOQUINTET
« Reply #60 on: February 08, 2005, 10:53:32 AM »
strange, i did a search and it found it exactly where you said it should be  :?
ELOQUINTET
« Reply #61 on: February 08, 2005, 10:57:05 AM »
i just looked down at the bottom of the screen and noticed it now says now playing. i plug in the phones and indeed it is playing but when i go to pick another song i get the message.
« Reply #62 on: February 08, 2005, 11:01:52 AM »
Dan, what version of AutoCAD are you using? I know t-bear could never get it working right...he is on 2004
Also what version of Windows?
Strangely enough it works for me on 2004 ..
Try this ...
In TimerModule change the file VBA332.dll to the entire path and see if that fixes the problem.
ELOQUINTET
« Reply #63 on: February 08, 2005, 11:21:05 AM »
hmmm put in the full path but it still doesn't find it. i am using adt 3.3 on windows xp. it's not a big deal right now just wanted to see if it worked for me now. remember i've got my own mp3 player that can play 7000 songs   :P
« Reply #64 on: July 25, 2005, 11:25:11 AM »
Well, it seems that this has gotten quite a bit of attention, some good some bad ... all helpful in development.
What I am considering is further development of this program. Of course the caveat is that if no one uses it (or will use it) then I won't waste my time to improve it.
... and make it more compatable with AutoCAD 2004+
So a show of hands would be great ... should I develop it further ... should I abandon it ... or should I just leave well enough alone ...
42
« Reply #65 on: July 25, 2005, 11:32:32 AM »
Great prog. If it could play a palylist without a promt for each track, then it would be all I could ask for. Runs fine on 2005.
Technical Director
Hunters South Architects
Dommy2Hotty
« Reply #66 on: July 25, 2005, 11:34:38 AM »
I agree with the playlist vote...
nivuahc
Re: CadAMP Windowless MP3 player for AutoCAD
« Reply #67 on: December 12, 2005, 10:43:02 AM »
FYI: This works great in 2006 :kewl:
dubb
« Reply #68 on: December 12, 2005, 03:18:58 PM »
cool prog man..i havent tried it yet since i dont have mp3 on my workstation. is there a way you can play a cd from this program?
« Reply #69 on: December 12, 2005, 03:42:07 PM »
Right now the program only plays MP3, WAV, and MIDI files .... if you burn your MP3 files to CD as MP3s, you can play them.
« Reply #70 on: October 30, 2006, 06:44:45 PM »
Update:
The following CadAMP program plays in AutoCAD 2004 (will not work in 2000-2) and support multiple files.
Get yours here
KIBOY
« Reply #71 on: March 09, 2009, 09:17:14 AM »
hi keith,
im interesred in CADAMP but how can i run those on autocad?
can u giv me some advise on how to do that...
thanks to u sir...
 :mrgreen:
« Reply #72 on: March 16, 2009, 10:32:11 AM »
The code has not been updated in a long time, but it "should" work as long as you have VBA installed.
Download the file from above and place in the path of AutoCAD, then load the CadAMP menu and CadAMP dvb. You should be able to simply play files from the toolbar.
