You can try this one.
;Tip1566A: DIMNOTE.LSP Dimension Notes (c)1999, Mike Lapinski
(defun DN_SHOWNOTE (/ LNUM LNOTE)
(set_tile "error" "")
(setq LNUM (get_tile "lb_notes")
LNOTE (nth (atoi LNUM) DM_NOTES)
) ;_ end of setq
(set_tile "eb_note" LNOTE)
) ;_ end of defun
;; Function: DN_PlaceNote
;; Purpose: If valid note is input, close dialog box
(defun DN_PLACENOTE ()
(setq DN_MODIFIER (strcase (get_tile "eb_note")))
(if (= DN_MODIFIER " ")
(set_tile "error" "Invalid note string")
(done_dialog 1)
) ;_ end of if
) ;_ end of defun
;; Function: DN_AppendNote
;; Purpose: Append note to selected dimension entity
(defun DN_APPENDDIM (VAL PLACEMENT / ENT DVAL)
(setq ENT (car (entsel "\nSelectionné dimension pour annotation: ")))
(while (/= "DIMENSION" (cdr (assoc 0 (entget ENT))))
(princ "\nSelected entity is not a DIMENSION.")
) ;while
(setq ENT (entget ENT)
DVAL (cdr (assoc 1 ENT))
) ;_ end of setq
(if (= DVAL "")
(setq DVAL "<>")
) ;_ end of if
(if (= PLACEMENT 1) ;above line
(setq VAL (strcat DVAL " " VAL))
(if (wcmatch DVAL "*\\X*")
(setq VAL (strcat DVAL "\\P" VAL))
(setq VAL (strcat DVAL "\\X" VAL))
) ;_ end of if
) ;_ end of progn
) ;_ end of if
(entmod (subst (cons 1 VAL) (assoc 1 ENT) ENT))
) ;_ end of defun
;; Main Function - Dimension NOTE
(defun C:DNOTE (/ DCL_ID DM_NOTES DN_ABOVE)
(setq DCL_ID (load_dialog "dimnote.dcl"))
(if (not (new_dialog "dimnote" DCL_ID))
(exit)
) ;_ end of if
(setq DM_NOTES '("AGRANDISSEMENT" "CLR." "D.C." "DÉPART DE COTE" "EXISTANT" "FIN DE PONTAGE" "MIN." "MAX." "N.A.E."
"NON À L'ÉCHELLE" "O.B." "OUVERTURE BRUTE" "REF." "S.I.C." "SAUF INDICATION CONTRAIRE"
"TYP." "TYPIQUE" "VÉRIFIER AU CHANTIER"
DN_ABOVE 0
) ;_ end of setq
(set_tile "eb_note" "TYP.")
(set_tile "dn_below" "1") ; Set as default
(start_list "lb_notes")
(mapcar 'add_list DM_NOTES)
(end_list)
(set_tile "lb_notes" "7")
(action_tile "lb_notes" "(DN_ShowNote)")
(action_tile "dn_above" "(setq dn_above 1)")
(action_tile "dn_below" "(setq dn_above 0)")
(action_tile "accept" "(DN_PlaceNote)")
(action_tile "cancel" "(done_dialog 0)")
(if (eq (start_dialog) 1)
(DN_APPENDDIM DN_MODIFIER DN_ABOVE)
) ;_ end of if
(unload_dialog DCL_ID)
) ;_ end of defun
(princ "Chargé en tapant DNOTE ")
//Tip1566B: DIMNOTE.DCL Dimension Notes (c)1999, Mike Lapinski
dimnote : dialog {
label = "Dimension Notes";
initial_focus = eb_note;
: list_box {
label = "Notes";
mnemonic = "o";
key = "lb_notes";
height = 11;
: radio_column {
fixed_width = true;
: radio_button {
label = "Localisé sous ligne de cote";
mnemonic = "B";
key = "dn_below";
: radio_button {
label = "Localisé à côté de la cote";
mnemonic = "N";
key = "dn_above";
: edit_box {
label = "Note:";
key = "eb_note";
horizontal_alignment = left;
spacer;
ok_cancel;
errtile;
EDIT: Wrapped that up in [ code ] tags for ya
