I'm new to reactors and I've learned a lot from others on this board - thanks to all those who've gone before. I'm trying to create persistent reactors from a separate namespace vlx and while there doesn't seem to be a problem creating them in a new drawing, they are not reliably working on subsequent drawing access.
I'm testing both Tim Willey's
http://www.theswamp.org/index.php?topic=10248.msg132020#msg132020and Lucas's
http://www.theswamp.org/index.php?topic=9573.msg122888#msg122888object reactor routines which behave in a similar way when compiled. When a vlx file is created with the separate namespace option turned off, saved reactors in drawings work as they should, however in a separate namespace vlx, reactors are created ok, but when the drawing is saved and reopened only the last created reactor retains its persistence.
I've tried every combination of making symbols and functions accessible with vl-doc-set and vl-doc-export to no avail... When I open a drawing in which reactors were created from a separate namespace vlx I get the message: Restoring Ldata-> this doesn't happen in a drawing where reactors are working fine. I think the way the reactor object is getting written to the drawing from the vlx namespace is the issue but I'm stumped about ways to fix this.
Any pointers will be much appreciated!
David
