Author Topic: Just wondering......  (Read 2520 times)
« on: March 26, 2004, 02:04:26 PM »
What takes up more space......a line or a polyline?
daron
« Reply #1 on: March 26, 2004, 02:24:12 PM »
I believe it depends on how many vertices. A polyline with two vertices i.e. start and end point, has two vertices. A line has three: midpoint. There are then, with a polyline sub-entities. This could make them larger, but I don't know. If you've been using autocad since before R13, they had three point plines, just like a line. They were then aware that plines took up more space. This is why they removed the vertice. Never tested it though. Take an empty drawing and test them.
« Reply #2 on: March 26, 2004, 02:38:54 PM »
I would have to say that lines probably use more space, because a single polyline with say 10 verticies actually uses less space than the 9 lines with a total of 18 verticies along with layer, entity, and other data that goes with it.
